wiring hookup for coil on BJ-7
robert_ellison
on my coil, one terminal is marked + the other -. The two wires that connect to it are- 1 ) white
2) white & black
Which one goes where?
Thanks!
Keoke
Hi Bob. It is necessary that we know what the ground polarity is in your car, Generally, when the car was built it was set up as POSITIVE ground, For this case the Two common blk/wh wires go to your + terminal while the single blk/wh one goes to the - terminal and the other end terminates at the Distributor.--Fwiw--Keoke
B TR4/4A Wiring Harness Triumph 3
R Wiring ??'s Spridgets 15
Healey Nut Rear Wiring Routing Austin Healey 2
7 General TR Wiring harnesses Triumph 5
Got_All_4 TR5/TR250 Wiring/Electrical Mystery Worked Perfect Then Not Triumph 5
MGTF1250Dave T-Series TF Windscreen Wiper wiring MG 4
M TR6 Fuse box wiring mystery Triumph 9
Healey Nut Wiring Harness Routing Austin Healey 5
J Wiring Harness Austin Healey 5
nichola TR6 Question on new wiring harness Triumph 6
R TR2/3/3A 1954 TR-2 O.D. Wiring Triumph 9
TomMull Dash wiring Plus 2 S Lotus 16
MadRiver BT7 Wiring Diagram Austin Healey 4
R TR2/3/3A Replace wiring harness in steering column Triumph 61
B Bugeye Electrical Wiring Diagram in Logic Format Spridgets 13
J TR6 73 TR6 Temp Gauge Wiring Question Triumph 6
Sopwith_Camel MGB wiring new Tacho MG 0
Ripper01 For Sale- TR6 Wiring Harness Triumph Classifieds 0
R TR2/3/3A Install new wiring harness in steering column Triumph 16
R TR2/3/3A Steering Column Wiring Triumph 18
Got_All_4 TR5/TR250 Pros and Cons to Wiring The Radio Direct Triumph 6
R TR2/3/3A Wiring from the steering column Triumph 7
D TR2/3/3A Tr3 horn testing and wiring Triumph 8
B Bugeye Sprite Wiring Diagram Spridgets 1
JPSmit Todays question - wiring Spridgets 14
P TR6 Wiring problem Triumph 50
ckeithjordan TR2/3/3A Overdrive Wiring Triumph 5
M General MG OEM Radio wiring help MG 4
R TR2/3/3A Overdrive wiring installation Triumph 14
ckeithjordan TR2/3/3A Wiring Harness Question[s] Triumph 10
nichola TR6 Victoria British wiring harness for TR6 Triumph 6
C For Sale MGA wiring harness MG Classifieds 3
C MGA Wiring harness question MG 6
JPSmit I'm stumped - wiring Spridgets 2
R TR2/3/3A Wiring 1954 TR-2 Triumph 12
L Wiring chan Austin Healey 1
W Tach wiring problems Jaguar 12
Michael Oritt LED bulb/resistor wiring question Austin Healey 24
Michael Oritt Safety-wiring knock-offs Austin Healey 24
H Re: electrical short wiring damage Spridgets 11
F TR2/3/3A I'm stuck... alternator/wiring/starting/? Triumph 2
R TR2/3/3A Wiring Nightmare Triumph 26
C Wiring for two front Driving Lights? Austin Healey 22
apbos Positive Ground Alternator wiring. Spridgets 9
BoyRacer Wiring question for alternator conversion Austin Healey 3
BoyRacer Need Tips on getting wiring harness through firewall Austin Healey 4
R TR2/3/3A Installing wiring harness in steering column Triumph 59
6 Relay wiring positive ground Spridgets 4
S TR2/3/3A Triumph tr3 overdrive wiring Triumph 9
C TR6 Wiring problem Triumph 3
