Wire wheel paint
Legal Bill
Merry Christmas and Happy New Years, one and all.
I'm cleaning up one of my original wire wheels to use as a spare. I'll be sandblasting and re-painting the wheel (I know to mask off the splines and seats from sandblasting, thanks for thinking of me). I was going to buy a can of the Moss silver grey wheel paint, but thought I'd ask if people think the Moss color is correct.
Keoke
"thought I'd ask if people think the Moss color is correct."
---YEP: Moss Silver Grey wheel Paint is Just about spot on---Keoke
L
Legal Bill
Thanks guys. When i see it on wheels that others have sprayed, it looks a bit dark and dull to me. With the tire off, the inside of my wheel is so bright and shiny (as compared to the outside that has seen 45 years and 63,000 miles) that I questioned the Moss product. I'll give it a try. What's the worst that can happen?
BoyRacer
Hey there Legal Bill, Marry Christmas.
Just a thought about your wheel. Sandblasting might be a little too aggressive. It can pit the metal and the new paint wont hide it. I suppose it also depends on the size of grit you use.
I am assuming you have the tire off the wheel. If so, your wheel should fit inside a blast cabinet where you could glass bead it. You will be much happier with the results.
One last thought. Glass beads get into everything. Afterwards, put your wheel into a tub of hot soapy water and slosh it around vigorously. That will wash away the glass beads.
Patrick67BJ8
I use the wire wheel paint from Eastwood and it is supposed to be "correct". In the past I removed the tires from the rims and power washed the wheels and then glass beaded them. Before painting I stuck one wheel at a time in the dishwasher on "pot scrubber cycle" when my wife wasn't at home. Wheels loked great and wife happy and Healey happy too!
Patrick
Cottontop
Sorry, Richard.
I have to disagree. Either hard media or glass bead blasting will expose virgin metal which if dunked in water, especially with a wetting agent, will rust within seconds of withdrawing.
Personally, I used Aircraft Paint Stripper and washed them with a power washer (50 cent car wash). No new or unplated metal was exposed and they didn't rust.
I didn't care how authentic the paint color was, so I used NAPA chrome, then coated with Plasticote clear.
I think that they looked GREAT until I got real chrome plated wheels.
Tim
Keoke
Patrick
Yep I did mine on my Daimler Saloon pretty much the same way and had no problems what so ever.--Fwiw--Keoke
Johnny
For what it's worth the color is supposed to be a 'warm silver' whatever that means. I would think bright and shiny doesn't fit.
I've used a chemical stripper followed by a good washing before, and then sprayed a good auto primer before painting with Moss silver I liked the results.
Jim_Newman
Anybody else try powder coating their wire wheels?
dancrim
A Cougar wheel paint around 1965 is a perfect match. I you use childs play sand when you sandblast the metal is not pitted and your job will come out great,
Keoke
:savewave:
Yep!!!! The previous owner of one of my cars spent $320.00 doing just that and guess what!!- every time you need to adjust a spoke or one over flexes it will crack.---Fwiw-Keoke- :frown:
L
Legal Bill
Maybe warm silver is right. I really don't know. I do know that the inside (part hidden by the tire and the rubbery band covering the spoke nipples) of my original 60 spoke painted wheels are bright and shiny compared to the outside that has seen 45 years of wear. Unless they painted the exposed surface of the wheel a different color (which would seem odd) the original color was a lot shinier and brighter than what I have now. If the Moss stuff doesn't match the inside of my wheel, I'll just shop around and find something that does.
I wish it was easier to post pictures on here. I'd take picks of the wheel and post them up.
L
Legal Bill
That is exactly the media I use for just about everything. One bag of play sand and my cheap craftsman sand blaster work very well for cleaning hundreds of parts and the play sand leaves an excellent surface for painting.
I wish I had a blast cabinet, but I don't and I'm not sure I'm going to buy one for this project; although I might if I decide to do all five wheels.
5
57_BN4
Not wanting to sound like one of those safety nuts but... re the use of regular sand for blasting- are you guys aware of silicosis? https://en.wikipedia.org/wiki/Silicosis
Silicosis is a lung disease caused by breathing in fine silica dust and is not curable or treatable. This is why sandblasting is banned in NZ. Garnet, steel grits or glass are used instead.
K Original "old" 1960'es Dunlop wire wheel paint code Austin Healey 7
K Original 1960'es Dunlop wire wheel paint code Jaguar 7
K 1960'es Dunlop wire wheel paint colour code Restoration & Tools 0
D Wire wheel paint MG 8
D Wire wheel clean prior to paint MG 1
Stinger Wire Wheel Paint Triumph 3
1 Paint wire wheel, not the tires... Spridgets 10
D part no for Moss wire wheel paint? Spridgets 3
RJS General TR Wire Wheel Spline Question Triumph 3
B TR4/4A Wire wheel question Triumph 10
P TR5/TR250 wire wheel question Triumph 3
F Three worn hubs and wire wheel centers - What to do next? 1960 BT7 Austin Healey 6
Leatherman TR2/3/3A Wire wheel conversion question Triumph 19
Joe Schlosser Wire wheel Parts Free to good home Spridgets 0
M Chrome wire wheel questions Spridgets 5
S Locknut - rear wire wheel - torque spec? Austin Healey 15
jfarris TR2/3/3A Wire Wheel Grommets Triumph 5
Raymond MGB Wire Wheel Tire Mounting MG 0
Raymond MGB Wire Wheel Cotter Pin MG 5
BN6_2197 Question on rear brake drums BN6 wire wheel Austin Healey 15
KVH TR4/4A Front Wire Wheel Hubs Differ from Disc Hubs?? Triumph 5
B General Tech Wire wheel sealing bands? MG 4
J For Sale Wire wheel set Triumph Classifieds 2
maxwedge5281 wire wheel conversion to road wheels Austin Healey 21
CJD TR2/3/3A Wire Wheel Locating Collar 108942 Triumph 15
M TR2/3/3A Wire Wheel Splines Triumph 3
Z Wanted WTB - One good wire wheel for Spare [15x4.5] Triumph Classifieds 1
S MGA wire wheel space saver spare MG 1
N Wire wheel hub removal & suspension tear down Spridgets 3
KVH General TR Short Wheel Studs for Wire Wheels--Replacing Triumph 14
PAUL161 General MG Wire wheel balancing service MG 2
S General TR Wire Wheel New Tire Installation Question Triumph 11
GTP1960 TR2/3/3A Hub extension torques? [for wire wheel] Triumph 4
S TR2/3/3A Wire wheel balancing Triumph 16
M wire wheel spokes "tuning" Austin Healey 8
S TR2/3/3A 155/15 Vredestein Sprint Classic on a 4.5" Wire Wheel as TR3B Spare? Triumph 6
S TR2/3/3A Lug nuts for wire wheel adaptors Triumph 3
J General TR Wire wheel sale pricing Triumph 18
J How to repair a tubeless wire wheel leaker ? Austin Healey 10
K General Tech 1960'es Dunlop wire wheel pint colour code Triumph 13
5 Bugeye wire wheel dust caps Spridgets 4
mgbmedic Wire Wheel Conversion - What am I Missing? Triumph 11
P New England Wire Wheel Triumph 2
D new member with wire wheel questions Jaguar 6
D new member with wire wheel questions Austin Healey 7
D neww member with wire wheel questions MG 11
D new member with spoke wire wheel questions Triumph 12
Lukens Wire wheel question. Triumph 14
D Where in N. Va. to buy/ mounts tires on wire wheel Austin Healey 3
bighealeysource Dayton Wire Wheel quality issues Austin Healey 0
