TR5/TR250 Wiper mystery - DFPO Strikes again
John Reynolds
Listers,
I have a wiper issue with my TR-250. Although I have the correct looking wiper motor for a TR250, my wipers park on the right side of the car. All of the TR250s I have seen have wipers that park on the left side. I just bought a new set of 250 wiper arms and they definitely will not work with the present set up. My question is, can the parking position be reversed in the wiper motor or drive gears? If I can do this I can use the arms I have purchased. I expect if the park position cannot be changed TR-6 wipers and arms will work on my car. Can anyone confirm this? Any guidance will be greatly appreciated.
Cheers,
John Reynolds
tinman58
Marv is correct! Been there done that. It will not be easy to turn the wheel boxes the right way, if the dash and all the gauges are installed
TuffTR250
I'm not sure how much they can be adjusted, but I was thinking that adjustment of the parking switch mechanism would control where the wipers park. May not fix the problem, but it's worth a try.
Regards,
Bob
J
John Reynolds
Thanks to Marv and the others responding. I will give reversing the wiper boxes a try. I guess the previous owner installed the boxes wrong and subsequently modified the wiper arms to make them fit. He overlooked the fact that when the rectangular piece on the arm was reversed the detent holding the wiper in place was now on the wrong side. This explains why the wiper flew off the first time I turned them on. Not much fun in a rainstorm, but, he has done much worse.
Cheers,
John Reynolds
JerryVV
The wiper arms fit too loose on the repro wheel boxes. My 4A and a friends 250 suffer from this. Also the park position can be adjusted at the wiper motor if your car has the 4A style motor which I believe that it does. Someone will correct me if I'm wrong but I think the motors changed on the TR6.
Rut
Just a question for my own edification...will wheel boxes interchange between a TR4, MGB, and possibly a Midget using the appropriate spacer?
Rut
Jerry
I would like to add on to this wiper discussion. My mini wipes too far. It hits the windshield rubber on the beginning and end stroke. I am using a 105 degree gear at this point. Is there anything else that will make the stroke shorter?
Jerry
Bob Claffie
No, AFIK a gear change is the only way to change the stroke. Likewise I believe all wheel boxes are interchangeable.
I'm thinking the TR3 wheel boxes are a little bigger making travel not as far. That might be a fix for the Mini.
Rut - think rest most of the boxes are the same
marv
charleyf
The difference between the TR3and TR4 wiper sweep is a result of a different size gear found in the drive of the wiper motor. I realized this when pulling parts for a TR3. I had a TR4 wiper motor and realized when I put it up next to the TR3 motor that the round gear is smaller on the TR4. This is not noticeable unless they are next to each other.
Charley
Jerry
The current gear is out of a Sprite, labeled as a 105 degree. I tried two different 110 degree without success. I have not been able to find anything that has a gear smaller than 105 so far.
Jerry
charleyf
Charley
i measured the outside diameter of the cover over the round gear found next to the wiper motor. I had the size backwards between the TR3 and TR4. The TR3 measured 1-7/8" while on the TR4 it was 2-1/8". The actual round gear inside will be smaller, but the difference between the two is what gives you a shorter or longer sweep of the wipers.
I also note that the identifiers on the units are DR2 for the TR3 and DR 3A on the TR4.
Hope this helps.
Charley
S Mystery Wiper Arm Attacfhment Austin Healey 7
J For Sale Lucas 75150A Wiper Motor Other British Classifieds 0
D TR2/3/3A wiper motor parking? Triumph 17
S Wanted Windscreen Wiper Arm for BN1 wanted Austin Healey Classifieds 2
R TR2/3/3A TR3 Wiper motor Triumph 10
G Toyota Wiper Blade Inserts - Cheaper Option Other Cars 3
R TR2/3/3A Wiper Arms Triumph 8
Joel Lester TR2/3/3A TR3 Wiper motor wiring and testing Triumph 5
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
I Replacing Windscreen Wiper Wheel Boxes Austin Healey 0
DocDup1 TR4/4A DR3A Wiper Motor Park Setting Triumph 4
DocDup1 TR4/4A TR4A Wiper Moror Rebuild Service Triumph 5
R TR2/3/3A Windshield Wiper System Triumph 2
B TR4/4A Too Many Wires? Wiper Motor Triumph 9
T TR2/3/3A wiper motor short Triumph 2
MGTF1250Dave T-Series TF Windscreen Wiper wiring MG 4
Sopwith_Camel mk2 windshield wiper nozzles Jaguar 4
nichola TR6 Rebuilder or replace wiper switch? Triumph 7
M TR6 Wiper washer knob Triumph 5
B TR4/4A Rubber wiper motor mounts Triumph 4
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
BoyRacer Windshield Wiper Wheelbox Austin Healey 4
Kurtis TR4/4A TR4 Wiper Arm Remval Triumph 2
S Series 1/2 Wiper Motor Needed Rover / Land Rover 0
W TR2/3/3A TR2 wiper motor mount Triumph 1
steveg TR6 Late Wiper/Washer Switch - What Happened? Triumph 3
RAC68 Wiper Motor and Arm Adjustment Austin Healey 8
P Wiper direction Austin Healey 9
R GT6 Wiper Motor problem and time capsule Triumph 4
N TR2/3/3A Wiper motor armature Triumph 11
T Windscreen wiper wheelbox rubber shaft seal Austin Healey 4
RCarr 1954 BN1 Wiper Wheelbox and Rack Austin Healey 3
Jim_Stevens TR2/3/3A Wiper motor hookup Triumph 4
M Wiper Motor Problem Not Working Spridgets 5
B TR2/3/3A Windshield Wiper mount rubber Triumph 3
J TR2/3/3A Wiper Motor bracket Triumph 5
JPSmit Question - wiper switch and signal switch ends Spridgets 4
T TR5/TR250 TR250 wiper switch and motor Triumph 1
JFS TR2/3/3A Wiper Cable Lube Triumph 5
T TR5/TR250 Wiper wheel box knurled end not tight on arm Triumph 9
T TR5/TR250 What lubricant for TR250 wiper box and cable? Triumph 2
Bayless Question on 1 speed wiper motor Spridgets 2
BoyRacer windshield wiper motor rubber mounting grommets Austin Healey 9
S TR2/3/3A Rebuilding Dr2 Lucas wiper motor Triumph 16
sparkydave Wiper switch repair Spridgets 5
F TR2/3/3A Beware eBay wiper blade and arm sales Triumph 6
tinman58 TR5/TR250 TR 6 wiper motor Triumph 10
H Post-War Other Wiper Motor [Early type DR2] Issue Triumph 7
pa297pass TR4/4A TR4 wiper motor rubber mount installation. Triumph 7
