windshield seal to car
zimmy
ive just finished putting my windshield
back together with the new glass and
seals....looks great!
but im not having much luck with the
windshield to car seal...
anybody know an easy way to install it?
also , will it shrink any? ........zimmmmy
jlaird
Actually it should slide right in and will need to be cut to fit the appropiate length. Use some dish soap.
Seat one side, and then press the other in with a rounded dull tool. I use a plastic orange peeler.
Jim_Gruber
It works real easy if you take the side off of the windshield. Slides right in place. One person job. Trying to tug through little slot on the channel is a PITA.
A tip on reinstallation. Could not figure out how to hold windshield shims in place and put screws on at the same time and keep everything aligned. I cut a slot in the side of the windshield shim so it came come in once the screw is through the hole and everything is lined up. Screws in place, slip shims into place via slots cut into shim and you are good to go. Also if using two shims a little masking tape to keep alinged goes a long way in getting it back together easily.
zimmy
zimmy
think ill try trevors method first,
i really dont wanna take any screws
out for obvious reasons....
looks really good so far and im excited
about being able to see where ill be
going,as my old WS was badly hazed and pitted!...z
Jim_Gruber
Why didn't you replace the seal while the side frame was off to replace the glass? or am I the only one on this list guilty of not preplanning the entire job.
It is a 10 minute job to tuck the seal into the groove one edge at a time. Honest. I've done two.
Joelb
Zimmy, how did you trim the seal? Do you have any pictures?
I'm doing the same thing right now and don't know how long I should trim it.
Joelb
One more thing, the seal on the side post, did you have any trouble with that? The one's I got from VB seem too big.
zimmy
zimmy
i didnt do the side post...
u probably have to trim them.
also , i havent got to the seal
yet...been busy with paint work....z
Jim_Gruber
Joel, The side seals will likely be too tall. It appears to me that you do need to trim them once windshield is on the car. They need to fit up flush against the forward part of the door otherwise you'll have an air as well as water leak right there. A Spridget never leaks of course but you don't want to make it worse. Wait till top is on the car before trimming off the top.
There is a rivet / screw that fits inside the bottom of the side rubber about 1" up from the base to keep the side rubber from sliding up. Wondering if that is really needed or perhaps a little contact cement.
Windshiled shims, I don't even want to get started on the number of hands needed to hold two windshield shims and press down and feed bolts in. I ended up cutting a notch in the windshield side post shims so they could be installed once bolts were started. Nothch slides over both bolts, held in place by the bolts and then tighten down.
Jim_Gruber
ModifiedBJ7 BJ7 Windshield Surround Rubber Seal Austin Healey 2
Michael Oritt 100 Windshield seal Austin Healey 0
S Bugeye Windshield Seal Austin Healey 1
Rut Windshield rubber seal Spridgets 6
TR3TR6 TR6 Triumph TR6 Windshield seal on ragtop Triumph 6
H Windshield to body seal Spridgets 9
Rut Bugeye windshield to body seal Spridgets 8
aero3113 100 lower windshield seal Austin Healey 4
HealeyRick Grey Windshield Pillar Seal Austin Healey 19
K TR2/3/3A Windshield corner finishers/seal retainer? Triumph 2
TR3TR6 TR6 TR6 top frame windshield seal. Triumph 5
D BJ7 Windshield Glazing seal Austin Healey 3
J BJ8 windshield-shroud seal installation-found way to help keep ends from popping out Austin Healey 1
healeydan Windshield Seal Won't Lie Down Austin Healey 3
J TR2/3/3A Lower windshield rubber seal Triumph 3
M Bn-2 Windshield Seal Paint Bleed Austin Healey 8
maxwedge5281 windshield to shroud seal Austin Healey 2
R TR2/3/3A Windshield lower seal orientation, again... Triumph 9
Lbp TR2/3/3A Question about TR3 Rubber Windshield Seal Triumph 9
M TR4/4A TR4A - looking for a windshield glazing seal Triumph 6
O BJ8 Windshield seal Austin Healey 3
M Sliding bottom windshield seal into groove... Spridgets 2
J Confused about Bugeye windshield to body seal. Spridgets 15
T TR2/3/3A TR3A upper windshield seal Triumph 12
M TR2/3/3A TR-3A Windshield Seal - Top Triumph 2
Nelson Windshield seal installed Spridgets 1
Nelson Windshield seal Spridgets 10
T windshield rubber seal Austin Healey 7
A 76 MIDGET WINDSHIELD SEAL FRAME TO BODY Spridgets 13
Jim_Gruber Pics of Windshield Seal to Vent Window Frame Spridgets 7
H Any tips to install BJ8 bottom windshield seal? Austin Healey 0
bighealeysource Rubber seal on windshield frame of BT7 Austin Healey 0
zimmy progress....... AND my windshield to body seal Spridgets 10
C Trimming windshield seal Austin Healey 1
Stewart Windshield cowl seal hot tip MG 1
HAN8L1965 Windshield Seal on a 65 Spridgets 5
amcboy TR6 Windshield Seal Question... TR-6 Triumph 8
J Moss windshield to body seal. Austin Healey 2
AndyH Windshield to body seal MG 2
regularman windshield seal question Spridgets 0
judow Windshield Seal BN-2 Austin Healey 6
John Loftus BJ7-BJ8 windshield seal cut Austin Healey 6
D Windshield to body seal Spridgets 17
Ed_K Installing the windshield frame to cowl seal ? Austin Healey 6
P Windshield Stanchion Seal Triumph 4
bluemiata90 replacing the rubber seal on windshield Triumph 18
P MGB WINDSHIELD TO BODY SEAL & VENT WINDOWS '79 MGB MG 3
T Replacing the windshield seal Triumph 5
SilentUnicorn windshield to body seal Spridgets 15
J SOLD!! Triumph TR 2 TR 3 windshield stanchion mounting plates Triumph Classifieds 3
