Window Seal Clip Question
Ray7Smith
Can someone send a photo showing the proper instillation of the window seal clips that secure the inner and outter seals.
I am replacing the seals on my BJ7. It appears that the clips on the old seals were installed incorrectly.
Ray
Keoke
Hi Ray , Whst makes you think the original clips were installed incorrectly? Thats pretty hard to do.--Keoke
R
Ray7Smith
Keoke,
My assumption is based on the fact that the clips on the outter strip are installed in such a manner that require the strip to be installed by pushing the strip upward into the clips. The inner strips are pushed downward to install. I would seem that if the clips were installed correctly, both strips would be installed in the same manner, i.e. both downward.
Ray
Keoke
Nope, the clip pushes on upward on to the rubber piece at the indented locations. It is then pressed on to the chrome trim and the remaing loop which faces down snaps on to the top of the door's lip.--Keoke-??
R
Ray7Smith
Keoke,
It sounds like you are saying that the chrome trim on top of the door must be removed before installing the outter strip. How does one remove this chorme strip?
Ray
Keoke
Hi Ray , Take a strong screw driver and put it up under the extreme back edge of the chrome strip. Tap the screw driver with the palm of your hand until it clears the top edge of the door. Now push it slightly forward and continue by hand, lifting it up, to loosen it along it entire length.--Keoke
B Window Seal Clip Tool Spridgets 5
T Early BJ7 Vent Window Seal Austin Healey 2
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
M Window Seal Bugeye Sprite Removable Hardtop Spridgets 3
B New Window Seal for BJ7/BJ8 Roll Up Windows Austin Healey 1
NutmegCT Window weather seal repair Restoration & Tools 4
Jeepster Door to window brush seal Austin Healey 0
jollyroger Spitfire rear window seal 76 spitfire Triumph 3
Jim_Gruber Pics of Windshield Seal to Vent Window Frame Spridgets 7
bighealeysource MGB Refitting rubber window seal on 65 MGB MG 1
R Side window seal installation problem. Austin Healey 20
R BJ-7 window rubber seal Austin Healey 2
I TR6 TR6 window door pull/window seal help Triumph 6
jerrybny More window seal questions Triumph 5
Paulus Door to window seal installation? Triumph 7
jerrybny Top to window seal problems Triumph 4
D Window-Channel-to-Windscreen Seal Lotus 1
Guinn More window seal MG 19
Guinn Window seal parts from Tony MG 6
A vent window seal replacement Austin Healey 0
SpeedyG TR4/4A Door window regulator spring Triumph 5
AngliaGT Wanted Two inside window handles & Regulator for Driver's Door - '67 GT MG Classifieds 6
O Jaguar rear window trim repair Jaguar 1
Bayless How to repair broken vent window studs? Spridgets 1
J Wanted MGA Coupe rear window glass center section MG Classifieds 0
B TR4/4A Window Regulator Leather Washers Triumph 6
algot1901 Window Channel Ford Prefect Other British Cars 5
DrEntropy Benz electric window battle Other Cars 13
Patrick67BJ8 Glazing Door Window Glass in BJ8 Austin Healey 15
Robert Somma power window installation TVR 3
idlehands Wanted WTB GT6+ driver (LHD) window glass and a single rostyle wheel cover Triumph Classifieds 1
HealeyRick BJ7 Side Window Alignment Austin Healey 31
nichola TR6 Door handle and window crank installation Triumph 0
gbtr6 Wanted: '96 LHD Drivers side master window switch panel. Jaguar Classifieds 0
P TR6 Tight window crank Triumph 9
B TR4/4A Window Channels Triumph 6
JFS Wedge Door wing window finisher Triumph 2
maxwedge5281 Replacing Factory Hardtop Rear Window Austin Healey 24
A PLATE, handle locking on Vent Window Austin Healey 0
B Side window question for early Longbridge BN4 Austin Healey 4
A Rebuilding Tiger window regulator question Sunbeam (Rootes) 3
T TR6 Frosted rear plastic window Triumph 6
G BJ7 Window channel position Austin Healey 1
P Rivets on windshield and vent window frame. Austin Healey 1
AUSMHLY BJ7-BJ8 outer weather strip for door window Austin Healey 4
B BJ8 vent window collar fused on Austin Healey 7
M Zip-Out Rear Window on a BN-7 Top? Austin Healey 11
Zitch TR4/4A Window Guide Writeup Triumph 2
M window rattles Austin Healey 5
