I have a 63 spitfire mk1 with SU carbs. I have checked all the timing, points and spark. If the car is cold it will start right up. I don't even have to choke it. I let it run for 5-10 minutes or even longer and when I turn it off and try and restart, it will not fire off.
I have check the spark, it is good, vacuum is good, timing seems to be ok, compression is about 125lb per cylinder.
I pull the plugs and 2 and 3 are wet. 1 and 4 seem to be a bit wet but not like 2 and 3.
I wait for 24 hours and come back and the car will start again. If I try even 12 hours later it will not start.
I am thinking that maybe I am flooding the 2 and 3 cylinders. Or I may have some issues with the rings or head gasket that shows up after the car warms up.
The oil is clear, antifreeze is good. The car is burning on the rich side at the moment but until I can get the car starting and running reliably the fine tuning on the carbs will have to wait.
In the head do 2 and 3 intake ports sit lower so gas could pure down into these cylinders?
Any ideas or help would be great. Thanks. Tom
