ncbugeye
I now have a Lucas points set and a "Made in China" low-tension lead. The hole in the connector of the China low-tension lead is slightly too small to fit over the shoulder of the insulator on the hinge end of the Lucas points. Why doesn't anything just "go right" any more? I can drill it out, I guess.
As if that wasn't enough, the connector is a spade terminal, not a stud and nut fitting. I can install a spade terminal, I guess.
AAARGGH!
AAARGGH!
