Where to get 2 tone colour electrical wires
DirkRoels
I would like to upgrade the electrical wiring to my car by using the original 2 tone electricla wires. Does anyone knows where these could be found? I'm refereing to the single wires, not the whole cable tree.
Thanks
Dirk
andybj8
Dirk
As you are in Belgium, Autosparks in the Uk are nearer and quicker, they make all the the looms for most of the Healey parts suppliers:
https://www.autosparks.co.uk/
you have to click on the type of wire, ie pvc, or braided, then they have pull down menus with all the colours.
Otherwise give them a ring / email with you car model and they will advice you.
cheers Andy
DirkRoels
Hi, Thanks for the advice.
in meanwhile I found also a company in the UK called AES.
I ordered the wires at autosparks and the connectors and switches at AES.
B MGA Where to Buy, What to Buy? Axle Nut MG 8
Scotsman TR4/4A Chimney nuts, where do they go Triumph 5
jehuie Where to post for parts that fit many cars? FORUM Navigation Questions 1
Pythias Where to post FOR SALE Spridgets 1
A Where to get key blanks for SD1 in the U.S.? Rover / Land Rover 5
F Off Topic Personal update/ Where is Frank? Triumph 4
Basil Where's Walter? Spotted 8
Q TR2/3/3A Where to start?! Triumph 13
jlaird MGB Up date. Where to begin? MG 7
B Windshield glass, where to buy Restoration & Tools 4
steveg TR6 '74 - Where is the Starter Relay located? Triumph 1
C MGA Where to tap into 12v for a power outlet MG 2
S TR2/3/3A I have this miss where the car will start and kinda idle Triumph 23
C Anyone know where to get one of these? Austin Healey 6
P Area where pillar, shroud, and drainage channel meet. Austin Healey 3
P Drainage Channel Where It Meets The Shroud Austin Healey 6
M TR4/4A Where to buy a new crown wheel & pinion for TR4A Triumph 5
PAUL161 T-Series Where My TF Came From MG 1
FlyingCat Spitfire What hoses go where... Triumph 6
A Phase 1, Phase 2, Where's Phase 3 Austin Healey 14
Got_All_4 General TR Someone asked where to get DOT5 silicon brake fluid a while back Triumph 4
Got_All_4 TR6 triumph tr6 wrist pins where to get them Triumph 5
T TR2/3/3A Where is best spot to check temp with infrared thermometer? Triumph 17
Got_All_4 General TR Anyone know where to get one of these? Triumph 5
R J-H Stromberg carb connections? Where do they go? Other British Cars 2
Paulus General TR Where to get HVDA parts and vibration when engaging clutch. Triumph 13
B TR2/3/3A Where on the clutch pedal? Triumph 4
N Spitfire Just picked up this 73 Spitfire. Hasn't run in ten years. Where do I begin? Triumph 10
P T-Series Where's my last TD? MG 2
R engine removal- where to connect hoist? Austin Healey 16
C Where and how to "disconnect" my two SU's? Austin Healey 3
55modified TR2/3/3A warning indicator bulbs need replacing where and what to buy? Triumph 4
S TR4/4A Where do the ground straps connect Triumph 5
Jim_Gruber Hubs a Rocking on side where Speedi Sleeve was installed Spridgets 5
warwick-steve Where did the smell go? Austin Healey 11
Gliderman8 TR6 Convertible cover snaps... where to install? Triumph 2
M TR4/4A Where to buy this aluminium extrusion? Triumph 7
C Gauge faces - where to get Austin Healey 9
G Where can I get bottle jack seals? Restoration & Tools 2
R TR4/4A Where can I get Triumph Midnight Blue carpet? Triumph 0
Got_All_4 TR2/3/3A Where to place the switch for the windshield washer & bottle Triumph 8
C Where to wire a Pusher fan - BN1 Austin Healey 16
Rob Glasgow Brackets, where do they go? Austin Healey 3
Got_All_4 TR2/3/3A Where can i get these door handle parts Triumph 1
M BT7 restoration, Where to start and sill reinforcement Austin Healey 3
M TR2/3/3A Two black wires on control box E where do they g0 after alternator conversion? Triumph 9
M TR2/3/3A Where can I get British Racing Green, 1958 Triumph tr3a touch up paint in the USA? Triumph 3
M TR2/3/3A Where does this screw go? Triumph 6
vette Any Suggestions As to Where to Buy a New BJ7 Gasoline Tank? Austin Healey 24
