What type engine do I have?
DanZ_BT7
Member
The engine ID tag on my BT7 is missing. Is there a way that I can tell the production number of my engine by looking at the other information on the engine block?
I see a 29 stamped on the side.
I noticed that my BT7 doesn't have a 10 inch clutch. Does this mean that I have an engine from a BJ8?
I measured the clutch at about 9.5 inches.
Keoke
DanZ_BT7 said:
The engine ID tag on my BT7 is missing. Is there a way that I can tell the production number of my engine by looking at the other information on the engine block?----------)
Perhaps, on the engine block just below the exhaust manifold at the front of the engine there may be an aluminum tag inscribed with the engine number on it.
I noticed that my BT7 doesn't have a 10 inch clutch. Does this mean that I have an engine from a BJ8?----
Only if the engine ID tag defined above says 29K
I measured the clutch at about 9.5 inches.-------
Perhaps again since all BJ8's used the 9.5" clutch disk. However, some PO could have swaped only the tranny or the clutch parts.
---------------Keoke
DanZ_BT7
DanZ_BT7
Member
That tag is missing. I ordered a 10 inch clutch but when I removed the existing clutch I noticed that it is much smaller (about 9.5 inches). I haven't investigated the transmission id tag yet. Maybe that is next.
I placed the 10 clutch onto the flywheel to see if it would fit. It doesn't fit. It doesn't fit due to pins on the flywheel that get in the way. That is why I think that I might have a different engine. Maybe someone replaced the flywheel with the clutch parts?
Keoke
Maybe some one replaced the fly wheel with the clutch parts. Yes if a different clutch Has been installed it follows that the corresponding fly wheel be used.
How about the carbs on the engine are they very large and have black plastic tops that bear the number AUC 8112 on them??
Look on the top of the transmission bell housing on the outboard side do you see " 22B173" ? ?----------Keoke
Johnny
Bob Hughes
Bob's rule number one - do not take things at face value.
These cars are 40 plus years old and in my case have been roaming planet earth from continent to continent. I have a BJ7 and renewed the clutch earlier this year, I left the purchase of the new one until I got the old one off, primarily because I could not find the engine number, but as it happened it was 10 inch job as the good book would dictate.
I have discussed engines with my local chap and was present when a delivery of used engines from the Austin Westminster arrived at his place. At ÂŁ60 a throw it was a good investment for him, he would get one or two refurbished to Healey spec and slot them straight into a car that has come in for an engine rebuild - with the owners approval of course, as some Brits are keen as mustard in keeping all the numbers together if possible. His comment was that there are not that many cars out there that have the original engine and this comment has propted me to be careful when ordering engine parts etc.
Bob
shorn
It is fairly simple to remove the number tag off one engine block and put it on a replacement. That certainly applies to the car body (vin) tags too. Therefore one should be careful. Things are not always as they first appear.
Patrick67BJ8
If there's any doubt about the correct vin number matching the car, you should remove the R/H front wheel and look for the vin ID number stamped on the shock tower. That would be the number hardest to change.
Patrick
M E Type 4.2 engine rebuild Jaguar 4
M Photos Needed of Series III E-Type Engine Oil Filter Clearance at Exhaust Manifold Jaguar 1
B Spitfire Advice on swapping to J Type OD with 1500 engine in 69 Spitfire Triumph 13
B Engine Oil Type and Weight? Austin Healey 8
jjbunn Engine fan - '69 E-Type Jaguar 15
M new engine rebuild, new type oil seal and LEAKS ?? Triumph 15
BOBBYR ENGINE OIL TYPE ? Austin Healey 7
Bruce_B Spitfire Spitfire Engine Type? Triumph 5
P E-Type 6 cyl Engine Rebuild in San Diego Jaguar 4
L X-Type -Engine Malfunction Light Horror USA California] Jaguar 9
J Lack of Diesel Engine in Europe causes slowdown in X type sales and production Jaguar 0
C Mid engine F-Type ? Jaguar 5
J Jaguar X-type pricing out..29950 for 2.5 engine 4 whd..stick..would you buy this? Jaguar 16
R TR6 Clutch Master Cylinder Hydraulic Line (Thread / Flare Type) Triumph 4
S TR2/3/3A 187 NOS sleeved type thermostat Triumph 16
M Series 3 E-Type Bonnet Jaguar Classifieds 0
Basil The new Kia E-Type? Jaguar 6
H TR4/4A A-type overdrive pump Triumph 4
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
P Wanted E type spare tire bracket Jaguar Classifieds 2
P Wanted 62 E Type spare tire bracket Other British Classifieds 1
Got_All_4 TR6 Routing Speedo cable for a J type tranny in my TR250 Triumph 4
Got_All_4 TR5/TR250 Trying to figure out rear transmission mount with a J type tranny Triumph 9
I GT6 A type OD vs D type - engagement speed? Triumph 3
J For Sale Jaguar E Type and MK2 spares Jaguar Classifieds 0
VooDooDaddy63 Basic E-Type Question: Fasteners - Metric or SAE or ...? Jaguar 15
D TR2/3/3A Type A overdrive not engaging Triumph 0
D TR2/3/3A Type A overdrive not engaging Triumph 16
S For Sale Lotus Elan Factory Workshop Manual on CD/ROM - Type 26 - 1963 - 1965 Other British Classifieds 0
B Resistor type vs non-resistor type spark plugs for 100-6 Austin Healey 17
K TR4/4A TR4 Fuel Gauge'"light bulb socket" type? Triumph 11
Martinld123 H Type Carburetors BN2 M version Leaking Fuel At Jet Bearing Area Austin Healey 18
AH67 Heat Shield finish 66 Type Jaguar 5
AUSMHLY Grease type for zerk fittings Austin Healey 7
M TR4/4A A type Overdrive Oil Leak Fix Triumph 3
M 5-speed, 1968, 4.2, E-Type, OTS Jaguar 3
M e-type siries 1.5 shock abosorbers Jaguar 3
B TR2/3/3A 'A' type Front calipers, TR3 vendor??? Triumph 7
D E-Type steering wheel Jaguar 6
DrEntropy E-Type windshield FYI: Jaguar 1
TRclassic3 TR4/4A A type OD working in 3rd but not in 4th Triumph 5
Graham H TR2/3/3A A type overdrive Triumph 6
H Post-War Other Wiper Motor [Early type DR2] Issue Triumph 7
M E-type series 1 plastic dash vents Jaguar 1
M TR2/3/3A SU H Type Carberator Float Lever Adjustment Triumph 10
KVH General TR Type A Laycock Overdrive Questions Triumph 8
Talon TR2/3/3A Float lever issue on SU type H carbs Triumph 1
D '69 E-Type sputters, coughs & dies Jaguar 20
Boink Left-hand Drive E-type at Windsor Jaguar 5
H Clutch-Type Differential Austin Healey 5
