Went with friend to the Farm Store
jlaird
Is new to our area only about 20 miles away.
Got 50 feet of air hose for 10 bucks. No more moveing air compressor around to work on things.
You know I have 18 tires that need checked from time to time. Gesh. How I ever got along without a compressor I will never know.
Jim_Gruber
Hey Jack hope you got some of the good stuff like 1/2" or bigger. You make find as I did that the cheap hose loses so much pressure that your air tools won't work well. I changed all of my fittings over to larger size i.e. larger ID on hose as well as all of the quick disconnects. Pressure drop is significant for each and every coupling and fitting between the compressor and the tool.
Jim_Gruber
1/2" Hose I.D. plus larger quick disconnects. I found running 2 50' sections of 3/8" hose along with assorted quick disconnects and couplers I ended up with a better than 50-60% loss in air pressure at my impact wrench. Impact wrench rated at 450 ft. lbs. could not budge the lug nuts on my daily driver. Ended up changing out all hoses to a 50' section of 1/2" hose and changed all of the fittings on all of my air tools to 1/2" I.D. Unbelievable difference in performance and torque. Google Air Hose AND Pressure Drop for lots of info on the subject.
jlaird
jlaird
My hose is 3/8 and seems to be fine for my purposes, shrug.
ecurie_ecosse
It's the length you have to factor in,Jack. Up to 50' you'll get away with the 3/8 hose and fittings,over that and the pressure drop really kicks in.Then you have to move to 1/2 hoses just as Jim has.
Stuart. :cheers:
jlaird
jlaird
Ahh, thanks Stuart, guess I need a larger garage before I need to be concerned.
It seems I mostly use this to take care of the neighborhood kids bikes, hehe, and glad to do so. As a result they are very nice to me, good kids in any case.
Jim_Gruber
Tractor Supply, HF. usual places. Just look a little more.
R
RonMacPherson
Most large communities have an industrial hardware supplier(Grainger, etc.) or bearing supply house or shop equipment store.
jlaird
jlaird
Niceville is just what it says. Nothing here, move along.
Billm
Also air quantity is a big factor, If you are just air-up tires then 1/4" line at 100 feet is fine but if you are running a 1/2" impact then 3/8 hose at 50 feet is questionable. I use 3/8" hose at 25 feet and move my compressor (and have a very long 220 volt extension cord).
Bill
G MGB ugh.....the fuel gauge went to *** again! MG 8
AngliaGT Went to Duncan Imports Today Spotted 5
AngliaGT Went to Get a Pallet,& spotted This...... Spotted 0
AngliaGT Went & Looked at a Few Cortinas Tuesday Spotted 17
N Suspected disaster - but it went well. Oil pressure restored. Austin Healey 1
AngliaGT Went to West Virginia Today [For about five minutes] Spridgets 2
R Clutch Went Away Austin Healey 9
Jim_Gruber Bugsy is alive and went for his first real drive this afternoon. Spridgets 9
gbtr6 TR6 Went to Sussex British Car Field Day, with some baggage. Triumph 5
J Went for a nice drive yesterday Austin Healey 0
PAUL161 MGB Went to a hot rod show! MG 3
J Went To Auburn Cruise Night and met an Aussie who just bought a 54 to take back home. Austin Healey 1
S TR6 First drive in the TR6 went well...until it didn't Triumph 9
D Riding today and clutch went out...... Triumph 6
J Went to a Jensen show this last weekend Other Cars 10
PAUL161 WHAT HAPPENED? PRINT WENT small! MG 3
AngliaGT Went to Albany,Oregon Yesterday Spotted 2
mrsprite My Bugeye went Ka-Boom! Spridgets 10
T Went to Barrett Jackson last night Triumph 9
bobmga62 New Master cylinder that went bad MG 3
G Went and looked at junk today Spridgets 2
pjsmetana Went for a drive last night... Triumph 3
TexasSprite Went for a drive in Dallas.... Spridgets 11
waltesefalcon TR6 Went to Wal-Mart today walked away with a TR6. Triumph 12
bighealeysource Know why the British Leyland went under ! Austin Healey 10
B All went for $1225 Spridgets 14
regularman Went to start the Midget. Spridgets 10
JPSmit Ms Triss went to the dentist today Spridgets 14
martx-5 TR2/3/3A Went To Fire Up the TR3 Today...Got a Problem Triumph 18
HAN8L1965 Went Looking for Cars Today Spridgets 0
RickB I have three Midget hoods, so I went ahead.... Spridgets 23
regularman So, I went for a ride today Spridgets 6
jlaird I went to a local showing Spridgets 16
PAUL161 Alternator went bad! Bummer. MG 8
Bret Well them Dodge boys finally went & did it! Other Cars 4
G Went this morning to visit my head....... Triumph 14
T In case you were wondering where the Bugeyes went Spridgets 6
Adam58 Went to look at a '61 Magnette and what did I see? MG 18
BritCarFan Stag Went to look at a Stag today...... Triumph 1
regularman Well, that went well.......NOT! Spridgets 9
jjbunn I wondered where all that brake fluid went! Triumph 7
B Dang! Starter went out! Spridgets 23
Russ Austin Temperature gauge went goofy!! Triumph 37
jlaird Went for a nice ride after dinner. Spridgets 5
jlaird Went to the Dr. today Spridgets 3
T Went Shopping Today [the good sort, not the mall] Triumph 6
YankeeTR I went to lunch in a MG.... Triumph 8
roofman This last surrey went for cheap[er] Triumph 1
L Went to Harbor Freight Restoration & Tools 4
regularman Went downstairs and got my midget fix today. Spridgets 7
