weber linkage
kalist
Could some one who has a dcoe weber on their sprite post a picture of the throttle linkage/cable set up you are using. I am having a problem routing mine so it works smoothly so before I reinvent the wheel I thought I would ask for help.
Thanks!
Westfield_XI
Which linkage do you have? Top or bottom mount, and which end of the throttle shaft is the arm attached, front or rear?
K
kalist
The linkage I have has the arm mounted at the rear and pulls up. Looks nothing like the picture from blue max. The picture helps. I am thinking I will need to purchase a top mount set up to make this operate properly. Currently it is just an arm off the throttle shaft with a mount on the top of the carb for the cable to sit in. Only remaining question I have is how do you mount the cable in the linkage shown in the picture.
BlueMax
If you look real closely you can see the accelerator bracket next to the valve cover, its held down with bolts that are threaded into a flat flange on the manifold…
twas_brillig
We have a 40 DCOE in our BE; any suggestions for an arm/linkage that would allow the 'pull' action of the choke to actuate the Weber 'enriching device' (which requires a 'pull' towards the front of the engine)?
Thanks,
Doug
BlueMax
Choke linkage is already on the throttle plat side, all you do in install the cable and use a hollow pinch bolt. You just have to figure cable length and your good to go. Here in the South it rarely gets cold enough to use a chock since the Weber has thoughts huge accelerator pumps.
T Looking for advice for throttle linkage for Weber DCOE Spridgets 2
J TR2/3/3A accelerator linkage for Weber 45 DCOE Triumph 4
jvandyke Weber linkage? Spridgets 2
L TR4/4A Weber DCOE linkage for TR4 Triumph 4
DenverMGB Weber Carb 32/36 DGV - Choke Linkage? MG 18
philman weber carburetor linkage Triumph 5
Celtic 77 MGB Tappet breather to Weber downdraft MG 4
R For Sale Weber Primary Venturi (28mm) for 40 DCOE Triumph Classifieds 0
K Marcos GT Weber Emulsion tubes on ethanol/E85 Kent X flow twin 40 DCOE 32 Other Cars 2
S For Sale twin Weber 40 DCOE 31 set Other British Classifieds 0
Celtic 77 MGB Rerouting heather pipe after Weber install. MG 13
S Weber carb set Other British Cars 7
TomMull Wanted Weber 40 DCOE 18 Other British Classifieds 1
TomMull Weber Carburetors Lotus 18
C MGB More Weber help needed MG 27
C MGB Which Weber DGV is the right one. MG 14
R Weber DGV Advice Requested… TVR 19
Simmo TR6 Weber Carbs and Redline Air Cleaners Triumph 1
A Spitfire Weber Carburetor Triumph 0
rr64 Wanted WTB: Weber 45 DCO 3 Carburetor Air Horns Other British Classifieds 2
J For Sale Two used WEBER DGV 32/36 carbs for Triumph TR 2,3,4 Triumph Classifieds 0
pbraun For Sale Weber downdraft Carb & manifold Spridgets Classified 3
R For Sale Italian Triple Weber Set Triumph Classifieds 1
steveg Weber balancer on HD8s Austin Healey 11
H General Tech Tripple Weber Swan Neck Manifolds for Triumph? Triumph 1
G Triple Weber DCNFs on 280i V6? TVR 1
P For Sale Weber carb/intake, header Spridgets Classified 2
S For Sale Weber Conversion Kit for TR7 Triumph Classifieds 0
H Triple Weber 45's Tipp? Austin Healey 2
JFS TR2/3/3A Weber Air Filters Triumph 7
R Pedal box clearance mod for triple Weber clearance Austin Healey 7
S For Sale Triumph Weber DGV dual Carb Set Up - $325 Triumph Classifieds 0
richie TR4/4A TR3/TR4 Weber DCOE serious fitment issues Triumph 12
toysrrus TR6 Weber DCO45 cost? Triumph 6
T looking for simple Weber Wisdom, and angled air horns Spridgets 1
bugedd Weber intake manifold Spridgets 4
T Understanding Weber DCOE identifiers? Spridgets 0
T Problems disassembling a Weber side-draft DCOE Spridgets 2
T Identifying vintage of a Weber DCOE Spridgets 4
T Weber for a 1275 cc engine? Spridgets 6
M_Pied_Lourd TR2/3/3A Weber Carb Installation Question Triumph 13
drooartz Leaning out/tuning a Weber on a 1275 Spridgets 20
krswen Comparing Weber kits .... advice sought Jaguar 4
DanLewis Weber 40DCOE - Does it need a check valve in the fuel supply line? Spridgets 4
DanLewis Side draft Weber and smell of gasoline? Spridgets 3
bthompson What fuel pressure does a Weber DGV like? Spridgets 2
W Weber/stromberg air cleaners Jaguar 3
N Spitfire Weber Carburetor Upgrade - 77 Spitfire Triumph 9
B Weber DGV Spridgets 2
TomChar Weber MCHH carbs Triumph 23
