jvandyke
Okay, slowing working out bugs.
Today was annoyed to suddenly loose all ability to accelerate, pressing pedal = nothing. Pulled off onto shoulder to find the linkage at the Weber loose. Managed to tighten up enough to go about my business.
Have since found that the lever/bell crank that the throttle cable is hooked on has a round hole, not the "oval" shape of the throttle shaft. Isn't it usually shaped to fit the shaft? Or is the dimple on the lever supposed to be tight enough in the wheel?
See picture and see tell me what you think.
Could easily be it was just too loose and I just need to crank on it.
Weber Linkage
Weber Linkage
