AUSMHLY
Seems some water is getting into my heater box. (if correctly named, the long box under the dash that the hot air from the heater runs through).
I'm looking for areas where water is getting in the car after I wash it. Seems to be two areas:
1. Guessing that water leaks down the windshield wiper posts and drips off the cork screw area where the two shafts meet. The metal tube around the long shaft that comes from the motor is dry. Seems to be dripping from the cork screw area inside. The tube is cut open there and I can see the starting point for the drip.
2. Water is dripping at the corner of the heater box pull flap. (the small black spring flap on the bottom of the heater box). I removed the spring flap and felt inside with my finger. Yup, wet in there and where the drip was coming from. ??
Any ideas?
Besides don't let it get wet?
Roger
Any ideas?
Roger
Hi Guest!
