VERY LITTLE CRACK IN DASH - what to do?
RickB
I noticed a small hairline crack (1.5") in the front of the dash on the passenger side today. Is there anything I can do to fix this & make it so this doesn't get worse?
This is in my 78 Midget (Frank).
aeronca65t
Drill a small ( 1/16" ) hole at the each end of the crack. This will reduce the chance that it will "spread".
Then fill the crack with black RTV sealer and let it cure.
I've also seen folks fill these cracks with Bondo (body filler) that is dyed with a bit of black paint mixed in at the same time as the hardener.
The dash is off-gassing some of the oil and becoming more dry. You can slow down the "drying out" by keeping it in the shade and use a protectant spray. The common product is Armor-All but I think the "303" Protectant is better.
bugimike
I would agree that the "303" is better. I have heard that, with time, Armor-All actually promotes deterioration! I have not found it to really help when I used it, and it left a film on the surface rather than penetrating to restore the softness!
Mirror Glaze has a good vinyl cleaner conditioner.
If the crack gets too bad, there are dash caps available that are easy to install and looks nice.
terriphill
zimmy said:
Eagle one nano protectant smokes the other!
plus , no greasy feeling! .........z
Where do you find this? I hates armour all cause it leaves a film that actually evaporates onto the windows in the Arkansas Summer heat. My dash is beautiful, but I want to keep it that way.
I buy it by the Gallon and use it all my cars.
terriphill
Thanks guys, just placed my order! t:smile:
RickB
RickB
Thank you, this will help keep an almost perfect dash in great shape! I use Meguiars already for other stuff, just didn't know it came so highly recommended. I may already have a bottle of the vinyl conditioner.
Right now the crack is hairline, so I would have to use a syringe to inject rtv into it. Does someone have an idea where to get one that would work for this application? RTV is thick stuff to try to force through a needle...
C A very pretty little Elva MkVII Racing 1
M Red dash ignition light glowing very little Spridgets 16
D Very Nice 80% restored BT7 Austin Healey Classifieds 4
Phil73 TR6 VERY tight Tie Rod ends Triumph 1
S TR6 Very nice original one-owner TR6 for sale in South Carolina Triumph 0
Bayless The very simple rotisserie Spridgets 3
G TR4/4A Flasher Unit...VERY hot Triumph 10
R Very Difficult cold weather starting problems! Austin Healey 21
2billydavies TR2/3/3A very low oil pressure when TR3a is warmed up Triumph 12
F Check out this new restoration diary - BT7 - very brave! Austin Healey 7
longbridgehealey BN4 turn indicator blinking very slowly Austin Healey 2
steveg Very interesting very long blog posting - racing oil and zinc Austin Healey 44
drambuie The nasty boy Healey version may very well be more true to the original intent! Austin Healey 14
2billydavies TR2/3/3A very high idle, timing perfect Triumph 7
andrea Very strange austin healey 3.9 Austin Healey 5
P gearbox shifts very badly Austin Healey 7
T TR2/3/3A Air dam seems to be working very well Triumph 5
W Very respectable restoration Spridgets 9
RJS TR4/4A Clutch Fluid Very Dark After One Year Triumph 5
tinman58 TR5/TR250 Very stiff rear end Triumph 27
fpstude TR4/4A Another Wiper Question - Very Sluggish Triumph 12
bighealeysource Best way to remove very fine scratches in chrome windshield frame Restoration & Tools 2
bighealeysource Best way to remove very fine scratches in chrome windshield frame Austin Healey 1
bighealeysource Anyway to fix very slight dent in body without painting ? Restoration & Tools 7
B MGB 1972 MGB, Head Gasket replaced...runs very poorly. MG 30
drooartz MGB Sometimes I'm very proud of my work... MG 6
John Turney UPDATE: Up-date on a Very Expensive Healey Austin Healey 8
D BT7 Hard top back window that is very cloudy Austin Healey 5
NutmegCT Buying this will sure make someone *very* happy. Other Cars 14
B very excited! Just ordered my Ford Mustang 2013 GT Other Cars 1
pkmh HBJ8 Steering Wheel Repair Experiment - VERY GOOD. Austin Healey 7
tr7andtvr Very Disappointed with Lotus at Indy 500 Lotus 13
swift6 A very wild morning drive... Triumph 34
C One very cool Allard Other British Cars 2
RickB VERY OT - what I'm doing while on sick leave... Spridgets 10
JPSmit Very cool rat rod! Other Cars 3
C The Story of a Very Special Jaguar Racecar Jaguar 2
JPSmit Need a MOWOG and very confused Spridgets 13
C Very nice Triumph-Powered TVR 2200 Special Racing 9
J Anyone interested in very original 1958 Bugeye? Spridgets 1
RickB Needo to install a very loud horn - freeway 'fun' Spridgets 27
S Very clean 1970 Morris Minor Woody on eBay Other British Cars 6
V Very nice Jensen Healey on eBay Other British Cars 10
14dna Very Sad Sight Spotted 0
T very early gear wear Triumph 8
JPSmit very scary engine noise Spridgets 37
nissanite E-Type V12 very low oil pressure - new rebuild Jaguar 11
T Working with clean parts is soooo very nice Triumph 19
Steve1970 Very slow in first when letting up on the clutch Triumph 17
TR4nut TR2/3/3A Very brief status report and question on TR3A Triumph 26
