HighAltitudeTR3
I thought I would share what I did with my Vent because it had not worked since day one and the design of the whole vent system is not very efficient. The wire from the pull mechanism goes in to the lever that actuates the vent, problem is the wire doesn’t move enough to create a smooth transition from open to close.
The problem is solved easily and FREE! Drill a small hole just slightly larger than the diameter of the wire in the plate above where the vent wire usually attaches, bend the wire in a zigzag pattern in order to keep it from sliding out. Make sure not to make the wire too short or you won’t be able to close the vent.
Hope this helps someone out there!! My vent works with perfection every time!
