Valve lifters wrecked again!
Amphibian
First post here so please be gentle! Interesting problem for you. This is about my 998cc Sprite engine.
The valve clatter just got intolerable again. Pulled out a cam follower (lifter I believe to you guys over there). Same old problem. Face eroded and vertical score marks on the sides. This is 3,000 miles after the third rebuild in 13,000 miles. Cam is a new (or was) Kent 276, new Minispares followers, new cam bearings, lube used on assembly, broken in exactly as per Kent instructions. No spring binding, clearances exactly to spec (but now impossible to keep right of course). Rocker bushes checked and OK, geometry adjusted by shimming the pillars. Oil is Duckhams 20/50, and gives 60 psi hot with a 10-row cooler. What more can I do? I have gone through 3 cams so far. Never had any probs like this over the last 40 years with A-series lumps. /ubbthreads/images/graemlins/frown.gif
GB1
A few questions?
How much pressure are you running cold?
How do the cam journals look?
Are the valve springs upgraded?
Do the followers have oil holes drilled in them?
Patrick
spritenut
276 cam should have rockers set at .016, not .012.
Are the cam bearing oil journals lined up with the block borings?
1275 pushrods in a 998? They are taller.
healeyneil
For what its worth, there have been problems with cam followers in big Healey engines. Modern made stuff just not as good quality as originals it would seem
Alot of the low end lifters plain and simple are junk. Also if your Kent cam was a rigrind then chances are it is not hardened. See what Mini Spares has in a hardened (nitrited) regrind or go with a billet cam, then buy the best lifters or you chaps say tappets, either the MS lighten lifters ( they check out to about 57 Rockwell C) or the Chilled iron lifter, or source a set of APT lifters in California. Bottom line new stock lifters are junk, reground non hardened cams are junk, you need a hardened cam and lifters that spec close to the same Rockwell C. Since you are in the UK, I would buzz Kieth Calver, he'll put you on the right path to what parts to buy. Keith Calver and Peter May are both knowledgable buildiers in the UK and can source you the correct pieces and get you on the right path.
JerryB
""""""vertical score marks on the sides. """"""
in addition to the above sounds like you might have an oiling problem.
have you driven out those silly brass insert plugs in
the oil galleys and given the galleys the scrubbing?
Oil pump functioning well?
A
Amphibian
Thanks guys for all this. Answers as follows:
Lifters were not drilled. I've seen conflicting opinions on this point.
Oil gallery has been scrubbed to death!
Oil pressure is 65 psi cold, 55-60 hot.
Cam journals are fine - bit polished on the thrust side. Oil holes correctly lined up - the problem is with lobes not bearings.
I am using 1098 conrods.
Clearance always set to 0.016".
Don't know if Kent cams are hardened. I will ask them.
There is no coil binding - head was set up by local tuning shop and they looked up the correct springs (supposedly). Kent doesn't supply spring data other than which of their own springs to use.
The cam lobes were down about 3 thou, with one exhaust lobe down 5-6 thou so I have replaced the cam with a new one - Kent again. This was not exchange so presumably it wasn't a regrind - I'll check with supplier.
Have now fitted Isky type lifters from Minispares which are lighter and look much better made.
All going back together now.
jlaird
Keep us updated, a very intresting problem.
Unless Kent has changed, they use unhardened regrinds, which in my opinion is a recipe for failure. If you got a billet cam you will know it, by price alone. Nitrited regrinds work fine but most don't bother with this for profit reasons. For the street I'm pretty much plugged into using APT's billets and a few of his nitrited regrinds now, atleast I know I can trust David and his products.
jlaird
Hap, what should a GOOD street cam cost, ball park only please.
GB1
Jack:
My cam from APT cost $212 and the followers were $98.
Patrick
[ QUOTE ]
Jack:
Patrick
[/ QUOTE ]
That was a nitrited regrind then, which is fine, you can trust David to shoot you straight. The problem with the nitrited regrinds is you the grinder has to source cores, so this will become a thing of the past in the future. David and I had a good talk this week about this, he says he been getting alot of garbage in for cores which are costing him money because he can't use them, so in the future expect it to be billets only, which depending on the cost of stele will run you anywhere from $300-400, but you geting what you pay for, and always with the hardened or billet cams use a good set of lifters like the APT units.
Patrick, what you have should work wonderfully and you bought them just in time as David is getting ready to have a price increase if he hasn't already done it.
Platinum
I think I heard Jack pounding the telephone keys from HERE! /ubbthreads/images/graemlins/jester.gif
jlaird
Naa Doc. Jack is going to get everything up and running then work on a very warm street engine that looks stock on the outside.
GB1
Hap, thanks that is interesting. They charged me a $10 core charge and I told Phil it wasn't worth sending my core back for that price.
Patrick
A
Amphibian
Sorry folks, I keep forgetting to check back here. Thanks for all the advice. I have put it all back together now with a new Kent regrind (which I had already bought before hearing all the tales of woe about regrinds), and the Isky-type nitrided lifters from MiniSport. Fingers crossed! If it happens again obviously the only next step possible is a billet cam. But essentially the wear has been far worse on the lifters than the cam.
KVH TR4/4A Engine Question: The Valve Lifters Triumph 9
A TR6 tr6 valve lifters--which ones??? Triumph 21
sim looking for 2 valve spring kippers for a 948 Spridgets 3
R Valve Drain Pipe Austin Healey 13
R T-Series Valve gap for an MGTD 1953. MG 5
6 Valve Oil Seals Spridgets 10
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
P TVR Big Valve 4.3 TVR 0
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
J MGB BRAKE VALVE ? MG 11
jehuie PCV valve explanation? British Motor Corp 5
R 3000 Heater Valve Austin Healey 4
T TR2/3/3A valve springs Triumph 15
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
T TR2/3/3A valve guides and piston clearance Triumph 6
kodpkd Valve Cover Gasket - Don't do this! Austin Healey 14
KVH General Tech Heater control valve/cable Triumph 1
G Valve Train Lubrication Austin Healey 1
KVH General Tech Valve Timing--No Marks Triumph 20
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
D Water Valve Connection Austin Healey 4
R TR2/3/3A Rule 9 Valve Adjustment Triumph 8
RJS General TR Lever Shock - HD Shock Valve Triumph 2
JPSmit Product Review - air compressor drain valve. Harbor Freight Restoration & Tools 9
M TR5/TR250 Bypass valve Triumph 27
I Bugeye valve rebuild suggestions Spridgets 8
G Valve Cover Gasket Silicone Adhesive Austin Healey 5
J Oil Pressure Relief Valve Austin Healey 3
K TR2/3/3A An alternate valve adjusting sequence? Triumph 3
K TR2/3/3A Camshafts and Valve Settings Conundrum? Triumph 7
charlie74 TR6 ‘74 valve springs Triumph 0
Joel Lester TR2/3/3A What type of valve to use when rebuilding the head? Triumph 10
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
M TR6 PDWA valve Triumph 6
M Ray Juncal Valve Covers Austin Healey 5
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
BillyB62 TR2/3/3A Anyone seen a valve cover like this Triumph 0
alexisrexx TR6 Oil Sludge in Valve Cover - Normal? Triumph 16
K TR2/3/3A Brake Restrictor valve? Triumph 9
Lin Heater water valve question Spridgets 2
D MGB MBG valve clearance MG 1
K TR2/3/3A Finding valve lash with cam specs? Triumph 8
A T-Series MGTD oil pump bypass valve MG 0
S Price check on TR3A valve cover Triumph Classifieds 0
H BJ8 Heater Valve/Control Tap Austin Healey 3
J Wanted ZS 175 CD-2 Air Valve Triumph Classifieds 0
G Valve adjustment and easiest way set cam position Austin Healey 15
CharlesBN1 Uprated or 'umbrella' valve stem oil seals for BN1 Austin Healey 2
dbenichou289 TR2/3/3A Valve seats Triumph 8
steveg TR6 Adding a PCV valve Triumph 5
