My valve cover had a couple of small dings and some rust pitting, so after bead blasting, I've hammered out the dents from the inside, which of course leaves some minor finishing to do. "Metal to metal" body filler works great, and after sanding and priming with acid etch primer, the cover is in really nice shape, ready for the engine green paint from Moss. My question is whether the body filler and primer are ok in this relatively high heat area? Any ideas?
