Bret,
I think thay Andy is correct. I quote a reference from the following:
https://www.mgbmga.com/tech/mgb9.htm
Carb. control system (1969 onwards)
"With the introduction of this system, the front side plate
cover outlet was now connected to the "Y" fitting from which hoses are routed to each individual carburetor. These carburetor connections are positioned between the piston and the throttle disc. Gases are drawn from the crankcase via the depression in this chamber. Increased throttle disc openings along with increased depression in the chamber allows a greater volume of gases to be drawn into the inlet manifold. The oil filter cap, as mentioned in the previous paragraph, is retained and works on the same principle. In 1970 a non- vented oil cap was introduced with breathing now taking place through a charcoal canister. This system stayed in effect until 1974, and was retained for the Zenith Stromberg carburetor equipped vehicles (1975 onwards). A redesigned front side plate cover was introduced on 18V engines to provide better oil separation and drain-back."
Also Bob is correct about the restrictor hole in the pipe:
Quote:
https://www.mgbmga.com/tech/mgb3a.htm
11/06/01 VENTING PROBLEMS
"NOTE: The 1⁄2” hose restrictor which, may or may not be supplied with your kit, allows for adequate breathing on a well sealed engine. For engines that have above average “blow-by” conditions, the 1/16” hole diameter can be enlarged to the following: 5/64” 3/32” 7/64” or 1/8”. It should not be necessary to exceed 1/8”.
Obviously, the larger the hole within the restrictor, the more chance of oil transfer to the induction system.
We recommend installing the hose restrictor with the original 1/16” diameter hole first, then monitoring for excessive “blow-by” conditions. These conditions will be manifested by oil being blown out of several locations on the engine. These locations can be the oil dipstick tube, the oil filler cap or even the charcoal cannister.
Sometimes, we find it necessary to inform customers that the only alternative to keeping the oil transfer out of the induction system is : direct the breather hose to a suitable catch tank, then direct a hose to the lower extremities of the vehicle. Directing the hose in this manner removes the offensive “blow-by” smell. "
To sum it up, the normal vent air flow path is from the carbon can through a hose & restrictor hole to the valve cover, through the engine, out the front side plate, through a hose to the carb or carbs, suction. The restrictor hole should be from 1/16" to 1/8" diameter. No pcv is needed. Under very heavy load-blowby conditions where this normal ventilation is not adequate, part of the blowby reverses direction & goes out through the restricted vent & out into the canister.
You need a hose fitting on the cover with 1/16" internal restrictor going to the carbon can & a sealed filler cap.
