Value on an original BJ7 these days. ?? 38,000 miles
Jerry
A friend of mine has a line on a BJ7 that is original except for the paint job. So the engine bay, frame and other spots now are black where the outside is the gold color that got popular a few years ago. Body appears sound, the rest of the car is ok, looks line it is original. I am guessing that the range for the car is probably $18-29K? Any opinions?
Jerry
BJ8
TR3A
69 Mini
J
Jerry
I went to see the car today. Original, not much done to it. Engine has been painted orange so it has been out of the car. Originally Black but now Gold. Paint has rust showing through. Surface rust only on the frame. Interior and much of the Chrome needs work. It is restorable, now just calculating the cost to fix and what it is worth.
Jerry
Healey_Z
Does it start, stop, steer? All systems need going through? Driver or resurrection project?
p.s. is the car off of old auburn road?
HealeyRick
From your description, it sounds like it's not in as good shape as first described and actually needs quite a bit of work. More like a restoration project than a car ready to be driven. BJ7s don't command the same prices as the BJ8s It's a wild guess without seeing a picture, but I'd be thinking more like offering $10k Trouble is, a BJ7 will cost about the same to restore as a BJ8, so it's harder to come out ahead on a BJ7 restoration.
M Original Bugeye steering wheel value Spridgets 3
B Original Hardtop - Identification and Value Austin Healey 8
C Value of BN1 Original Front Drum Brakes? Austin Healey 4
Lin Oil sump torque value? Spridgets 3
Lin Water Pump torque value for nuts on studs Austin Healey 1
HealeyRick Gold Level Concours Value Austin Healey 20
Kleykamp Rubber bumper Midget value? Spridgets 5
K TR2/3/3A Value of a Complete Motor disassembled? Triumph 8
J 1963 Austin Healy "Sprite" Value Austin Healey 7
J MGB 1973 MGB Value MG 8
K TR4/4A TR4A clutch pressure plate to flywheel bolt "torque value"? Triumph 2
K TR2/3/3A Steering box drop arm Nut torque value? Triumph 0
K TR2/3/3A Steering box rocker shaft Nut torque value? Triumph 4
simon1966 Does taking a stock BN1 and adding M bits increase its value? Austin Healey 10
TR4nut TR6 Ballpark hardtop value? Anyone? Triumph 3
D 68 Sprite value - need help Austin Healey 9
TomMull GT6 More on value trends Triumph 12
Brinkerhoff TR6 value of a TR6 factory hardtop Triumph 5
GTP1960 TR2/3/3A the value of experience when setting timing on a modified engine Triumph 33
M The value in 5 speed conversion Spridgets 18
7 TR6 help with tr6 hardtop value Triumph 5
C Value of 100-4 heater box?? Austin Healey 2
J TR2/3/3A Dynamic timing value Triumph 5
Gliderman8 TR6 Opinions on value of this '76 TR6 Triumph 18
C Color change...impact on Value? Austin Healey 24
Mink TR4/4A Your thoughts/value of this TR4 Triumph 357
Jim_Stevens TR2/3/3A OD Transmission value Triumph 3
AngliaGT MGB '67 B - Value? MG 5
T 100-6 Longbridge value Austin Healey 5
2 GT6 69 GT6+ suggested value? Triumph 4
RickB MK1 Midge radiator value? Spridgets 2
apbos Works hardtop. The value of or cars is climbing! Spridgets 11
K TR2/3/3A Torque value for TR3 clutch cover to flywheel bolts....... Triumph 2
Brinkerhoff Market value for an unrestored BJ7 ? Austin Healey 17
K Value of an early Commission Number Triumph 5
N BT7 Restoration value advice Austin Healey 32
6 any value to this?? MG 2
TR4A_IRS TR4/4A TR4A long block value? Triumph 11
C BJ8 Smoothline top value Austin Healey 9
Marvin Gruber Looking at another 100 6- value? Austin Healey 16
R Fair Market Value Triumph 15
J Things that influence the value of a Spridget? Spridgets 18
K TR2/3/3A TR3 starter dog bolt torque value? Triumph 1
A T-Series MG TD Barn Find [sort of] value MG 1
Marvin Gruber TVR Value TVR 1
E MGB VALUE OF A EARLY 1963 MGB MG 4
Editor_Reid Value Premium for a Le Mans Kit-Equipped 100 Austin Healey 47
D daily driver value Austin Healey 21
J true value of a couple of books... Triumph 13
Got_All_4 Wedge Need opinion on TR7 value Triumph 3
