For Sale Used Armstrong Rear Shock Set; AH Sprite / MG Midget, 1958-70
TRopic6
Nice used set of Armstrong rear dampers for 58-70 AH Sprite / MG Midget (PN 8681 RH/LH). They move smoothly through full range with good resistance. However, the LH unit seems to have slightly less resistance and has a very slight 'soft' spot when lever direction is quickly reversed.
These are offered as cores, although the RH one could probably be used OK as is. The mounting holes are fine; not wallowed out from loose mounting bolts.
Please study the pictures to ensure they will fit your application. $25 or BO; includes
USPS Flat Rate shipping.
S TR2/3/3A used POR 15 for like a base primmer Triumph 8
D Used cars/parts Spridgets 6
BJ8Healeys For Sale Midget/Sprite nose section - used [Moss Motors P/N 455-145] Spridgets Classified 0
J For Sale Two used WEBER DGV 32/36 carbs for Triumph TR 2,3,4 Triumph Classifieds 0
S Wanted Looking for a new/used crankshaft for a 100-4 Austin Healey Classifieds 0
F Wanted Used leather interior for BT wanted Austin Healey Classifieds 5
dougie Big Healey Six - Used the Right Way Austin Healey 5
Ripper01 For Sale more TR-6 Used Parts Oct 2019 Triumph Classifieds 0
A Wanted '59 TR3A Clutch Master Cylinder - USED, RE-BUILDABLE, NOS Triumph Classifieds 4
T Finding Datsun 210 transmissions or other obscure used components Spridgets 1
Got_All_4 General TR Has anyone used these poly bushings Triumph 6
K For Sale TR3 Wheel spacers...Never Used...1/2 Price Triumph Classifieds 0
C What is this used for? Austin Healey 4
steveg Has anyone used a knock sensor? Austin Healey 0
Csarneson Rear Springs - Aftermarket or buy an old used pair Austin Healey 10
J Pre-War Steering box used in Pre-war? MG 6
2billydavies TR4/4A yellow blinker light stays on all the time the shuts off when blinkers are used Triumph 2
T MGB My '80 B used to shift fine MG 2
K TR2/3/3A Can a TR4A fuel gauge be used in a 3A? Triumph 8
floyd TR6 need of used carpet set Triumph 0
T TR4/4A Your procedure for checking out a new-used engine Triumph 6
pbraun Door pillar number used as VIN on title. What to do? Spridgets 11
RickB Any fiberglass one piece fronts available used or cheap? Spridgets 15
5 I used to own one of those Spridgets 6
T TR4/4A Has anyone used steel gear bushings in their TR4 transmission? Triumph 3
M Properties of wire used in harness? Spridgets 29
S TR2/3/3A used thermostat Triumph 5
G Filler metal used for tig welding ah aluminum shrouds Austin Healey 2
Boggsy64 MGB Used or Spare parts? MG 6
MY66AH Has anyone used this paint?? Spridgets 7
nevets used reverse with OD switch on Austin Healey 12
W Bought a used center console a while back..... Spridgets 6
Scotsman TR2/3/3A Should inner tubes be used with TR3 OEM steel wheels Triumph 3
floyd TR6 used tr6 carpet Triumph 0
J Need used starter post TS50000 Triumph 2
coldplugs Bricklin in a used car lot Spotted 0
Trevor Jessie Looking for used seat covers Spridgets 13
J Source for used front hubs? Triumph 3
PAUL161 What ar these used for? Restoration & Tools 9
regularman Anybody got any cheap used distributor parts Spridgets 8
S used parts where to sell? Triumph 9
K Anyone used Corraseal Rust Converter? Triumph 1
hondo402000 used wiring Harness, plugs wanted Triumph 15
I source for used 948 oil pan Spridgets 4
Nelson XS used gas tank Spridgets 0
M What is the alloy of steel used in the A-H body? Austin Healey 2
M What is the alloy of steel used in the A-H body? Austin Healey 4
L Anybody used.... Spridgets 9
jjbunn Used parts, battery cables, rocker switch etc. Jaguar 6
H New & Used Parts for triumphs- Miami, Florida Triumph 4
