Two Switches On Transmission?
jhorton3
I discovered 2 electrical switches on my transmission. One is on the driver's side and down in the tunnel if you looking down from the driver's seat and has 2 blade connections sticking out. The other is on the passenger side close to the top of the gear selector, and looks like the new brass brake switches. Which one of these is the reverse switch?
The one in the tunnel of the left side (drivers side) is for the seat belt warning light system, the one on the right rear of the shifter tower is the reverse switch.
Thanks for clearing that up. I had no idea that seat belt system was that involved. Can the reverse switch be swapped out for one of the new brass brake light switches? Mine has about 1/8" left of wire on one side, with the other completely gone.
71TR6 TR2/3/3A Switches on the top of an Overdrive Triumph 2
T Wanted PANTHER J72 or AUSTIN POLICE CAR switches Other British Classifieds 1
R TR2/3/3A OD Wiring from Switch to isolater switches. Triumph 6
C TR2/3/3A OD switches Triumph 12
adcronin For Sale MGB New Turn Signal Switches: 62-67 and 68-70 Also 70-73 MBB Steering column cover MG Classifieds 0
S TR2/3/3A bezels off the switches Triumph 5
Got_All_4 TR2/3/3A Overdrive switches Triumph 2
S Dashboard toggle switches for BJ8 - exact match? Austin Healey 12
wkilleffer MGB MGB brake light switches lately MG 1
wkilleffer MGB brake light switches of late Restoration & Tools 3
A TR2/3/3A TR-3A light switches Triumph 6
glemon Tech Tip, Wonky Switches Restoration & Tools 3
Tinkerman TR2/3/3A Continuity Check on Tranny Lock out switches Triumph 2
Tinkerman TR2/3/3A Tranny lock out switches Triumph 9
CJD TR2/3/3A Early Switches Triumph 2
O TR2/3/3A Dash Switches Removal Triumph 1
O TR2/3/3A Changing Ignition Switches Triumph 5
KVH TR4/4A TR4 Overdrive Switches--Top Cover Triumph 8
robdmau New to a Sprite, dash switches... Spridgets 9
W Cleaning Switches Triumph 15
J Spitfire Early Spitfire headlight switches Triumph 4
I Source for broken Bugeye heater cable/switches? Spridgets 2
Moseso A Tale of Two Switches Triumph 10
hondo402000 TR6 TR6 New door switches Triumph 1
hondo402000 TR6 TR6 Door Switches Triumph 19
M TR6 tr4-tr6 door switches Triumph 3
Ofcalipka Where can I obtain dash lights and switches from. Spridgets 18
newmexTR3 Period switches / light relay Triumph 6
C TR6 TR6 Hazard Switches Triumph 2
B Dashboard Switches Light Brackets?? Spridgets 1
M Restoring Switches Triumph 6
jvandyke headlight operation switches functions Spridgets 21
M Hydraulic brake light switches Jaguar 2
MadRiver Lucas Hazard Switches Triumph 6
G chrome switches? Spridgets 1
ronzet T-Series Those little chrome nuts on the switches MG 5
Jack_Long Dumb question about headlight switches Spridgets 7
S Gearbox Switches on Non-Overdrive Unit Triumph 5
B Brake Light Switches Spridgets 2
H What Do These Switches Turn On? Austin Healey 3
H What Do These Switches Turn On? Austin Healey 1
Michael Oritt Switches and fuses Racing 13
M Toggle Switches Spridgets 11
RobSelina battery kill switches Racing 21
L T-Series switches??? MG 12
L T-Series Early toggle switches MG 1
A T-Series Brake Light Switches MG 1
A Spitfire Transmission Help Triumph 1
mctriumph Wanted Tr 3/Tr6 transmission kit interest Triumph Classifieds 10
G TR6 TR-6 Engine and transmission. Triumph 6
