apbos
I am going nuts on this one. I need to get these going so I can go to the DMV and get the car on the road.
https://www.dinoplex.org/sprite/Sprit... Diagram.pdf
So using a new wiring harness for Moss and I have a positive ground car with a fiberglass bonnet. I have headlights (high and Low), dash lights, parking lights and rear tail lights and brake lights and the plate lamp is working! I have checked my signal switch and have a new flasher. When I add a wire from the negative post to the green/red wire (18) left beehive flasher lamp (when it is screwed into the car) I have light. When I hot wire the right beehive (green/white) (21) when it is screwed into the body no light. When I REMOVE THE SCREWS it will burn brightly.
Is this an indication that my ground from my RH flasher is not working? Does it indicate that I am totally inept and should go crawl back into a deep hole and cry out to the prince of darkness
and curse him for even existing?
Thanks for your help guys. It is 100 degrees in the garage and I would rather be driving.
Paul
and curse him for even existing?Thanks for your help guys. It is 100 degrees in the garage and I would rather be driving.
Paul
Hi Guest!
Scott hit it on the head. I cleaned up the flasher ground bolt again and it still did not work. At that time I noticed my headlights were starting to dim ( just like me). Hooked the battery charger and Bob's you uncle
