Trickle charger thread for Dale & Don
tdskip
Have it it guys...
(for the record - I use them heavily. Slow charge is my preference since they seem to be easier on the battery, but I don't have empirical evidence on that).
T
Tinster
Man, I am so confused, I can't stand it.
We drive Wendy's Jeep almost every day, I drive my
own Jeep almost every day,the Triumph TR6 about every
other day and use my fishing boat maybe twice a week.
I disconnect the boat battery after every use.
All three are are about 800 to 850 cranking amps.
What purpose does the trickle charger make?
confused,
dale
DNK
For us folks in the frozen north where our cars sit for 3-4 months.
Brosky
Dale, as Don says, if we could drive these things every day, we wouldn't need chargers.
And half of the threads on this forum would not be here. The biggest problems are when these cars sit too long. The more you drive them the better.
I know that you may find that hard to believe, but it's the truth. That and not tinkering toooooo much.
DNK
Then we wouldn't have anything to talk about.
Brosky
Well, we could talk about you torturing your poor cat with the lime skins, but that would make the SPCA mad, so we'll let that one go by.
Opa
this is what i've been using.Seems to work pretty well. $35.00 up here in Canada.
dklawson
On our cars that sit, I have... Harbor Freight specials. They are cheap and they work. With all trickle and float chargers though you really need to look at the fluid level in the cells perhaps every month or so. The electrolyte level will go down over time.
T
Tinster
So OK- Amos is almost a daily driver , except when it rains,.
Do I need to hook up a trickle cell charger?
thanks,
dale
Brosky
Dale, no you do not.
Doug & Casey,
Remember that I have an Optima battery and need to be careful with which charger I use. This will work for mine and all others, but other chargers may not be good for my Optima battery.
Opa
yer right on Paul....but for those with standard battery,nothing to fancy is required.Just be sure it has the auto shut off/start up feature to keep from over charging.
Dale up here in the great white north, my TR usually sits in the garage from Nov to about late April.
myspitfire
Hi Dale;...As i always have said no man is(on) an island....My stint in the service at Ramey AFB,I always worried about bad PR RUM :nonono: & Cameleons :cz,NEVER about charging MY BATTERY ;-)Thats one of the reasons i named my Triumph 'WhiteLightning'It runs well on 20% alcohol. :cheers:
T
Tinster
Opa- and here in the tropics- my car is usually on jackstands, broken down and
being repaired from late April until November. I guess it evens out.
I spent an enjoyable year designing hurricane upgrades for
the old Ramey air base. The fighter plane excort pads are
still very visible.
enjoy,
dale
dklawson
Brosky said:
Doug & Casey,
Sorry, didn't mean to imply that you should use what I'm using. I only suggested the HF float chargers for those who have more traditional batteries and want to keep them in shape with a smaller investment. I have been pleasantly pleased with the HF float charger... some of their stuff is absolute junk you know.
I recommendations for trickle charger? Spridgets 5
AUSMHLY Trickle charger vs. battery tender Austin Healey 13
X Mity mite battery trickle charger MG 9
X Trickle Battery Charger MG 12
KVH General Tech Trickle Chargers Triumph 13
R Trickle chargers MG 2
tinman58 TR2/3/3A Need super charger!! Triumph 7
AngliaGT Subaru XT,'68 Charger Spotted 0
NutmegCT Car batteries and charger Restoration & Tools 6
M TR2/3/3A Phone charger & Radio can I put these in my car??? Triumph 7
G BATTERY CHARGER/MAINTAINER Austin Healey 5
tinman58 TR2/3/3A Super charger TR3 Triumph 21
tinman58 TR2/3/3A super charger TR3 Triumph 43
Tabcon TR4/4A Triumph TR4 T3T4 Turbo Charger Kit Triumph 3
coldplugs Strange battery charger behavior Restoration & Tools 7
Steve Dodge Charger Other Cars 0
X Battery Charger MG 2
78MGB MGB Boat Battery Charger For The MGB??? MG 8
N TR6 TR6 Super Charger? Triumph 5
Jkirchner Rocker Pedestal Banjo Bolt Thread Size Austin Healey 10
CARSINC Spark plug thread size Spridgets 2
J Next Thread? FORUM Navigation Questions 1
L Little1's 75 Midget 1500 Thread Spridgets 14
tr6nitjulius General TR Plenty thread left on my old OEM 185 Redlines Triumph 5
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
NutmegCT Change amount of posts shown in a thread. FORUM Navigation Questions 0
BoyRacer Thread Pitch Gauge from "British Tool and Fasteners" Austin Healey 0
C My 2500M progress/questions thread TVR 5
JFS Wedge Stripped gearbox filler hole thread Triumph 3
71TR6 TR2/3/3A TR3 windscreen frame corner bracket screw thread Triumph 9
charlie74 Wanted Thread restorer kit Triumph Classifieds 0
1 TR2/3/3A TR3 Fuel Pump Thread Type? Triumph 4
R TR6 Clutch Master Cylinder Hydraulic Line (Thread / Flare Type) Triumph 4
Geo Hahn TR6 TR6 Oil Line Thread Size Triumph 1
dbenichou289 TR2/3/3A Another exhausting thread Triumph 10
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
J TR2/3/3A such strange thread on gear shift knob Triumph 12
J Thread Locker on Shock Bolts? Austin Healey 19
PAUL161 T-Series MGT Exhaust Stud Thread Size MG 2
T TR2/3/3A Can someone confirm size and thread count on fuel line tube nuts [brass fittings]? Triumph 16
M TR2/3/3A Transmission Removal Tool Thread Triumph 2
S TR2/3/3A The big brass drain plug on the OD does not thread in easily Triumph 9
JPSmit Spridget thread question FORUM Navigation Questions 2
S Fan blade bolts - torque setting and thread-locker? Austin Healey 4
B TR6 Boot lid thread plates loose in stiffener Triumph 1
Jim_Stevens TR2/3/3A Rear bumper bolts size/thread? Triumph 3
Editor_Reid Parts List Thread Now "Sticky" - parked at the top of this list of subjects Austin Healey 0
Boink Rolls-Royce head replacement thread... Other British Cars 0
TulsaFred aluminum BE radiators on ebay, drain plug thread? Spridgets 12
