Tinkerman
I have started taking apart the TR4 tranny that the PO purchased because it is syncromesh and I have the overdrive for it.
I was doing just fine until I came to the center mainshaft bearing. Part # 58391 StanPart Book page 27 item L3. I am following the dis-assembly steps in Nelson Riedel's article. He shows a tool that he made up to do the job. I was wondering if anyone out there has done this and how did you get that bearing out.
As I see it there are several ways to do it.
1. Might be able to use a split bearing puller
2. Could use a big hammer and bang the shaft in(really don't like that one)
3. Use a jig of the type he made and push the shaft through the bearing until it gets to a smaller diameter on the shaft.
#3 has the most appeal to me because you are using slowly applied force and not flaying away with a 3 lb sledge.
So what ideas are out there? Better yet does anyone have a jig I might borrow or buy?
Thanks, Tinkerman
Thanks, Tinkerman
