Trying to get most of the wiring working in my TR6.I find that the purple wires in my car seem to only have power when the ignition is in the on position.In checking at the fuse box the brown incoming to the fuse box(which passes thru the fuse to purple) seems to be switched with the key.Since this powers circuits such as hazards, horn and interior lights I assume these circuits should not switched.Doesn't make sense to have to put the key on to have the light go on when you open the door or to turn on flashers or beep the horn.Have checked the wiring diagram but the brown wire has so many interconections on its way to the fuse box that it is nearly impossible to figure out.Do others out there have power to the purple wires without the ignition on?(ie.do the passenger compartment lights or gove box lights operate without the key in the igmition?Thanks
