I finally got my windsheild in and took it on my first adventure on the freeway - what a rush! The only downside was my turn indicator is suddenly not working. I checked the bulbs and connections. I had an extra flasher unit on the passenger side that I swapped and still nothing. The emergency flashers work. All the lights, including the brakes. The turn signal switch would not return (wearing out?) before this, but it would at least do the job. Is there a way to test the switch? If so, how do I test it? Is there anything else I could check?
Thanks, Kevin
Thanks, Kevin
