TR6 TR6 Tail light refurbishing
mrv8q
I'll leave it to Paul for the fancy, comprehensive web page, but here's a couple shots of my "down and not-so-dirty" tail light cleaning. I'm continually amazed what a little Simple Green, plastic polish, and 0000 steel wool will accomplish!
I wound up painting the plastic reflector (on the right) in silver, and polishing the metal reflector (on the left) with the steel wool. The painted reflector side had faded to the base greyish green plastic.
Here's a pic of the undone side:
Here's the finished side: Inner and outer gaskets sourced from TRF:
I await Paul's page!
T
Tinster
It makes a great difference, doesn't it?
Did you have any problems reinstalling the light
bulb sockets? My socket holes were so beat up,
I could not get a decent ground. I ended up hard wiring
ground wires to all the rear bulb sockets and then
attaching them to grounding blocks.
looking schweet!!
d
trrdster2000
Good job Kevin, did you get the new sockets with a ground of do your own. The lens look great, did you do your buffing or are they new. Dale had the right idea, add a ground, check out the forum list on how to, I have one in there somewhere, or I can send it to you.
Wayne
Brosky
Hey Kevin, great job!
I just got my tail lights back in the car, I'm not taking them out for a long while if I can help it.
Which plastic polish did you use?
mrv8q
mrv8q
Brosky said:
Kevin, what happened to your bumper?
Paul, I hate to say I took it off in January(!), to pull off the black rubber bumpers.
I fully intended to get a random orbital polisher to start detailing the sad paint; with the bumpers off, I'd have more real estate to polish. Fast forward 11 month, and no RO polisher; perhaps Santa will stop by Griot's Garage....
Between work and family, it's scary how fast time flies...
I think I used a Meguiar's plastic polish, couldn't find it when I went to look. Happily, I've had no ground problems w/ the taillights. I gave them a good scrub with the steel wool, but they worked OK before. Thanks for the inquiries....
Brosky
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]it's scary how fast time flies...[/QUOTE]
Wait until you hit your 50's.....
trrdster2000
Paul, I tried a couple of different glazes on the lens and the best I could fine was the 3M final glaze. The stick polish was way to harsh. Now I have some #3 from Griots and I bet it's better.
Wayne
martx-5
Nice job! Looks brand new. :thumbsup:
gardener
another to the "list to do when "miracle" arrive, there is another thing, but this is for the paint, is a kind of a pink clay, you rub the car with it while the car is wet, and when you feel the paint, is very smooth, I'll check the name of this clay, and tell you later.
Brosky
Gardner,
That is a Clay Bar and it is used in conjunction with a liquid cleaning compound. you don't want to use that only with water and the paint must be clean of any dirt prior to it's use.
gardener
I can't tell you for sure, but I used it on all my others car just with water only and the paint feel much better, I used it after I wash the car.
Brosky
Oh, it will work, but it works best when used with a cleaner to remove dead pigment and that helps prep the bare paint for a good waxing. Even a soapy water (mild car wash soap) mix would be better than plain water.
I TR6 TR6- water leaking through tail lights Triumph 4
P TR6 TR6 Tail lamp Assy Triumph 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
R TR6 TR6 Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
A For Sale 1974 TR6 Triumph Classifieds 1
EWD For Sale ‘74 TR6 original wheel trim rings Triumph Classifieds 3
EWD For Sale ‘74 TR6 original radio Triumph Classifieds 0
EWD For Sale ‘74 TR6 original starter Triumph Classifieds 0
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
JPSmit TR6 at lunch today Spotted 0
E Wanted looking for a tr6 bell housing Triumph Classifieds 12
jfarris For Sale TR6 Yellow Fan - new Triumph Classifieds 0
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
charlie74 ‘74 1/2+ TR6 Spotted 0
E TR6 TR6 flip-up bonnet question Triumph 4
Marvin Gruber For Sale 1974 TR6 for sale, $7200 Triumph Classifieds 3
T TR6 TR6 Tire Pressures Triumph 2
