TR6 TR6 rear lights?
kodanja
Ok, well I took the 6 out today to a show all went well, even got me home. /ubbthreads/images/graemlins/yesnod.gif
But when I looked at my rear running lights they were not working... /ubbthreads/images/graemlins/nonono.gif
The side rear lights worked, so I checked the fuses they were all ok.
I checked the bulbs "ok"
I'm not sure what to do next, any suggestion?
thanx so much!!
/ubbthreads/images/graemlins/england.gif
R6MGS
Check the grounds...They might be weak as they're in an area prone to corrosion.
kodanja
kodanja
ill do that next, thanx!
should I clean the prongs, or just trash the sockets and go with a common ground? /ubbthreads/images/graemlins/hammer.gif
DougF
Clean everything. The sockets, bulbs, lamp chassis, quick slide connectors. This is the area where I have had my worst electrical problems. I got pulled over last summer by a local policeman because my tail lights were too dim. With these young pups who know nothing but LED, I'm sure we will be experiencing these things more often in the future.
R6MGS
Yup, When I got mine I had to repair one of the truck panels, with that removed I decided to clean up the lighting connections on the one side....I was amazed that they were still functioning with all the crud back there. Now I've got to do the other side........
kodanja
kodanja
so you think just by cleaning the connections and bulbs this may solve the problem.?
It was kinda strange that they went all at once. Hmmmmmm...
Brosky
Welcome to the playground of the Prince of Darkness.
DougF
I would clean the contacts inside the sockets and the tail light frame where the light sockets attach. When finished, a little dialectric grease to prevent further corrosion couldn't hurt. And of course, clean all of the electrical connections.
Andrew Mace
[ QUOTE ]
[/ QUOTE ]It's fairly likely.
[ QUOTE ]
[/ QUOTE ]That might possibly indicate a grounding problem...something to double-check while you're cleaning the connections and bulbs! /ubbthreads/images/graemlins/grin.gif
MrPandy
I ended up soldering a new ground wire onto each tail light socket to get all of mine nice and bright - actually, just to get them working.
kodanja
kodanja
I think I'll set up the new sockets with a common ground, I purchased new sockets with an extra grounding tab.
thanks for everyones input !
kodanja
kodanja
Well so far i cleaned the prongs, that helped, the running lights work now /ubbthreads/images/graemlins/yesnod.gif but only one of the brake lights work now. /ubbthreads/images/graemlins/nonono.gif..and the other running light goes off when i step on the brake... Hmmm /ubbthreads/images/graemlins/nopity.gif
I checked the bulb "ok" i checked the ground "ok" I also checked to see that the wires were on the correct connections,
Sounds like a job by "Mr. Lucus" /ubbthreads/images/graemlins/england.gif
any input.... /ubbthreads/images/graemlins/grouphug.gif Thanx! /ubbthreads/images/graemlins/driving.gif
swift6
How is your license plate light? I had a ground issue with mine and it affected all of the rear lights. Especially the passenger side rear. All part of the same circuit.
R6MGS
I still say a bad ground somewhere....I had almost the exact some problem with the Caddy....spent Christmas day in the truck cleaning and re-cleaning every single connection.
kodanja
kodanja
ill have to check the wires for the licence plate light, along with cleaning all the other connections,
thanx, Ill let ya know...
G
It's a bit of a hassle and a small expense but the rear harness for your car should be available from British Wiring. You have to consider that this harness runs along the floorboard and through the trunk and can often get worn or shorted over the years. It is not that difficult to run new wires and you will know what you have. The sad truth is all of the sockets that you buy now as replacements are of questionable quality (not sure that the Lucas originals were all that great) and getting a bulb in and out of these little jewels can be tricky. I usually keep spares of everything on hand, especially bulbs. The weakest link in all the braking lights is the darn brake light switch. These things are a nightmare to adjust properly and will fail at all the wrong times. I have half a dozen in my spares box.
Bill
kodanja
kodanja
do you think the brake switch could be the culprit?
If I have to I will replace the rear harness, but only at last resort.... /ubbthreads/images/graemlins/hammer.gif
G
[ QUOTE ]
[/ QUOTE ]
The brake light switch pretty much only controls the brake lights but getting less than a "full load" on a circuit when needed is never good. Try unplugging the two wires to the brake light switch and run some extensions to the rear of the car so you can check them in an off/on situation. The downside to doing anything like this (playing with circuits with the ignition on for a period of time) with electronic ignition is you will burn the module out in short order (Pertronix, Crane). (Unless of course you unplug the ignition) Another issue with the running, tail, brake lights is you will never get full brightness unless you have the engine running and charging the battery, unless you have a really fresh, killer battery. One of the reasons I switched over to a Delco-style 66 amp alternator, weak lights. Now they burn brightly.
Bill
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 14
M For sale rear wings Tr6 Triumph Classifieds 3
M Have a pair of tr6 rear wings Triumph Classifieds 0
M Wanted TR6 Rear Bumper impact Brackets Triumph Classifieds 0
E TR6 74 TR6 - Rear and windshield frame color Triumph 2
E TR6 Rear Transmission Seal 74 TR6 Triumph 4
Got_All_4 TR6 drill and tap for a grease fitting tr6 rear hub assembly Triumph 4
J TR6 1973 TR6 Rear Brake Operation Questions Triumph 4
T TR6 TR6 Rear Bumper Bar Triumph 1
Got_All_4 TR6 Rear Bumper removal 1970 TR6 Triumph 3
T Wanted TR6 rear trailing arms Triumph Classifieds 1
M TR6 TR6 rear bumper Triumph 0
cmacmillan TR6 Rear bumper removal - TR6 Triumph 10
GBRandy TR6 1973 TR6 Rear Frame / Body Bushings Triumph 3
T TR4/4A Under the been there - done that school of learning: TR6 rear springs on a TR4a Triumph 12
T TR6 TR6 aftermarket rear shocks Triumph 35
W TR6 tr6 rear hubs Triumph 3
F TR6 TR6 HARDTOP GLASS [rear] Triumph 7
D TR6 76 TR6 Rear Brake Installation Triumph 17
hondo402000 TR6 New rear wheel cylinder leaking, TR6 Triumph 0
D TR6 76 TR6 Rear Right Brake Line Triumph 8
J TR6 rebuilding tr6 rear hubs Triumph 13
T TR6 Passenger side TR6 rear clunk? Triumph 9
W TR6 broken bleeder on rear brakes tr6 Triumph 6
S TR6 tr6 rear shock part number ??? Triumph 5
Coyote1 TR6 TR6 Rear Springs ? Triumph 11
Pete_Chadwell TR6 TR6 Rear Hub question, plus gearbox vibe Triumph 8
O TR6 TR6 Rear Valance ID Triumph 1
TR6oldtimer TR6 TR6 windscreen and rear flat black Triumph 4
SherpaPilot TR6 TR6 Rear Axle Bearing Question Triumph 10
B TR6 TR6 rear axle oil change Triumph 21
T TR6 Anyone use TR6 rear springs in their TR4a IRS? Triumph 8
glemon TR6 TR250 TR6 Rear Springs Triumph 13
S TR6 Rear suspension TR6 Triumph 8
hondo402000 TR6 NEEDED rear light socket TR6 for reverse lamp Triumph 10
hondo402000 TR6 TR6 Rear Paint, Satin Black Triumph 8
hondo402000 TR6 TR6 rear body Black paint help Triumph 9
B TR6 Rear-ended today and my beautiful TR6 is smashed.. Triumph 18
T TR6 TR6 rear sway bar question Triumph 6
I TR6 TR6 rear hub and trailing arm spares advice Triumph 2
T TR6 Is this a TR6 rear sway bar? Triumph 10
B TR6 Removal and Replacement of TR6 rear deck Triumph 3
T TR6 tr6 rear noise Triumph 8
I TR6 Rear brake drum temperature TR6 Triumph 13
I TR6 Rear wheel bearing help TR6 Triumph 6
I TR6 TR6 rear axle u-joint removal help Triumph 14
I TR6 What type of oil for TR6 rear shocks? Triumph 2
A TR6 TR6 Front lower wishbone mount [rear] broken Triumph 1
I TR6 TR6 rear camber help Triumph 16
hondo402000 TR6 TR6 rear brake rebuild Triumph 10
