TR6 TR6 rear body Black paint help
hondo402000
As you guys know I am getting closer to painting my TR6, My question is about the black on the rear of the body, What do I use? should it be a flat urethane with a satin clear, how about black with clear and wet sanded with 3000 to dull it? should I paint the complete car with my base coat then clear coat then scuff the rear and paint the flat black? The guy at the paint store said that would work and it would protect the body better since flat paint are not very durable,
Suggestion would be appreciated
Hondo
Brosky
The body shop painted mine with matte black and masked it off before the clear went on the car.
Tim Tucker
Platinum
I too am in the process of stripping my car for a re-paint. I had this saved for the rear paint. It comes from the Cape Cod British Car Club; TR6 Reference Document. Good Luck.
Tim
"Black paint for rear section of TR6 - "Euro Black" semi-gloss black. Early ‘70's “Boss 302” Mustangs used a similar product. Original paint code given by Triumph for the black paint to the rear panel in one of their early newsletters was ICI paint reference 062/4253. Current practice is to use a satin black rather than the matte black used by Triumph when the cars were built. Try your local NAPA and ask for Martin Senour 7244 black trim paint. It is a large spray can with a quality nozzle that dries to a nice matte black finish. And for what it's worth, they also have black chassis paint, #7243, in the same large style spray cans."
TR6oldtimer
I have just finished the color and clear coating of the rear of my tub. The color and clear went over everything. When the time comes I will mask and scuff the area for the matte black. Probably PPG urethane matte black...
Brosky
Ideally, Ray's method is probably best if you are painting the entire tub or car.
TR6BILL
All you need is a rattle can of Krylon Semi-Flat Black spray paint. Perfect color for you Kamm back, and Krylon is a quality paint.
conan69
Member
Dupont HOT ROD BLACK single stage paint, Won't turn chalky in the sun. Which is all we seem have in Fresno. [Wishing for rain]Hot Rod Black is not to flat, not to shiney, easy to spray.
kodanja
heres another option'
rooster
Hondo,
A word of caution...
If you are using waterborn paint on the car you need to be carefull about doing two tone. The waterborn stuff needs to be cleared before applying any masking. If you mask directly on the waterborn without a clear coat on it, the waterborn will peel off when you remove the masking, and you will have a mess to clean up. :cryin:
This has happend to me, :wall: and also to few other people including a guy with 40 years experience in the autobody trade.
The way I'd do it, is once the car is fully painted and clear coated, mask off the area you want to blacken and then polish it with a coarse buffing compound to remove the shine, and then spray on some quality "trim black" as suggested by the guys above.
Hope this helps
Todd
GBRandy TR6 1973 TR6 Rear Frame / Body Bushings Triumph 3
TR6oldtimer TR6 TR6 rear body shims [under trunk] what is ok? Triumph 2
S TR6 1974 TR6 Rear Brakes w/o hydr. press. Triumph 6
R For Sale TR6 REAR AXLE HUBS Triumph Classifieds 0
R For Sale TR6 REAR DIFFERENTIAL Triumph Classifieds 3
edkap2002 TR6 TR6 rear pinion seal Triumph 3
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
mctriumph For sale rear wings Tr6 Triumph Classifieds 3
mctriumph Have a pair of tr6 rear wings Triumph Classifieds 0
EWD TR6 74 TR6 - Rear and windshield frame color Triumph 2
EWD TR6 Rear Transmission Seal 74 TR6 Triumph 4
Got_All_4 TR6 drill and tap for a grease fitting tr6 rear hub assembly Triumph 4
J TR6 1973 TR6 Rear Brake Operation Questions Triumph 4
T TR6 TR6 Rear Bumper Bar Triumph 1
Got_All_4 TR6 Rear Bumper removal 1970 TR6 Triumph 3
T Wanted TR6 rear trailing arms Triumph Classifieds 1
M TR6 TR6 rear bumper Triumph 0
cmacmillan TR6 Rear bumper removal - TR6 Triumph 10
T TR4/4A Under the been there - done that school of learning: TR6 rear springs on a TR4a Triumph 12
T TR6 TR6 aftermarket rear shocks Triumph 35
W TR6 tr6 rear hubs Triumph 3
F TR6 TR6 HARDTOP GLASS [rear] Triumph 7
D TR6 76 TR6 Rear Brake Installation Triumph 17
hondo402000 TR6 New rear wheel cylinder leaking, TR6 Triumph 0
D TR6 76 TR6 Rear Right Brake Line Triumph 8
J TR6 rebuilding tr6 rear hubs Triumph 13
T TR6 Passenger side TR6 rear clunk? Triumph 9
W TR6 broken bleeder on rear brakes tr6 Triumph 12
S TR6 tr6 rear shock part number ??? Triumph 5
Coyote1 TR6 TR6 Rear Springs ? Triumph 11
Pete_Chadwell TR6 TR6 Rear Hub question, plus gearbox vibe Triumph 8
O TR6 TR6 Rear Valance ID Triumph 1
TR6oldtimer TR6 TR6 windscreen and rear flat black Triumph 4
SherpaPilot TR6 TR6 Rear Axle Bearing Question Triumph 10
B TR6 TR6 rear axle oil change Triumph 21
T TR6 Anyone use TR6 rear springs in their TR4a IRS? Triumph 8
glemon TR6 TR250 TR6 Rear Springs Triumph 13
S TR6 Rear suspension TR6 Triumph 8
hondo402000 TR6 NEEDED rear light socket TR6 for reverse lamp Triumph 10
hondo402000 TR6 TR6 Rear Paint, Satin Black Triumph 8
B TR6 Rear-ended today and my beautiful TR6 is smashed.. Triumph 18
T TR6 TR6 rear sway bar question Triumph 6
I TR6 TR6 rear hub and trailing arm spares advice Triumph 2
T TR6 Is this a TR6 rear sway bar? Triumph 10
B TR6 Removal and Replacement of TR6 rear deck Triumph 3
T TR6 tr6 rear noise Triumph 8
I TR6 Rear brake drum temperature TR6 Triumph 13
I TR6 Rear wheel bearing help TR6 Triumph 6
I TR6 TR6 rear axle u-joint removal help Triumph 14
