I am replacing the four rear u-joints on my 69 TR6. It is normally a simple process for me to remove a u-joint. I remove the retaining clips, support the opposite side, and use a small socket to push the u-joint to the other side. I remove the cap and simply pull out the u-joint. The problem I am running into is when I push it in as far as it will go, there does not seem to be enough room to push either cap out. I am baffled as to what I am doing wrong. Any tips on what I am doing wrong? Any tips would greatly be appreciated.
Kevin
Kevin
