TR6 TR6 Fuel gauge help
ichthos
Hello,
My car has been sitting since mid October and I finally had some nice weather to pull it out of the garage, put the dash back together, and start it up. I have not hooked up the tachometer or installed the glove box yet because I need access to the windsheild wiper areas under the dash. All the gauges seem to work except for the fuel gauge. I cleaned the connections at the tank and gauge. Just to be sure it was not the gauge, I hooked up a spare fuel gauge, and it did not work either. Both gauges showed my tank a little less than 3/4 full even when the tank was topped off in October. Could it just be a matter of the sending unit having a leak in the float? I had planned on pulling the tank and taking a look at the sending unit this summer, but I just want to have a little fun for now. Is there a way to check the sending unit without pulling the tank? Do you have any other ideas on what I should check? If it a matter of grounding still, where else should I check? Other ideas? Any suggestions would greatly be appreciated.
Kevin
TRopic6
Kevin,
The sending unit's resisance varies as the float arm moves from full to empty. You can hook an ohmmeter across the two sender terminals and pull the float arm up (and push down, although that's much trickier!) I used a coathanger wire and a flashlight. Hint - it's easier at night. I think it should vary from about 25 ohms (for full...I think) to 280 ohms.
My car sat for 10 years and I had to dismantle the sender and clean the inner connections. It's pretty straightforward.
Jeff
CF13816U
2wrench
Read a thread on the forum about two gauges acting up
at the same time: Both Gas and temperature. Guys had some
success in correcting their problems by replacing
the voltage stabilizer. (Messes up the gauges if bad).
I am just quoting to you what I made note of. I have
not personally done this repair. Found and reviewed the
thread to assure my info per their post is accurate.
Something to consider.
TexasKnucklehead
My 74 TR6 sending unit reads as follows (with an ohm meter):
0 ohms = full
52 ohms = half
128 ohms = 1/4
I didn't run it out of gas to get another reading, but the gauge functions fine. I only measured it because I'm trying to figure out why my TR3 sending unit does not work with a TR4 fuel gauge. The TR3 sending unit seems to be wired on the opposite end of the wiper, with a different resistance. I'm still trying to figure it out...
You can short the wire at the sender to ground, and the meter should show full. The tank and meter should both have good grounds.
TR674
Kevin
thought I would throw my 2 cents worth in.
I recently took my speedo out to get it serviced. I drove the car a few times with the speedo out, and neither the fuel or temp gauge worked. Once I re-installed the speedo all was working well. I'm not sure if the taco has the same effect, but try reinstalling it and start the car to see if this fixes the problem. Just a suggestion, as I'm pretty much electrically illiterate.
Regards
Craig
dklawson
If it's just the fuel gauge and the temperature gauge (presuming it's electric) is acting normally, focus on the fuel gauge, its wiring, and the sender. Normal temperature gauge operation implies that the voltage stabilizer is OK.
Since the gauge is reading something you know that there is power. Use the coat hanger test mentioned above. Try both lifting the float up and pushing it to the bottom while you observe the gauge. If lifting brings the reading to "full", take a close look at the float as you suggest. Remember when using the coat hanger that the gauge responds slowly and give it time to react.
roofman
TR674 when you removed the speedo, the voltage stabilizer is attached. If you disconnected the stabilizer wires you will get no fuel or temp guages ( at least).
T
Tinster
Both gauges on the Crypt Car were wacky
until a new voltage regulator was installed. Then
the entire car rewire did away with the need of the
VR completely.
With the tach out, and original wiring-neither gauge
will function.
d
K TR2/3/3A TR6 fuel gauge in a TR3? Triumph 1
Gliderman8 TR6 Troubleshoot a TR6 Fuel gauge problem Triumph 36
I TR6 TR6 - Fuel leaking from bottom of Evaporator Canister Triumph 11
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
hondo402000 TR6 TR6 Fuel Injection made easy Triumph 12
F TR6 TR6 Fuel Pump Priming Triumph 11
sundown TR6 1973 TR6 fuel pump Triumph 4
B TR6 TR6 Fuel Filter keeps clogging Triumph 9
Gliderman8 TR6 Mounting location for electric fuel pump on TR6 Triumph 42
D TR6 1976 TR6 Fuel Lines Triumph 7
I TR6 75 TR6 Fuel sending unit gasket Triumph 1
T TR6 TR6 fuel line / mechanical fuel pump compression? Triumph 5
G TR6 TR6 fuel tank fitting size. Triumph 14
Got_All_4 TR6 Moss TR6 mechanical fuel pump TR6 Triumph 25
M TR6 TR6 Fuel Delivery Issue Triumph 18
I TR6 TR6 fuel pipe nut source? Triumph 5
I TR6 TR6 fuel pump - how do I replace these? Triumph 18
T TR6 Bolt size/thread count for fuel sender TR4/TR6 Triumph 16
wangdango TR6 76 TR6 electric fuel pump? Triumph 3
T TR6 tr6 fuel sending unit Triumph 5
G TR6 TR6 Fuel Injection ? Triumph 8
T TR6 Fuel tank question - TR4a & TR6 truly identical? Triumph 3
BobbyD TR6 TR6 Fuel Pump Triumph 1
Brosky TR6 Fuel Pump Kit for TR6 Triumph 3
Gliderman8 TR6 TR6 Fuel electric pump? Triumph 14
DNK TR6 TR6 fuel lines. Triumph 20
B TR6 TR6 Fuel Odor in the Brake Servo Triumph 7
B TR6 71 TR6 Fuel Tank firewall? Triumph 6
J TR6 Just another whining TR6 fuel pump again? Triumph 19
SCguy TR6 How can you tell if your TR6 fuel pump is working? Triumph 4
E TR6 TR6 Fuel / Mixture ? Triumph 4
71tr TR6 fuel line TR6 Triumph 2
V TR6 Oil and Fuel for TR6 Triumph 6
I TR6 Fuel injection for TR6 Triumph 4
G TR6 Free OE TR6 Fuel Pump.....................8 bucks. Triumph 2
71tr TR6 fuel line TR6 Triumph 6
V TR6 TR6 Fuel pump spares Triumph 8
F TR6 Changing TR6 fuel tank sending unit... Triumph 6
T TR6 Repair or replace TR6 fuel level sender unit Triumph 4
G TR6 Fuel sender resistance for TR6 Triumph 1
I TR6 fuel lines for 69 TR6 Triumph 3
Tullamore TR6 TR6 Fuel Leak Triumph 4
Morris TR6 TR6 Fuel Injection Triumph 21
padjo TR6 TR6 Fuel Pump Triumph 1
M TR6 TR6 FUEL TANK VENT PIPE Triumph 3
BierRunner TR6 TR6 Gas Pedal Triumph 2
nichola TR6 Another TR6 back on the road Triumph 1
TR6Canuck TR6 Wire spoke rims to fit Michelin Red Line Tires on TR6 Triumph 12
E TR6 74 TR6 - “ A Post Seal” Triumph 0
J Wanted TR6 seat vinyl Triumph Classifieds 1
