TR6 TR6 dash lights not bright enough
G
Seems like the dash lights on my TR6 don't get bright enough. I reached down through the ashtray and the back of the rheostat switch is very hot to the touch when the lights are on. Is the switch on its way out? I can turn the switch to on-off and rather dim only. It does not brighten the dash lights up and down anymore. When it is turned to the off position it cools down completely. It was working okay last week when I drove the car at night. I can't think of anything else that I have done electrically except put a new bulb in the glovebox socket. I took the bulb out and no difference, so that was not a factor.
DNK
Get rid of that thing before you burn your car up. Just straight wire it and you'll be golden.
G
Thanks for that advice but I'm looking to fix it properly.
TR3driver
Great Pumpkin - R.I.P
So if I understand you right, you can still set the lights to full bright, but then the only other choices are "rather dim" and "off". Sounds like standard Lucas to me /bcforum/images/%%GRAEMLIN_URL%%/grin.gif
Seriously, that might be a sign that there is a short in the dash lights. Not enough to pop the fuse apparently (what size fuse do you have in there ?), but enough to drop the voltage way down when the resistor (rheostat) is in the circuit.
Or, it might just be a nearly-dead rheostat. If it hasn't failed already, it will quickly with that short. They are very fragile that way.
One of my many "back burner" projects is to figure out how to use an IC as the pass element for the dash lights, with overcurrent and overtemp protection built in, and a knob/control that looks the same as original. But at the rate I'm going, I'll have to retire before I have time to work on that, which is still several years away.
G
On is dim only. No bright at all. On and off is all I have and on is the dimmest of how the switch used to be. As I turn it up, it just stays dim.
All other lights on the car are working properly.
Brosky
DNK
Stirkle, I'm serious about the car becoming a car-b-que. Has happened to many a Triumph. My suggestion,fix it soon.
G
I'm sure it could easily cook something, it was very hot. I am not going to use it again until it's fixed.
DNK
You don't have to be using it. It just stays hot and eventually Whoosh!!!
G
Well, I guess I'll have to get at the back of the dash for this. It looks like 5 screws, unhook the speedo, tach cables and wiper switch. Then the wood dash will pull out enough to work on? Did I miss anything else?
swift6
Yes, you have to remove the speedo and the tach. Not just the cables. They clamp against the metal facia behind the dash while the other instruments simply clamp to the wood. You might also try taking apart the gauges in order to clean the insides and the lighting fixtures.
Just so you know, if you haven't figured it out from the previous posts yet, they were never very bright to begin with. Especially when compared to more modern lighting schemes.
G
Thanks for the guages tip Shawn. Yes I know how dim these dash guages are to begin with. More so as we all get older and the eyes aren't what they once were.
G
Stirkle, the wooden dash is just a cover for the real dash, a metal plate with holes in it. It would be a lot easier for you to just pull a seat, say the passenger side, lay a nice thick blanket down and with a strong flashlight and you laying on your back, stick your head up under there and poke around. I just bypassed my dash lights rheostat and keep the dash lights on their brightest, which is still not very bright at all.
Brosky
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]Just so you know, if you haven't figured it out from the previous posts yet, they were never very bright to begin with. [/QUOTE]
Excuse me Shawn, but are you referring to the lights or the posters to this thread?
Brosky
Oh, I do have the 8 watt bulbs which are supposed to light it up pretty well, but those are being saved for after the suspension and under body paint project.
T
Tinster
The "Refurbisher Guy" says the lights were dim to
begin with as that was the romantic concept back
in the day.
If you take apart the gauges you will find the lighting is
indirect and bounces around the inside. Clean the insides
and the lights will be brighter. Replace the wires, the
lights will be brighter. Install new grounds, the lights
will be brighter. But they will never be a bright as
TRBill's Miata dash lights.
There are some plastic end cap baffles in the speedo and
tach that diffuse the light. (4 total if I remember
correctly.) You can remove them and brighten things up a
bunch.
DPO Pedro replaced the rheo with a cigarette lighter. I
replaced his cigarette lighter with a rocker switch for
on/off all dash lights.
tinster
swift6
Excuse me Shawn, but are you referring to the lights or the posters to this thread? [/QUOTE]
Do I have to answer that or can I assert my fifth amendment rights? /bcforum/images/%%GRAEMLIN_URL%%/jester.gif
Adrio
Tinster said:
Clean the insides
I too have a back burner project I hope to get to one winter that takes this cleaning idea one step further. The hobby shops sell this chrome leaf like stuff. It is self adhesive, thin almost like gold leaf and just like chrome. I figure if I line the inside of the gauge (or at least all the parts the light travels through) it will brighten the gauge a fair bit.
2wrench
I think you might be able to drop your wood facia forward
enough to access the rheostat by removing the speedo and
tach cables; screws in wood fascia. This should let
the wood drop forward. Problem for me was that at the
angle the wood set forward, the little screws holding the
rehostat in place were a little testy to get at. You'd
need a small and short-handled screwdriver.
Also, I ordered a new rehostat from The Roadster
Factory. It took a number of weeks, and then I received
the wrong thing. I was so disappointed that I bypassed
the rheo. Basically, the wire in on one side of the
switch connected to the wire on the outside end of the
switch and the lights stay on full bright, such as they
are.
G
I'm going to replace the rheostat not bypass it but I'm trying to make sense of this whole thing to myself. Everyone agrees that the TR dash guages are rather dim to begin with and the big 3 want over a hundred dollars for the switch that makes them even dimmer.
It's almost cheaper to legally change my name to Pedro!
I TR6 Thickness of original TR6 dash Triumph 2
E TR6 ā€˜74 TR6 Interior - Padded dash and heat/sound material Triumph 4
rjc157 For Sale 74 tr6 dash Triumph Classifieds 2
S TR6 TR6 Dash refinish: a nice surprise Triumph 4
S TR6 Removing TR6 dash [and suggestions on refinish] Triumph 12
TR4nut TR6 TR6 under dash pics? Anybody? Triumph 9
J TR6 TR6 Dash knobs Triumph 2
JimTR4 TR6 TR6 dash support in a TR4? Triumph 23
G TR6 TR6 dash and windshield frame removal Triumph 13
Coyote1 TR6 TR6 Dash Support won't go in Triumph 9
Tr4dude TR6 Tr6 resto dash Latest Triumph 3
V TR6 TR6 Center Dash Support Triumph 16
C TR6 TR6 Dash replacement, now only the horn works Triumph 6
S TR6 TR6 Dash Triumph 18
G TR6 Dash support options for TR6 Triumph 8
Brosky TR6 Free dash panel, late TR6 Triumph 4
G TR6 TR6 original dash bulbs as bright as newer bulbs Triumph 1
mrv8q TR6 In the dash, '74 TR6 Triumph 2
I TR6 Veneer sanding, TR6 dash Triumph 3
C TR6 TR6 Dash Support Triumph 5
M TR6 TR6 dash Triumph 13
hondo402000 TR6 Veneering a TR6 dash Triumph 15
hondo402000 TR6 need a used dash for 71 TR6 Triumph 1
2wrench TR6 Pictures of TR6 dash refinished front + back Triumph 22
I TR6 TR6 dash help Triumph 8
I TR6 TR6 Dash help Triumph 7
I TR6 Reveneering TR6 Dash Triumph 3
T TR6 "Might as well" if you need to pull the TR6 dash Triumph 6
B TR6 Installing a new dash in TR6 Triumph 38
2wrench TR6 How do I remove the rheostat from dash of TR6? Triumph 23
2wrench TR6 Need replacement bulbs ID'd for under dash '74 TR6 Triumph 4
roofman TR6 72 TR6 dash lite reostat question Triumph 10
F TR6 Looking for TR6 metal dash support Triumph 4
R6MGS TR6 TR6 Under Dash panel?? and dash cap Triumph 10
I TR6 TR6 dash refinishing Triumph 7
J TR6 TR6 DASH HELP? Triumph 6
G TR6 tr6 - really dumb dash question Triumph 4
nathandarby67 TR6 TR6 Dash on ebay Triumph 0
J TR6 1975 TR6 Alternator Advance/Retard spring(s) Triumph 1
F Wheel Trim Rings Triumph TR6, $95.00 Triumph Classifieds 0
P TR6 TR6 Frame Stiffener Triumph 4
Geo Hahn TR6 TR6 Oil Line Thread Size Triumph 1
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 14
C TR6 Latest TR6 updates and pics Triumph 10
P TR6 TR6 Horn Relay Problems Triumph 8
tr6nitjulius General TR TR6 Triumph 0
Sherlock Triumph TR6 (rather modified) Spotted 2
B TRIUMPH TR6 BODY SHELL Triumph Classifieds 0
M For sale rear wings Tr6 Triumph Classifieds 3
tr6nitjulius TR6 Ongoing Love Affair with 1 TR6 Triumph 8
