TR6 TR6 Dash help
ichthos
Hello All,
I need some help on my dash. My dash was a disaster, but I am almost done with repairs and new veneer. I hope to be done with the finish in another month. One area that is still a little worn is the recessed area the four small gauges and the two warning lights sit into. The tach and speedometer stick out where just the triangular part of the outer rim sticks out about the dash. My question is how far do the four small guages (fuel, oil, amp, temp.) stick out? How far do the two warning lights stick out? I plan on using various thicknesses of O-rings for adjustment if needed.
Thanks, Kevin
Brosky
You need answers from Tom and Dale....where are you guys???
tomshobby
This has turned out to be an interesting question because I only refinished my dash and was very careful to not remove material from the original surface.
I just went out and made some measurements and found a considerable variance. The tach and spedo seem to average close to .150" and the small gages seem to average about .040".
Notice I used the terms "seemed to" and "average". The reality wandered between .2 and .125 for the large gages and .05 and .025 for the small ones.
The interesting part is that I, a person that normally is drawn to such variances and well aware of metrology (the science of precision measuring), never checked it out until now. Actually, it does not even bother me know that I know, again something that normally would, simply because it is not really noticeable or seem out of place. And that might be because nothing else on these cars seems to fit with anything representing "precision". The normal fit criteria seems to be more in tune with being in the general area. /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
Kind of like a machinist I once knew that operated on the theory of "sneak up and allow" to reach tight clearances.
kodanja
not perfect but...
tdskip
As an FYI - that smoke you see in the last picture is my brain going up in smoke based on how nice Kodanja's dash looks.
Brosky
Nice picture, but tach at ZERO again...
Hehehehehe....
I
ichthos
Thanks for the pictures; they are a great help. I think I will put O-rings behind them so that the triangular portion of the outer ring sticks out above the dash.
My TR6 is a 69. I am amazed at the variances in my car overall. When ever anyone points the variances out, I just let them know it is the sign of "British hand-craftmanship."
I try to make my car a little better every year, but I am OK with the little flaws - I figure it gives my car a little character. My car will probably never look like the pictures I see posted on the forum or ones I see in the shows. I just enjoy driving my car too much to have that much down time.
Bach to my dash. I am fairly certain that my dash is original since the car sat for over 25 years and still had the original finish. Some unusual things I found with the dash are that they didn't completely drill the screw holes to attach the dash (The holes were drilled from behind, but not all the way through the veneer.) The glove box never appears to have been fitted correctly (I had to shim one of the hinges to make the gap half way uniform.) Not one of the small instrument holes appears to have been cut to the same depth. I did notice the rheostat on my dash sticks out a lot further than the picture - is that normal? The holes for the guages seem a little too large also. The original finish was quite thick - maybe that decreased the diameter some.
Kevin
Brosky
Kevin,
It sounds as though you have taken the time to do this correctly, from the start. Please note (in the close up picture) the "bead or edge trim" that Kodanja added to his, which fits around the wood and seals the gap in between the wood and vinyl. You may want to consider doing that as you reassemble.
Good luck!
I TR6 TR6 dash help Triumph 8
J TR6 TR6 DASH HELP? Triumph 6
EWD TR6 74 TR6 Renegade Dash Wire Triumph 7
EWD TR6 TR6 top dash trim paint Triumph 2
I TR6 Thickness of original TR6 dash Triumph 2
EWD TR6 ‘74 TR6 Interior - Padded dash and heat/sound material Triumph 4
rjc157 For Sale 74 tr6 dash Triumph Classifieds 2
S TR6 TR6 Dash refinish: a nice surprise Triumph 4
S TR6 Removing TR6 dash [and suggestions on refinish] Triumph 12
TR4nut TR6 TR6 under dash pics? Anybody? Triumph 9
J TR6 TR6 Dash knobs Triumph 2
JimTR4 TR6 TR6 dash support in a TR4? Triumph 23
G TR6 TR6 dash and windshield frame removal Triumph 13
Coyote1 TR6 TR6 Dash Support won't go in Triumph 9
Tr4dude TR6 Tr6 resto dash Latest Triumph 3
V TR6 TR6 Center Dash Support Triumph 16
C TR6 TR6 Dash replacement, now only the horn works Triumph 6
S TR6 TR6 Dash Triumph 18
G TR6 Dash support options for TR6 Triumph 8
Brosky TR6 Free dash panel, late TR6 Triumph 4
G TR6 TR6 original dash bulbs as bright as newer bulbs Triumph 1
G TR6 TR6 dash lights not bright enough Triumph 22
mrv8q TR6 In the dash, '74 TR6 Triumph 2
I TR6 Veneer sanding, TR6 dash Triumph 3
C TR6 TR6 Dash Support Triumph 5
M TR6 TR6 dash Triumph 13
hondo402000 TR6 Veneering a TR6 dash Triumph 15
hondo402000 TR6 need a used dash for 71 TR6 Triumph 1
2wrench TR6 Pictures of TR6 dash refinished front + back Triumph 22
I TR6 Reveneering TR6 Dash Triumph 3
T TR6 "Might as well" if you need to pull the TR6 dash Triumph 6
B TR6 Installing a new dash in TR6 Triumph 38
2wrench TR6 How do I remove the rheostat from dash of TR6? Triumph 23
2wrench TR6 Need replacement bulbs ID'd for under dash '74 TR6 Triumph 4
roofman TR6 72 TR6 dash lite reostat question Triumph 10
F TR6 Looking for TR6 metal dash support Triumph 4
R6MGS TR6 TR6 Under Dash panel?? and dash cap Triumph 10
I TR6 TR6 dash refinishing Triumph 7
G TR6 tr6 - really dumb dash question Triumph 4
nathandarby67 TR6 TR6 Dash on ebay Triumph 0
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
