glemon
I am lookking at fitting a modified head to my TR250, I have the chance to buy either an early motor complete with early head and log manifold, or the later head with the longer manifold. I plan on skimming to head to get the compression ratio in the 9.5/1 range and doing some mild port and polish work.
I have generally read that the later head/manifold is the better bet, there won't be any compatibility issues with the earlier block, didn't the later heads and or block have some sort of lip for each cylinder? Also the earlier head has bigger exhaust valves, does it make sense to do a retrofit?
My goal has always been to increase performance with little or no damage to reliability or drivability, if you want to know where I am going with the motor, already has a very mild cam and slightly lightened flywheel.
Also real technical question, I did get a set of the big Joe Alexander intake trumpets, they stick out slightly under 3.5", it looks like the later intake manifold will space may carbs out a couple inches farther from the head, any known or projected clearance issues, thanks, quick help appreciated, want to snap up the motor this weekend.
Greg
Greg
