TR6 TR6 Camshaft timing
houleyh
Can someone tell me where the timing mark is on the crankshaft so I could refitt the timing chaion & camshaft??
I do not see any mark.
Thanks
YH
trrdster2000
houleyh, you will have to put the crankshaft sprocket on and the cam shaft sprocket on for a temp fit as these have a small punch mark in each for alignment. A couple of things, the crank should be pointing north or straight up and the other is the cam sprocket can be arranged in four different places, so be sure your timing for #1 is correct. If you have new sprockets they may not have the punch mark, so just start off with the crank in the right position and go from there. Wayne (Hope you have a DIY book.)
Rick O.
[ QUOTE ]
[/ QUOTE ]
That is, the crank keyway should be pointing up. When I did this procedure, I verified that the dots on the crank sprocket and cam chainwheel were aligned with a metal rule at TDC before removing them. Then I transferred the chainwheel dot/line to the new chainwheel. I had bought a new sprocket but found that it was keyed wrong in comparison with my old one.
B TR6 TR6 Camshaft Timing Triumph 4
H TR6 TR6 camshaft options Triumph 9
E TR6 TR6 Camshaft Install - Engine In Triumph 10
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
R TR6 TR6 Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
A For Sale 1974 TR6 Triumph Classifieds 1
EWD For Sale ‘74 TR6 original wheel trim rings Triumph Classifieds 3
EWD For Sale ‘74 TR6 original radio Triumph Classifieds 0
EWD For Sale ‘74 TR6 original starter Triumph Classifieds 0
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
JPSmit TR6 at lunch today Spotted 0
E Wanted looking for a tr6 bell housing Triumph Classifieds 12
jfarris For Sale TR6 Yellow Fan - new Triumph Classifieds 0
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
charlie74 ‘74 1/2+ TR6 Spotted 0
E TR6 TR6 flip-up bonnet question Triumph 4
Marvin Gruber For Sale 1974 TR6 for sale, $7200 Triumph Classifieds 3
