TR4/4A TR4A long block value?
TR4A_IRS
Any guesses as to the fair market value of a TR4A long block? I have the opportunity to pick one up, but I don't have a feel for how much I should be willing to pay.
I would like to do an engine rebuild, and like the idea of being able to drive my car while doing the work.
TR3driver
Great Pumpkin - R.I.P
The block itself is practically worthless; in fact I tried to give one away last year and got no takers. A sound crank & head are worth perhaps $150 each, IMO, maybe a bit more if the crank has never been ground before (will clean up at .010" under). ISTR Larry was paying $60 for camshafts, and Joe was paying $20 for rear main seals.
So maybe $500 for the package. YMMV
TR4nut
I agree with Randall on the component prices, but I'd say the really marketable parts are just the crank and the head. So if I were hunting for a long block probably $200-$300 is about as much as I'd go. Just like a car, the engine is worth more in parts than whole so bargain hunting is not out of line I think. All depends on timing and needs - they do show up for low money over time.
TR4A_IRS
TR4A_IRS
I guess I should have been more specific. I have always thought of a long block as a complete engine with accessories (water pump, generator, etc.) and I think of a short block as the block and head, including all engine internals.
Thanks for the feedback so far. What I am looking at is a long block plus both manifolds and carbs. I am told it ran before pulled, albeit poorly.
mallard
I just sold a TR4 complete engine for $500.00.The engine would turn, but had no idea of the condition. I was surprised that I got asking price.
Andrew Mace
I don't know who's right, but I always thought of the short block as that relatively complete assembly BELOW the cylinder head (including crank, pistons, probably camshaft). The long block would be the above plus cylinder head and such. A "complete engine with accessories (water pump, generator, etc.)" is something I would describe as "a complete engine"! :laugh:
As for value of a wet-liner block itself, probably not much...unless you've got someone trying to find one that doesn't have cracks around the cylinder head stud holes, or other damage. THEN you might have something worth a few $$$.
Marvin Gruber
Short block has no head. I have a TR4a high port head engine I'm selling for $400. All disassembled, head magnafluxed. Those heads bring $300. A crank is worth $100/150, about the same as the short block.
Marv
cheseroo
That's my belief as well. If it's on OHV engine, a short block includes the cam otherwise no cam. It should include a pan but I've seen them advertised as such without it. A long block is a short block that includes the head (and cam and cam chain/belt stuff) and pan. It does not include any manifolds or accessories (incl water pump). A complete engine is just that, one ready to drop in (maybe less air cleaners). A short block requires the head and accessories installed to make it run. A long block requires accessories to run and a complete engine requires nothing to run.
It sounds to me like you want a complete engine although in the situation you describe, I would get a long block and transfer my accessories to it (I'd wouldn't share the water pump between the two though) and rebuild my original. If you are going whole hog, I'd send off my distro and carbs right before the rebuild was complete to minimize the downtime. Unless you feel the need to have stuff like spare exhaust and intake manifolds, I don't see it being cost effective to have a complete spare engine unless it doesn't cost any more than a long block.
TR4A_IRS
TR4A_IRS
For futher clarity, what I looking at is a "complete engine" that includes just about everything.
I know I could swap over all the accessories, when the time comes, and I will probably do that, since mine are all in good working order. I won't be paying a premium for all the extras.
Thanks.
TR3driver
In that case, the starter, generator, manifolds and carbs will add something to the value.
My point of view, a "long block" would probably include the water pump housing and might include the water pump; but not manifolds, starter & carbs.
I'm still trying to decide whether it is worth the extra effort to swap engines before the rebuild, so I can rebuild the original block. As I get older, I seem to value originality more than I used to, and yet since I don't plan to ever show the car, it really doesn't matter what numbers are on the side of the engine. And for sure I'm still going to install my "go fast" goodies, including hot cam, 89mm liners, 4-2-1 header, etc.
Perrymip
This will be a high figure, since it's a shop's charge, but I was intending to do the opposite of your plan, that is: having another motor rebuilt, while continuing to drive mine. Anyway, the shop's "core charge" was $750. I ended up not going this direction, but I'm guessing the figure is not far off standard.
A TR4/4A Short or long tie rod end levers on TR4a Triumph 6
R TR4/4A Tr4a, new horn brush is too long Triumph 2
K TR4/4A TR4A long intake manifold on a TR3A? Triumph 3
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 14
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
RJS TR4/4A TR4A Seat Upholstery - Piping Question Triumph 7
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
RJS General TR TR4A Seat Rebuild Triumph 12
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
T TR4/4A Recommendation on top for a late TR4A Triumph 8
S TR4/4A Build Date Triumph TR4A IRS Triumph 3
R For Sale Tr4a parts Triumph Classifieds 2
Sarastro TR4/4A TR4A top's rear attachment Triumph 2
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
fpstude TR4/4A Steering U-Joint Question for TR4A Triumph 5
S For Sale Triumph TR4 and TR4A Factory Workshop Manual on CD/ROM - 1962 - 1968 Models Triumph Classifieds 0
G TR4/4A Vin # for TR4A Triumph 3
M TR4/4A Seats for TR4A Triumph 3
B TR4/4A TR3 valve cover on TR4A Triumph 4
T For Sale TR4A Grille Triumph Classifieds 0
K For Sale TR4A Intake Manifold..Put one on your TR3...improves air intake....cheap like borsht. Triumph Classifieds 2
K For Sale TR4A Grille with Embedded Fog Lights Triumph Classifieds 0
K TR2/3/3A TR4A 16P Girling Calipers Adapted to TR3. Hose/tubing routing? Triumph 15
D Wanted TR4A Live axle frame Triumph Classifieds 0
D TR4/4A Tackling the biggest problem with my TR4A.... Frame Damage :[ Triumph 70
K TR2/3/3A Can a TR4A Fuel Gauge be swapped into a TR3A? Triumph 8
H TR4/4A Original TR4a grill versus aftermarket Triumph 0
M TR4/4A Where to buy a new crown wheel & pinion for TR4A Triumph 5
Rut TR4/4A TR4A parts car Triumph 7
M TR4/4A Reducing Chassis Flex on TR4A IRS Triumph 2
jfarris For Sale 1967 TR4A IRS $19,000 Birmingham AL Triumph Classifieds 3
Rut TR4/4A 67 TR4a irs to live axle Triumph 18
michalotti_tr For Sale TR4A Project Triumph Classifieds 18
Sarastro TR4/4A Original TR4A paint: enamel or lacquer? Triumph 4
KVH TR4/4A Wiring to TR4A Wiper Switch Triumph 11
S TR4/4A TR4 vs. TR4A metal dash panel Triumph 5
PeterK General TR Need a handbrake button and rod TR4a-TR6 Triumph 5
Rut TR4/4A 66 TR4a on BAT Triumph 4
J TR4/4A TR4A clogged fuel filter Triumph 13
T TR4/4A TR4A/TR250 what are they worth Triumph 8
N TR4/4A TR4A windshield replacement Triumph 1
AngliaGT Tr4a Spotted 0
Brinkerhoff TR4/4A Straightening a TR4A IRS chassis Triumph 15
M Wanted Wanted TR4A/TR250 passenger side front fender Triumph Classifieds 0
M Wanted WANTED TR4A or TR250 fendet Other British Classifieds 0
busybrit Wanted TR4, TR4A, TR250 Rear light WANTED Triumph Classifieds 0
K For Sale TR4A Grille...Modified for Lights Triumph Classifieds 0
S For Sale Triumph tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
J Wanted Tr4a irs frame Triumph Classifieds 1
S TR4/4A Smoothline hardtop for TR4A Triumph 0
