TR4/4A TR4A IRS Front and Rear Differential Bridge Pins
KVH
When those threaded pins that hold the differential, quite stout, actually fail or break, can't they be replaced by carefully cutting them off and welding a new threaded extension?
I've not seen that done, but it seems like a possible fix, and maybe more practical than removing the body of car and dropping a new pin in from the top (assuming anyone would do that).
thx
HerronScott
Has anyone actually had the pins themselves break? I thought the usual failures were initially the lower part of the bracket would crack where the pin goes through it and if left untreated, then the pin would tear loose from where it was welded to the top bridge.
Scott
pacotaco
Member
I believe HerronScott is correct. My bracket cracked side to side from the pin. I certainly feel like it could have caused the pin to crack loose at the top bridge as there is not much to hold it there if unsupported at the bottom. I did the "fixes" with both bracket side supports and extra reinforcement welded at the top of the bridge. Also did the fixes on the front suspension at the same time. I have had a failure at the front on a previous car that was within a couple of minutes of probably costing me my life. So I don't want to mess around with things that could have bad consequences. But my car is disassembled so fixing these items was much easier.
KVH
KVH
Yes, the main issue is where the pin enters the bracket. It is common to see those brackets with hairline cracks. Mine, for instance, looked perfect until we hit the brackets with a wire brush. We then boxed them in with cross members for added protection.
However, the pins do fail--at the top of the bridge and at the bottom where the threads can be stripped. I've seen some awkward fixes with stripped pins, and I was just curious how difficult the "fix" might be.
pacotaco
Member
Mine was more than a hairline crack and I believe that finding it and correctin g it was critical. Mine was like most it was the front right mount that failed Don't skip on safety. I've now owned two TR4A IRS's and both have had cracks at the bad places. But we know of these weaknesses front and rear and suppliers do to and provide the necessary parts to fix these.
tdskip
Side note - generally speaking welding upside down in that location unless you have a proper lift is not a laugh riot.
I boxed in my TR6 and TR4a and it was not the most fun I've ever had.
hondo402000
well I just boxed in mine on my TR6 and what I found was the welding portion, although a pain, was the easy part, cleaning all the grease off was the hard part,
Hondo
R TR4/4A Disc wheel studs front and rear TR4a irs Triumph 4
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
S TR4/4A Build Date Triumph TR4A IRS Triumph 3
M TR4/4A Reducing Chassis Flex on TR4A IRS Triumph 2
jfarris For Sale 1967 TR4A IRS $19,000 Birmingham AL Triumph Classifieds 3
Rut TR4/4A 67 TR4a irs to live axle Triumph 18
Brinkerhoff TR4/4A Straightening a TR4A IRS chassis Triumph 15
J Wanted Tr4a irs frame Triumph Classifieds 1
L For Sale late tr4a IRS project Triumph Classifieds 0
Scotsman TR4/4A TR4a Live axle vs IRS Triumph 13
J TR4/4A TR4A IRS Grille Question Triumph 4
O TR4/4A Will these tires/wheels work on my 1966 TR4a, IRS? Triumph 19
G TR4/4A tr4a irs left rear wheel Triumph 14
C TR4/4A TRIUMPH TR4A iRS For Sale - NUT & BOLT RESTORATION--[CONCOURS CONDITION] Triumph 2
C TR4/4A 1967 TR4A IRS motor mounts Triumph 7
Zimmycobra TR4/4A TR4A IRS Differential Mounts Triumph 8
Zimmycobra TR4/4A any tricks to change rear brake hose - especially on passenger side [TR4A IRS] Triumph 9
richie TR4/4A Wheel fitment on TR4a solid axle vs IRS Triumph 6
rovernut TR4/4A TR4A IRS VIN differences Triumph 9
Gerard TR4/4A TR4A IRS rear suspension rebuild Triumph 10
T TR4/4A 65 triumph tr4a-irs tires Triumph 7
J TR4/4A TR4A IRS Trunk Triumph 3
J TR4/4A TR4A IRS Exhaust Triumph 5
T TR6 TR4a IRS vs TR6 handling Triumph 20
J TR4/4A TR4A IRS Clamps, Belt and Suspenders? Triumph 4
J TR4/4A TR4A IRS Exhaust Triumph 11
britlover TR6 TR4A IRS body on a TR6 Frame?? Differences? Triumph 10
J TR4/4A TR4A IRS Jack Stands Triumph 6
J TR4/4A Shock Absorbers TR4A IRS Triumph 3
R TR4/4A 66' TR4a irs, steering nut size Triumph 13
R TR4/4A Tr4a irs, name plate question Triumph 13
J TR4/4A 67 TR4A IRS Hood Bumpers-Cones or Flat? Triumph 8
gubba TR4/4A My new 1967 TR4A IRS Triumph 17
R TR4/4A tr4a irs clunking rear end on fast acceleration Triumph 7
J TR4/4A TR4A IRS Home Triumph 5
J TR4/4A 67 TR4A IRS picked up today! Triumph 23
T TR4/4A Broken disc wheel stud on TR4A IRS hub. Triumph 3
RJS TR4/4A TR4A IRS Diff Capacity Triumph 3
T TR4/4A Fired the 67 TR4a IRS engine today Triumph 5
T TR4/4A Which TR4a is better - IRS or solid axle? Triumph 30
Darrell_Walker TR4/4A TR4A IRS-SC?!?!?! Triumph 48
KVH TR4/4A TR4A IRS Differential and Axles Removed Triumph 11
KVH TR4/4A TR4A IRS Issues and Smashed Thumb Question Triumph 24
KVH TR4/4A TR4A IRS Axle Shafts Triumph 19
KVH TR4/4A TR4A IRS Rear Spring Bridge Triumph 6
KVH TR4/4A TR4A IRS Rear Suspension Knock Triumph 3
T TR6 Anyone use TR6 rear springs in their TR4a IRS? Triumph 8
T TR4/4A TR4a IRS differential mount issues Triumph 11
T TR4/4A TR4A IRS trailing arm bushing question Triumph 15
bcliff TR4/4A Triumph TR4A IRS FS. Need help with this one.PICS! Triumph 6
