TR4/4A TR4A IRS Exhaust
JDstr4a
New exhaust on this weekend. Decided to go with stock, with stainless down pipe and y-pipe using stocks clamps. Everything back together thanks to my brother and a few Mike's HL's. I'm happy with the sound, am am thrilled to drive again and move on to other areas. Other than deciding what type of tips to put on the exhaust, I want to go through the rear suspension and check the mounts etc.
I noticed a tilt with the drivers rear about 3/8 lower than the passenger's side. Anything specific I should look for while I'm under there?
Thanks
JD
Simon TR4a
JD I would first make sure the car is sitting on a REALLY flat surface, check with a long (4 ft.) spirit level.
If the car is not sitting level as indicated by different clearance from tire to lip of the wheel arch or by using the spirit level across the top of the rear wings then you need to see if the spring on the driver side has sagged, or possibly a spacer is missing.
You could take out both the coils and see if the free height is the same- assuming from the IRS badge that you have coil springs!
J
JDstr4a
Thanks, nothing scientific just an observation and follow-up tape measure from floor to upper wheel well using the knockoff as a center line. You'd think in Illinois finding a good flat surface would be easy! It's too nice out today to put back up on stands, so it will have to wait! I'm putting on a quick wax to keep the bugs from sticking (really makes the warts jump out on a black finish) then I'm off to do some more "test" driving! :driving:
HerronScott
JD,
Looks like your picture was deleted or moved on Photobucket?
Scott
J
JDstr4a
OOPS! :blush: Rearranged photobucket to send PO an update. Thanks Scott.
J TR4/4A TR4A IRS Exhaust Triumph 11
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
S TR4/4A Build Date Triumph TR4A IRS Triumph 3
M TR4/4A Reducing Chassis Flex on TR4A IRS Triumph 2
jfarris For Sale 1967 TR4A IRS $19,000 Birmingham AL Triumph Classifieds 3
Rut TR4/4A 67 TR4a irs to live axle Triumph 18
Brinkerhoff TR4/4A Straightening a TR4A IRS chassis Triumph 15
J Wanted Tr4a irs frame Triumph Classifieds 1
L For Sale late tr4a IRS project Triumph Classifieds 0
Scotsman TR4/4A TR4a Live axle vs IRS Triumph 13
J TR4/4A TR4A IRS Grille Question Triumph 4
O TR4/4A Will these tires/wheels work on my 1966 TR4a, IRS? Triumph 19
G TR4/4A tr4a irs left rear wheel Triumph 14
C TR4/4A TRIUMPH TR4A iRS For Sale - NUT & BOLT RESTORATION--[CONCOURS CONDITION] Triumph 2
C TR4/4A 1967 TR4A IRS motor mounts Triumph 7
Zimmycobra TR4/4A TR4A IRS Differential Mounts Triumph 8
Zimmycobra TR4/4A any tricks to change rear brake hose - especially on passenger side [TR4A IRS] Triumph 9
richie TR4/4A Wheel fitment on TR4a solid axle vs IRS Triumph 6
rovernut TR4/4A TR4A IRS VIN differences Triumph 9
Gerard TR4/4A TR4A IRS rear suspension rebuild Triumph 10
T TR4/4A 65 triumph tr4a-irs tires Triumph 7
J TR4/4A TR4A IRS Trunk Triumph 3
T TR6 TR4a IRS vs TR6 handling Triumph 20
KVH TR4/4A TR4A IRS Front and Rear Differential Bridge Pins Triumph 6
J TR4/4A TR4A IRS Clamps, Belt and Suspenders? Triumph 4
britlover TR6 TR4A IRS body on a TR6 Frame?? Differences? Triumph 10
J TR4/4A TR4A IRS Jack Stands Triumph 6
J TR4/4A Shock Absorbers TR4A IRS Triumph 3
R TR4/4A 66' TR4a irs, steering nut size Triumph 13
R TR4/4A Tr4a irs, name plate question Triumph 13
J TR4/4A 67 TR4A IRS Hood Bumpers-Cones or Flat? Triumph 8
gubba TR4/4A My new 1967 TR4A IRS Triumph 17
R TR4/4A tr4a irs clunking rear end on fast acceleration Triumph 7
J TR4/4A TR4A IRS Home Triumph 5
J TR4/4A 67 TR4A IRS picked up today! Triumph 23
R TR4/4A Disc wheel studs front and rear TR4a irs Triumph 4
T TR4/4A Broken disc wheel stud on TR4A IRS hub. Triumph 3
RJS TR4/4A TR4A IRS Diff Capacity Triumph 3
T TR4/4A Fired the 67 TR4a IRS engine today Triumph 5
T TR4/4A Which TR4a is better - IRS or solid axle? Triumph 30
Darrell_Walker TR4/4A TR4A IRS-SC?!?!?! Triumph 48
KVH TR4/4A TR4A IRS Differential and Axles Removed Triumph 11
KVH TR4/4A TR4A IRS Issues and Smashed Thumb Question Triumph 24
KVH TR4/4A TR4A IRS Axle Shafts Triumph 19
KVH TR4/4A TR4A IRS Rear Spring Bridge Triumph 6
KVH TR4/4A TR4A IRS Rear Suspension Knock Triumph 3
T TR6 Anyone use TR6 rear springs in their TR4a IRS? Triumph 8
T TR4/4A TR4a IRS differential mount issues Triumph 11
T TR4/4A TR4A IRS trailing arm bushing question Triumph 15
bcliff TR4/4A Triumph TR4A IRS FS. Need help with this one.PICS! Triumph 6
