TR6 TR4a and TR6 gas tanks interchangeable?
T
tdskip
Here is why I ask - check out this indentation on the TR4A tank I had dipped.
There was some artful bondo that made the indentation look smooth, but now that it is stripped it doesn't look quote so good.
Any issues using this tank (other than a slight loss of fuel capacity and aesthetics?
bgbassplyr
As long as it doesn't leak, use it. You're going to cover it up: so much for aesthetics.
Looks like PO used a hammer for clearence (?).
TR6oldtimer
The tanks are interchangeable as far as fitting them into the tub. There may be some additional fittings that will require a plug or two.
As far as the tank with the dent, as long as the metal is intact, it is still serviceable. Once installed, no one but you and everyone on this forum will know.
You could attempt to pull out the dent, but that could be a challenge.
The holes, if any, can be soldered up or better yet, a small piece of metal placed over the hole then sweat soldered. Just sure the tank is vapor free.
I would use the old tank, and destroy all the pictures of it.
HerronScott
What the heck were they thinking when they did that???
(and I didn't see a thing!).
Scott
T
tdskip
Hi Scott - I have <span style="font-weight: bold"><span style="font-style: italic">no</span></span> idea. Weird eh?
DougF
Let's hope some day you won't wish you had that extra pint of petrol.
AngliaGT
Tom,
We've seen it..... now you'll have to swear us
to secrecy,or kill us.
- Doug
HerronScott
Doug,
I was thinking the same thing...
Scott
DNK
If it is dented is the,has the capacity changed??
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 14
PeterK General TR Need a handbrake button and rod TR4a-TR6 Triumph 5
Sarastro TR4/4A Puzzled about TR6 door seals on a TR4A Triumph 7
Rut TR4/4A TR4a or TR6 top frame? Triumph 4
K TR4/4A Black marks on a TR4A/TR6 vinyl top boot cover? Triumph 4
Scotsman TR4/4A Can the TR6 exhaust go on a TR4A Triumph 5
B TR4/4A Possible to put TR6 seats in a TR4A Triumph 3
T TR4/4A Under the been there - done that school of learning: TR6 rear springs on a TR4a Triumph 12
T TR4/4A Converting TR4a from wire to TR6 steel wheels Triumph 7
T TR4/4A Anyone have pictures handy of TR4a with TR6 steel rims? Triumph 13
K TR6 Differences in Chassis on 67 TR4A and 73 TR6? Triumph 8
K TR6 Are TR6 dasboards the same as TR4A? Triumph 5
T TR6 TR4a IRS vs TR6 handling Triumph 20
britlover TR6 TR4A IRS body on a TR6 Frame?? Differences? Triumph 10
T TR6 SU or TR6 ZS carbs for my '66 TR4a? Triumph 18
M TR6 TR4A on a TR6 Frame? Triumph 19
rlich8 TR6 TR6 fan on a TR4A Triumph 3
T TR6 TR4a vs TR6 fulcrum pins [was TR4a shims] Triumph 31
T TR6 Differences between TR4a and TR6 convertible tops Triumph 14
T TR6 Anyone use TR6 rear springs in their TR4a IRS? Triumph 8
KVH TR6 TR4A/TR250/TR6 Triumph 5
T Wedge TR4a, TR6 and TR8 seat webbing's interchangeable? Triumph 2
T TR6 Fuel tank question - TR4a & TR6 truly identical? Triumph 3
TR4A_IRS TR6 Will all TR6 seats fit in a TR4A? Triumph 11
T TR6 Moving TR6 gearbox to TR4a - any issues? Triumph 5
T TR6 TR4A sway bar same as TR6? Use same bushings? Triumph 12
G TR6 TR4A & TR6 Marriage? Triumph 26
fad64b TR6 TR4A - TR6 clutch pressure plate??? Triumph 9
Paulus TR6 Changing a TR4A fan to a TR6 fan Triumph 3
B TR6 TR6 wheels fit a TR4A? Triumph 5
kindofblue TR6 TR6 seats in a TR4A Triumph 3
T TR6 Will a TR6 4 speed fit a TR4A Triumph 7
PeterK TR6 Installing a TR6 M/C, servo setup in a TR4A Triumph 5
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
RJS TR4/4A TR4A Seat Upholstery - Piping Question Triumph 7
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
RJS General TR TR4A Seat Rebuild Triumph 12
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
T TR4/4A Recommendation on top for a late TR4A Triumph 8
S TR4/4A Build Date Triumph TR4A IRS Triumph 3
R For Sale Tr4a parts Triumph Classifieds 2
Sarastro TR4/4A TR4A top's rear attachment Triumph 2
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
fpstude TR4/4A Steering U-Joint Question for TR4A Triumph 5
S For Sale Triumph TR4 and TR4A Factory Workshop Manual on CD/ROM - 1962 - 1968 Models Triumph Classifieds 0
G TR4/4A Vin # for TR4A Triumph 3
M TR4/4A Seats for TR4A Triumph 3
B TR4/4A TR3 valve cover on TR4A Triumph 4
T For Sale TR4A Grille Triumph Classifieds 0
K For Sale TR4A Intake Manifold..Put one on your TR3...improves air intake....cheap like borsht. Triumph Classifieds 2
