T
TRDejaVu
When I got the barn-find last year it was in a non-running condition. As I had the sump off for a look-see I decided to change the con rod bearings on spec. The crank journals seemed reasonable and I put standard size bearing shells back in. I also dropped the center main bearing cap to look at that bearing; it all looked reasonable. I also changed the thrust washers. I used lots of assembly lube and babied the RPMs; I still haven't taken it above about 3500RPM and I don't gun it or labor it.
From the time I got it running last fall until yesterday afternoon it had 70PSI pressure at 2000 and about 40PSI at idle. Took it out tonight and I noticed that it only reached 30PSI at 2500RPM and about 15PSI at idle.
Symptoms:
- I have done 2 oil changes after about 250 miles each and it gets dirty quickly. I put that down to the block flushing through.
- A few days ago, I started to notice a bearing knock sound at startup, but it quickly went away.
I would appreciate any ideas as to the suddenness of this?
Symptoms:
