TR4/4A TR4 - Rear wheel slot key removal
Dono
Greetings,
The studs on my L rear wheel came loose, about 3 miles from home. It sounded like a bad bearing, thought I'd hobble home. I have wire wheels. It wasn't the bearing but loose studs. By the time I got home it had damaged the 4 stud threads and rounded open the outer wheel part w/ splines that the wire wheel attaches to. I need new parts.
How is that key / pin that holds the inner plate w/ studs removed?
Thanks, Dono
TR3driver
Great Pumpkin - R.I.P
The piece that carries the studs (most call it a hub) isn't held by the key, but by a "locking" taper between it and the axle shaft. There is a special tool required to remove it from the shaft.
However, if you just need to change the studs, you can leave the hub on the shaft. Undo the 6 bolts and lockplates that go in from the back, then pull the axle out with the hub still attached. That will give you easy access to the back of the studs, so you can grind away where they are staked to the hub, and unscrew them. Screw in the new studs (preferably with some Loctite) and stake them in place.
If you do need to pull the hubs off, I would suggest removing the axles anyway, and taking (or shipping) them to someone that has the proper tool. Don't let someone with a hydraulic press try to force them apart, as that frequently distorts and ruins the hub.
This photo shows a small Triumph hub being removed, but the tool & process are similar for your TR4.
Dono
Thanks for the response Randall.
Q: In para 2, you mention grinding the back of the studs, then unscrewing them? Why grind, if they're screwed in? In the Victoria British sales guide it shows the studs and they appear to screw in from the front side. So something must be ground off the back? Thanks, Don
Geo Hahn
They're screwed in then the backside is swaged (mushroomed, mooshed, whatever).
Randall mentions the taper fitting that locks the hub in -- that connection makes 'The Sword in the Stone' look like a hot knife in butter.
Love that photo -- you only see the guys hands -- I suspect he's a Sumo wrestler on steroids.
Dono
Randall, or anyone -
I did as suggested, left the hub on the exle and removed the 6 bolts behind the brake plate. All the axle came out. I ground the back of the 4 studs flat, but they do not appear to unscrew. I presume lefty losie. I all so heated one w/ my torch and it wiggles, like it is only pressed in. Are they screwed in? Left or right loosen?
I can't imagine they'd only be pressed in since they do hold the axle & wheel to the car.
Thanks, Don
TR3driver
They are threaded, then swaged (spread until they lock into place). You either didn't get all the swaging ground away, or didn't apply enough force to unscrew them. The only time I've done it myself (on a TR3A), I had to grind into the end of the stud slightly, and then it visibly crushed a bit as it came out. Threads are normal RH threads, so "lefty loosey" is correct.
bgbassplyr
Still tight? May be rusted. Try a dose of 'weasel pee' to loosen the studs, 50% ATF and Acetone. Will not make a solution, only a suspension, so shake well and then apply.
TR4nut
Don't forget the dreaded previous owner. You may have conventional pressed in studs there - was the back of the studs standing proud of the hub? If so, I suspect replacement press-ins, as the peened versions are pretty flush with the hub.
Dono
Greetings,
Thank you all for the assistance. After cutting a slot into the threaded end of the stud, placing some rust buster on it overnight, and much torquing, I still cannot break any of the studs loose, so I surrender, and called Scott Harper for a hub. He had a used one available for a straight axle TR4, and a new outer hub & nuts. I'll have a local shop pull the inner hub and will then repack the bearings as part of the repair when I get the parts.
Thanks again for the suggestions. Don
J TR4/4A Replacing TR4 rear wheel studs Triumph 2
KVH TR4/4A TR4 Rear Wheel Studs Triumph 6
6 TR4/4A Advice on stripped Rear Hub wheel stud for TR4 Triumph 24
Lotuswins Wanted TR4 H6 rear carb body Triumph Classifieds 4
T For Sale TR4 TR250 Rear Fenders Triumph Classifieds 2
P Wanted 1963 TR4 passenger fender rear Triumph Classifieds 2
busybrit Wanted TR4, TR4A, TR250 Rear light WANTED Triumph Classifieds 0
S TR4/4A TR4 front and rear suspension Triumph 8
Gerald_Gordon TR4/4A Routing of wiring harness to the rear of a 1961 TR4 Triumph 8
M TR4/4A TR4 with Surrey Top......Rear seat upholstery assistance please. Triumph 2
D TR4/4A Seals on TR4 Solid Rear Axle Triumph 5
Popeye TR4/4A Rear leaf spring - do I have a TR4 spring on my 4A?? Triumph 4
Got_All_4 TR4/4A TR4 Detroit Locker Positraction Rear End Triumph 6
K TR2/3/3A TR4 rear leaf spring "distance piece"? Triumph 1
M TR4/4A tr4 zip out rear window Triumph 6
B TR4/4A TR4 Rear Leaf - Do I need distance piece? Triumph 5
Willie_P TR4/4A Girling brake drums/rear innards - tr4 Triumph 6
F TR4/4A TR4 rear trim Triumph 2
Willie_P TR4/4A TR4 rear brake cyl. - what's this thingamajigger? Triumph 5
TR4v8 TR4/4A tr4 rear axle width Triumph 0
doughairfield TR4/4A TR4 Rear Hub removal Triumph 14
M TR4/4A TR4 rear sway bar installation Triumph 15
CinneaghTR TR5/TR250 TR4/RA/250 Rear Bumper Installation Triumph 3
R TR4/4A TR4-A rear fender Triumph 12
G TR4/4A tr4 rear end in a tr3a Triumph 10
J TR4/4A TR4 rear suspension Triumph 8
TR4 TR4/4A Removing a rear fender on a TR4 Triumph 7
T TR4/4A Early TR4 Rear Suspension & Tube Shock Conversion Triumph 13
T TR4/4A Early TR4 Rear Suspension Triumph 22
R TR4/4A TR4 IRS coil over rear suspension Triumph 3
Tabcon TR4/4A TR4 Rear Brake Parts? Triumph 25
M TR4/4A Last question about original rear main sealTR3 TR4 Triumph 17
SCguy TR4/4A lost link... TR4 rear shock rebuild Triumph 4
Tabcon TR4/4A TR4 Rear Suspension Upgrades Triumph 15
T TR4/4A TR4 Rear Leaf Spring Mounts Triumph 6
T TR4/4A '62 TR4 rear end clunk Triumph 10
SCguy TR4/4A TR4 rear axle piece fell of into my hand? Triumph 21
KVH TR4/4A TR4 Rear End Again Triumph 4
KVH TR4/4A TR4 Rear End Again Triumph 0
PeterK TR4/4A TR4 Rear track bar pictures and info needed Triumph 6
macino62 TR4/4A TR4 rear tube shock conversion Triumph 5
D TR4/4A TR4 rear diff pinion seal Triumph 4
KVH TR4/4A Rear Oil Galley Plug and Flywheel Bolts TR4 Triumph 6
T TR4/4A Early TR4 - Rear Leaf Springs Triumph 3
T TR4/4A Early TR4 - Rear Brake Cylinder Installation Triumph 5
T TR4/4A Early TR4 - Rear Brakes Triumph 1
T tr4-rear tube shocks Racing 2
P TR4/4A tr4 rear hub problem Triumph 16
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
P Wanted WTB Restorable TR4 Triumph Classifieds 3
