TR4/4A TR4 Rear End Again
KVH
After boasting of the great job I did on the rear cover plate of the differential, it now appears I may have a leak in the front seal where the driveshaft connects.
I'm not looking forward to confirming that, but I assume it will be no small job when I get to? Remove entire rear end?
Thanks.
Geo Hahn
PeterK said:
btdt. If you can get the car on a lift, it is a pretty easy job...
KVH -- At least 2 of our local club members have lifts... might be able to wangle some time on one of them.
Maybe even call it an official tech session (though usually there is someone present at those who has actually done the job before).
In any case, I would be willing to help -- if we don't break your car then I will do mine too.
PeterK
The slide hammer is key to getting the old one out. Make sure to buy NEW lock nuts for the propshaft before you start. You will need 8 3/8"-24 nuts.
Often the sealing surface on the flange is rough and pitted. If is is too far gone to dress with emery paper, a speedi-sleeve ($35 from Moss) installed over the flange will give you a permanent repair for proper sealing.
KVH
KVH
Man! What a great Board this is! Advice right on the mark. No wonder TRs are still so popular, and on the road, too.
Thanks, all.
Got_All_4 TR4/4A TR4 Detroit Locker Positraction Rear End Triumph 6
G TR4/4A tr4 rear end in a tr3a Triumph 10
T TR4/4A '62 TR4 rear end clunk Triumph 10
KVH TR4/4A TR4 Rear End Again Triumph 0
Lotuswins Wanted TR4 H6 rear carb body Triumph Classifieds 4
T For Sale TR4 TR250 Rear Fenders Triumph Classifieds 2
P Wanted 1963 TR4 passenger fender rear Triumph Classifieds 2
busybrit Wanted TR4, TR4A, TR250 Rear light WANTED Triumph Classifieds 0
S TR4/4A TR4 front and rear suspension Triumph 8
Gerald_Gordon TR4/4A Routing of wiring harness to the rear of a 1961 TR4 Triumph 8
M TR4/4A TR4 with Surrey Top......Rear seat upholstery assistance please. Triumph 2
D TR4/4A Seals on TR4 Solid Rear Axle Triumph 5
Popeye TR4/4A Rear leaf spring - do I have a TR4 spring on my 4A?? Triumph 4
K TR2/3/3A TR4 rear leaf spring "distance piece"? Triumph 1
M TR4/4A tr4 zip out rear window Triumph 6
B TR4/4A TR4 Rear Leaf - Do I need distance piece? Triumph 5
Willie_P TR4/4A Girling brake drums/rear innards - tr4 Triumph 6
F TR4/4A TR4 rear trim Triumph 2
Willie_P TR4/4A TR4 rear brake cyl. - what's this thingamajigger? Triumph 5
J TR4/4A Replacing TR4 rear wheel studs Triumph 2
TR4v8 TR4/4A tr4 rear axle width Triumph 0
doughairfield TR4/4A TR4 Rear Hub removal Triumph 14
M TR4/4A TR4 rear sway bar installation Triumph 15
CinneaghTR TR5/TR250 TR4/RA/250 Rear Bumper Installation Triumph 3
R TR4/4A TR4-A rear fender Triumph 12
D TR4/4A TR4 - Rear wheel slot key removal Triumph 8
J TR4/4A TR4 rear suspension Triumph 8
TR4 TR4/4A Removing a rear fender on a TR4 Triumph 7
T TR4/4A Early TR4 Rear Suspension & Tube Shock Conversion Triumph 13
KVH TR4/4A TR4 Rear Wheel Studs Triumph 6
T TR4/4A Early TR4 Rear Suspension Triumph 22
6 TR4/4A Advice on stripped Rear Hub wheel stud for TR4 Triumph 24
R TR4/4A TR4 IRS coil over rear suspension Triumph 3
Tabcon TR4/4A TR4 Rear Brake Parts? Triumph 25
M TR4/4A Last question about original rear main sealTR3 TR4 Triumph 17
SCguy TR4/4A lost link... TR4 rear shock rebuild Triumph 4
Tabcon TR4/4A TR4 Rear Suspension Upgrades Triumph 15
T TR4/4A TR4 Rear Leaf Spring Mounts Triumph 6
SCguy TR4/4A TR4 rear axle piece fell of into my hand? Triumph 21
PeterK TR4/4A TR4 Rear track bar pictures and info needed Triumph 6
macino62 TR4/4A TR4 rear tube shock conversion Triumph 5
D TR4/4A TR4 rear diff pinion seal Triumph 4
KVH TR4/4A Rear Oil Galley Plug and Flywheel Bolts TR4 Triumph 6
T TR4/4A Early TR4 - Rear Leaf Springs Triumph 3
T TR4/4A Early TR4 - Rear Brake Cylinder Installation Triumph 5
T TR4/4A Early TR4 - Rear Brakes Triumph 1
T tr4-rear tube shocks Racing 2
P TR4/4A tr4 rear hub problem Triumph 16
P Wanted WTB Restorable TR4 Triumph Classifieds 2
A TR4/4A TR4 Overdrive Solenoid Triumph 19
