TR2/3/3A TR3A Wing beading
mapleaf
For the past ten years or so, the wing beading between the scuttle panel and front fender of my TR3A has been loose. So rather than continuing to push it down every time I pass I've decided to try to fix it. I would like to know the proper way for securing the wing beading tabs between the scuttle panel and fender? Any advice will be greatly appreciated.
prb51
I'm not sure exactly where your beading is popping out but some here have riveted there beading in place to the outer wing. They've used a small rivet on the tabs spaced evenly between the bolt patern.
This also make removing the apron easier as you don't have to worry about errant beading dangling in the air.
Arrow
I have three TR-3s I just looked and all three bee\adings are installed the same. Along the hood area the long sliver of steel sticking down is either pop rivited in orhas small screws into the fender. Behind the hood or just in front of the door the tabs stick down and are basically clamped between the fender and the cockpit. At the front the tabs are likewise squeezed between the front apron and fender. I suspect if you gave the slipping tab a slight twist it would add to the friction fit. Another solution would be to solder another sliver of steel to the tab making them slightly thicker.
martx-5
Arrow said:
... Behind the hood or just in front of the door the tabs stick down and are basically clamped between the fender and the cockpit...
If this is the area you are refering to, there is a bolt (7/16" hex head) accessible from inside. There is a hole in the inner panel that you can stick a socket and extention through. You may be able to tighten that screw up and clamp the beading in place. You may have to peel back the interior trim to gain access to the hole if your trim does not have a hole in it. It's up pretty high on the panel.
NickMorgan
When you re-fit wings and beading you should aim to have the metal tabs just above the wing bolts. This will stop the tabs all sliding down to the bottom. You can always temporarily tape them in position until all of the bolts are in place.
As your wings are already in situ, you can either locate the metal tabs on the underside of the wings and bend them straight and re-bend them to tighten the beading, or alternatively, on one TR I had the tabs had been pulled down and then twisted. Although this is effective it created a lovely sharp edge to catch your hands on.
Russ Austin
Art is correct there is a hole on the inside that will give you access to a cage nut, check and see if you can tighten the bolt and that should get it.
Don Elliott
I MIG welded a 2" long bolt to the top of thr head of the normal last bolt near the door and stanchion base that secures the fender up behind the carpet in the sidewall of the footwell and this re-design makes it much easier to tighten the bolt plus washers because the second bolt is only just inside the hole and you can see it and easily fit a socket onto it to tighten it.
M
mapleaf
Thanks for info, guys. I removed the carpet from the side of the footwell and found that the bodyman apparently forgot to replace the fender bolts on both sides. Should be an easy fix now. I've also got the apron off the car to have the rad recored so the other wing beading tips will be helpful when I get around to putting it back together. Thanks again.
M TR2/3/3A Loose wing beading TR3A Triumph 4
71TR6 TR2/3/3A TR3A Wing to Apron Mismatch Triumph 9
M TR2/3/3A TR3A Wind Wing Hardware Triumph 10
Tinkerman TR2/3/3A TR3A Rear Wing Clamp Installation Triumph 14
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph For Sale Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
J TR2/3/3A TR3A Finally on the Road! Triumph 6
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Hamish Racing TR2/3/3A Harewood hill climb Yorkshire TR3a Triumph 3
Hamish Racing Harewood Hill Climb Yorkshire TR3a Racing 0
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
Hamish Racing General TR TR3a hillclimb Thumdrrstorm video uk Triumph 4
Hamish Racing General TR TR3a faster that a Lamborghini Huracan STO ?? Triumph 6
W For Sale 1960 TR3A for sale Triumph Classifieds 0
D TR2/3/3A tr3a occasional seat padding Triumph 10
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
Hamish Racing TR2/3/3A Greenville TR3a V8 ? Triumph 8
T TR2/3/3A Would like a paper pattern for TR3A hood stick cover Triumph 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
T TR2/3/3A TR3A Windshield Question Triumph 4
Hamish Racing TR2/3/3A Anglesey (Wales) TR3a track videos Triumph 3
RonC TR2/3/3A TR3A Hardtop Seals Triumph 7
T TR2/3/3A TR3A Disk Brake Question Triumph 10
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
Hamish Racing TR2/3/3A TR3a British Hill Climb Shelsley Walsh Triumph 8
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
T For Sale TR3A Original Radiator Triumph Classifieds 3
Hamish Racing TR2/3/3A TR3a Faster Lap Times than a Ferrari F430 ?? Triumph 1
Hamish Racing UK hill climb TR3a Racing 0
Hamish Racing TR2/3/3A TR3a UK hill climb video Triumph 4
Hamish Racing TR2/3/3A 3 sisters fun in a TR3a ! Triumph 5
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
Hamish Racing General TR TR3a and TR7V8 Shelsley Walsh Hill climb action Triumph 0
Hamish Racing TR2/3/3A Fast and wet TR3a Triumph 0
