TR2/3/3A TR3A Rear Axle Picture
rlandrum
I'm in need of a rear axle picture. I believe I have my backing plates in the wrong place and may need to move them down 1 hole.
The cables are at an angle. Everything works, but it just doesn't seem right.
Rob
Don Elliott
Here is one from 1988 when I was doing the restoration of my 1958 TR3A - exactly like it was originally. If this is not what you need, tell me what you want. I have others.
Banjo
Jumpin jupiter Don! that's nice. Mine's gonna look like that sometime......
rlandrum
rlandrum
Yep... mine are 1 bolt hole higher than that.
It occurs to me that the brake line would be at a pretty tight bend there, since the cylinder is right in front of the spring.
PeterK
There are also 3 locking plates that lock the hex nuts on each axle/hub. I can't see them on Don's chassis in the picture.
TR3driver
Great Pumpkin - R.I.P
Interesting ! I'm pretty sure they're supposed to be there ... have been on all my TRs. SPC shows them from 13046 onwards (including TR4). And I just felt TS13571L, it has em too.
DNK
Oh dear, Don, you have to give back all those trophys
Tinkerman
Yep, there on mine also, course I put them there, heh
Tinkerman
Twosheds
The locking tabs were on my old racecar, and bent over the bolt heads, but the bolts were loose!
When I had the rear overhauled, the overhauler used lockwashers. He said he didn't trust locking tabs.
TR3driver
A disadvantage of locktabs (and Loctite) : difficult to retorque to cover bolt stretch and/or locktab crush.
Don Elliott
I can only guess that in the three years between taking my TR3A all apart and putting it together again, well what is it called, "a senior moment or three years?"
I have lock washers on there and they never seem to come loose.
On the one I finished in 2006, I guess I used my photos as guides. In the case with that TR3A, it was 10 years between dis-assembling it all and finishing it.
NickMorgan
See what happens when you display your intimate parts on this forum!!
Don,
You see that little clip that holds the brake line onto the rear diff cover, is there an easy way to unclip the brake pipe from it? I couldn't see a way of separating them when I wanted to replace the leaking diff gasket.
Nick
rlandrum
rlandrum
I purchased new tabs to replace the rusted ones I removed. I have yet to bend them over specifically because I wasn't positive about the position of the backing plates.
I replaced almost all of the hardware, actually. There are a few studs I haven't replaced, and the lock washers and bolts on the brake calipers, and the 3.5 inch bolts on the front hubs. Aside from that, new lock washers and nuts or new nylocks are the rule. All Grade 8s.
TR3driver
Been a long time ago, but ISTR that after removing all the cover bolts, I could work the pipe out of the clip by moving the cover and then pull it free without disconnecting the line.
rlandrum
rlandrum
Here's a picture that has me puzzled...
This backing plate had no hardware attached to it, so it may have once been off the car...
As you can see, the backing plate is oriented with the adjuster BELOW the level of the frame. In both pictures above, the adjuster is ABOVE the level of the frame.
In this picture, the driver side is pointed straight up, which suggests it matches the passenger side.
TR3driver
Yup, it's installed wrong. The orientation shown in Don's photo is correct.
Looks like you could use a new pinion seal and LH shock, too.
CraigLandrum
Just looked in the brake section of the "How to Restore a TR3" book and it also shows that my son a I got the position one bolt off...Not too bad to change them - I think I'm getting so I can put the brake shoes and springs back on in less than 60 seconds :smile:
The real pain will be rebending that %%^&(& brake line....
TR3driver
No doubt a big advantage of having the body off and the proper tools. I recall it being more of a pain in the neck, with the body on and only an open end wrench. Seemed like it took forever to wind those bolts out, one flat at a time.
Then I learned the hard way that TR4 rear axles are not the same as TR3 ... Duh !
MGTF1250Dave TR2/3/3A TR3A Rear Axle Pinion Oil Seal Replacement Triumph 8
M_Pied_Lourd TR2/3/3A TR3A Rear Axle Help Triumph 25
F Wanted TR3A rear seat peg and clip Triumph Classifieds 2
J TR2/3/3A TR3A Girling 9" Rear Brake Initial Adjustment Triumph 9
M TR2/3/3A Difficulty Adjusting Tr3A Rear Brakes Triumph 12
T TR2/3/3A TR3A Hardtop Rear Mounting Brackets Triumph 15
D TR2/3/3A assembly, TR3A rear fender and radiator stays Triumph 22
JFS TR2/3/3A TR2 Rear Plate Lite on TR3A Triumph 10
Got_All_4 TR2/3/3A Triumph tr3a occasional rear seat Triumph 14
JohnnyMead TR2/3/3A TR3A Rear Wheel Cyl Assembly Question Triumph 5
luke44 TR2/3/3A TR3A Rear Trim Panel Triumph 7
M_Pied_Lourd TR2/3/3A TR3A Rear Bumper Distance Tubes Triumph 11
tinman58 TR2/3/3A TR3a rear Diff seal Triumph 8
TR3Dad TR2/3/3A TR3A Loud Buzz & Rear Axel Triumph 3
T TR2/3/3A TR3A rear valance lower seam Triumph 2
M_Pied_Lourd TR2/3/3A TR3A Rear Close Out Panel Triumph 5
J TR2/3/3A TR3A rear view mirror placement Triumph 13
K TR2/3/3A Needs Picture of Rear TR3A Brake Assembly Drum Off Triumph 6
M_Pied_Lourd TR2/3/3A TR3A Rear Valence Triumph 12
PatGalvin TR2/3/3A Rear Half of TR3A Tub for Parts or Scrap??? Triumph 9
Tinkerman TR2/3/3A Rear Valance TR3A post 60000 Triumph 6
G TR4/4A tr4 rear end in a tr3a Triumph 10
M_Pied_Lourd TR2/3/3A TR3A Rear Body Mount/Spare Tire Compartment Repair Triumph 42
M_Pied_Lourd TR2/3/3A TR3A Rear Brakes Triumph 5
H TR2/3/3A TR3A Rear Bumper Triumph 5
H TR2/3/3A TR3A Rear Bulkhead Triumph 9
ekamm TR2/3/3A Rear seat tr3a Triumph 4
Don Elliott TR2/3/3A Stripped threads - TR3A block RHS rear ead stud Triumph 9
K TR2/3/3A TR3A: Refilling rear shocks? Triumph 4
Tinkerman TR2/3/3A TR3A Rear Wing Clamp Installation Triumph 14
Tinkerman TR2/3/3A TR3A Rear Fender Stone Guards Triumph 4
M_Pied_Lourd TR2/3/3A TR3A Rear Brake Opinions Triumph 12
Got_All_4 TR2/3/3A Needed TR3A front and rear fenders Triumph 4
CraigLandrum TR2/3/3A TR3A Rear Seat Questions Triumph 13
mcguijo TR2/3/3A Clamp plate on Rear Fender TR3A Triumph 16
J TR2/3/3A TR3A Rear Brake Cylinders Triumph 1
T TR2/3/3A TR3A rear end ratio Triumph 1
T TR2/3/3A Tr3A rear main seal conversion - adviced needed Triumph 11
P TR2/3/3A TR3A Rear Crankshaft Seal Triumph 2
Don Elliott TR2/3/3A Late TR3A Rear Interior Support Triumph 11
G TR2/3/3A TR3A rear fender captive bolts Triumph 7
C TR2/3/3A TR3A 10 inch rear brakes Triumph 7
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph For Sale Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
