TR2/3/3A TR3A New Brake pads binding to New drum?
karls59tr
Bronze
The drums don't want to spin freely. Everything is new and freshly assembled. Hydraulics not installed yet.Brake cable adjusted. Any ideas on what may be overlooked?
Geo Hahn
Seems like some shoes are oversized -- one theory I heard was that they are made on the assumption that 50 year old drums will have been turned some. I had to remove some material from the Classic Gold ones I installed to make them work.
TR3Dad
I had dragging shoes on my car, it turned out to be a sticking wheel cylinder. However, you said the hydraulics are not hooked up.
One other thing to look at is the eccentricity of the hub the drum mounts on. I have one that was slightly bent and I only noticed it when I had all 4 wheels off the ground and watched the wheels spin while in gear. The wheel itself was not bent but the hub the drum mounted on was, causing extra drag.
Good Luck
TR4nut
The 10" shoes I put on my 3A were oversized, I had to remove material as well.
TR3driver
Great Pumpkin - R.I.P
"Back when", shoes were commonly supplied slightly oversized. The dealer had a machine that would grind them down to match your drums. The difference in effectiveness (from being arced to match the drums) was quite noticeable.
But I've not seen such a machine for a long time. If you can turn them by hand, then don't worry about it. They will quickly wear down once you start driving the car.
Er, you do have the adjuster backed off all the way, right?
T TR2/3/3A TR3A Disk Brake Question Triumph 10
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
J TR2/3/3A TR3A Girling 9" Rear Brake Initial Adjustment Triumph 9
C TR2/3/3A TR3A clutch/brake cylinder rebuild Triumph 4
A TR2/3/3A 1960 TR3A front brake dust covers Triumph 5
B TR2/3/3A TR3A Brake rotors Triumph 2
T TR2/3/3A Wanted: Tr3a lft frnt brake caliper Triumph 3
J TR2/3/3A Brake Bleeding problem on a TR3A Triumph 19
PatGalvin TR2/3/3A Brake Master Cylinder Fluid Reservoir Bracket needed, TR3A Triumph 6
Bremer TR2/3/3A TR3A: Strange brake bleeding behaviour Triumph 4
V TR2/3/3A TR3A Brake Pedal - Too Much Travel Triumph 6
Tugboat TR2/3/3A TR3A Brake Line Triumph 2
Q TR2/3/3A Using DOT 5 Brake Fluid On TR3A Triumph 34
K TR2/3/3A TR3A Brake caliper thread chaser? Triumph 2
R TR2/3/3A TR3A front brake cailper leaking Triumph 7
K TR2/3/3A Girling 10" Brake Backplate TR3A? Triumph 1
R TR2/3/3A TR3A Girling Brake Callipers Triumph 7
Got_All_4 TR2/3/3A Why is my brake light continuously on TR3A Triumph 10
Parker TR2/3/3A TR3A Brake drum removal: RUST! [Arghhhhhh] Triumph 23
K TR2/3/3A Needs Picture of Rear TR3A Brake Assembly Drum Off Triumph 6
T TR2/3/3A TR3A clutch&brake master cylinders Triumph 11
deadair TR2/3/3A TR3A -- Vacuum Bleeding Girling Brake System Triumph 13
deadair TR2/3/3A TR3A -- Removing front brake pistons Triumph 19
PatGalvin TR2/3/3A Toyota Brake Conversion on a TR3A Triumph 5
M_Pied_Lourd TR2/3/3A TR3A Front Brake Caliper Choice Triumph 5
T TR2/3/3A TR3A brake light activation Triumph 27
T TR2/3/3A TR3A Brake distribution block Triumph 12
JohnnyMead TR2/3/3A TR3a Brake Shoes Triumph 3
M_Pied_Lourd TR2/3/3A TR3A Rear Brake Opinions Triumph 12
Don Elliott TR2/3/3A Brake Switch TR3A Triumph 4
J TR2/3/3A TR3A Rear Brake Cylinders Triumph 1
rlandrum TR2/3/3A TR3A Disk Brake Rebuilding Triumph 9
T TR2/3/3A Brake dust - TR3A Triumph 2
K TR2/3/3A TR3A Park Brake Compensator Bar Assembly Picture? Triumph 7
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph For Sale Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
J TR2/3/3A TR3A Finally on the Road! Triumph 6
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Hamish Racing TR2/3/3A Harewood hill climb Yorkshire TR3a Triumph 3
Hamish Racing Harewood Hill Climb Yorkshire TR3a Racing 0
