TR2/3/3A TR3A Door latch alignment
tmc
I'm working on installing the door latches/hardware. When I position the striker plate in the holes/"nut plates" provided, my door sticks out more than a 1/4 inch at the back edge when latched. Without the striker plate in there, the doors fit very well, the hinges are right and tight and the door latch assembly can't be "adjusted". The holes in the door jamb/post give some "wriggle" room but nowhere near enough. I got the striker plates from Moss. I can't find the old ones in my parts heap, so can't tell if the new ones are wrong. I'm stumped. Jim Beam and I are going to think about it on the porch for awhile.
Suggestions?
mallard
I think I may have had the same concern that you have. I later found out that the when the door is closed all the way the catch should be on the back side of the plate. I was thinking it should have been in the hole in the striker plate.
M_Pied_Lourd
I was trying to think of a way to describe this as well as I know that to me it looked like mine wasn't going to close properly either. I think that there was a discussion on here a few months ago about the same thing....I tried to find the thread in a search but couldn't come up with it.
Cheers,
M. Pied Lourd
CJD
I had that problem on one of my doors. I wound up opening the holes on the b-post for the nuts a little with a die grinder. That only got me so far, since the nuts are still captured from the back side. I then had to grind about 1/16" off the back of the latch plate The latch is chromed brass...so it is at the chrome shop right now getting re-chromed.
I wish i could say it was easier, but it took quite a while to get the perfect fit.
Oh, there is one easy thing that may get yours aligned. The guides on the top and bottom of the latch are meant to be bent around the striker plate to securely position the door when it is closed. Check to make sure these are not binding on the new striker plate...as they may be preventing the full closure of the door. If they move the plate up or down slightly, it may move the plate to a position not allowing full in-out adjustment...because the plate mounting holes are round. Not likely, but possible.
My other door fit fine without any massaging.
John
sp53
Hi John my driver door does not close right either and if I am understanding your post correctly you made the hole larger in the center of the striker plate so the moving plunger piece of the door mechanism can fall into the latch plate easier? In addition, you exposed some of the inner metal bolt cage by removing a small amount of the actual body tub around the latch holes on the B post to gain more adjustment.
Steve
tmc
tmc
So..........what's the rectangular hole in the middle of the striker plate there for? It fits the latch bolt so nicely!
tmc
tmc
John
I'm just glad to see that I'm not the only one that had to "massage" the d*mn thing! Jim Beam and I decided to cool it for a few days on the TR3 project and go fishing instead.
mallard
I don't know why they don't use the hole for the catch. It would make a lot of sense, as it does fit very nice. The door should have a double click when you shut it all the way. The door latch has the two folded over tabs to keep the door in alignment when driving. Does your door fit when you have the latch pin behind the striker plate?
tmc
tmc
I don't know.....never even crossed my mind to try that! I've sworn off working on the TR for awhile, but I'll check that out when I get back at it.
CJD
Steve
To elaborate, I took the material off the very back of the plate, not the middle hole. When I was finished, the only way you could tell it was different from original would be to hold two strikers right next to each other...and the fact the brass was exposed. If you do this, you'll have to re-chrome to get the silver back.
My door was so far off when I started that I even tried making it fit using the center hole. It was almost exactly off by half the distance between the hole and the inside (or back) face of the striker. I only figured out the door should have a "double click" by getting frustrated and moving to the other door, which fit VERY easily...thank goodness. The oddest thing is that the easy door was the one I had replaced the sill and quarter panel. The hard door had the original sill and quarter. Go figure!?!
Every time I work on the TR I picture some old war vet standing there 50 years ago, smoking his pipe and taking all day to fit a single door...but not really caring in the least that it does. A different day and age!
John
CJD
Got the latches back from the chrome shop. Here are some pics
MGTF1250Dave TR2/3/3A TR3A Door Handle Latch Part Needed Triumph 9
G Wanted - Glove Box Door for a TR3A Triumph Classifieds 2
T TR2/3/3A TR3A Door Handle Triumph 3
T TR2/3/3A What is the purpose of the groove behind TR3A door ? Triumph 6
bertl TR2/3/3A Tr3A Door Cap Triumph 3
TR4nut TR2/3/3A TR3A door seal question Triumph 7
Q TR2/3/3A TR3A Spare Tire Door Seal Triumph 3
PatGalvin TR2/3/3A TR3A Door Handle Key Question Triumph 12
PatGalvin TR2/3/3A TR3A Door Question Triumph 17
T TR2/3/3A TR3A door post packing Triumph 9
CJD TR2/3/3A TR3A Door Seals Triumph 12
ekamm TR2/3/3A tr3a door interior panel Triumph 2
Number_6 TR2/3/3A TR3A Passenger door Triumph 11
NutmegCT TR2/3/3A TR3A door "draft seal" Triumph 3
mcguijo TR2/3/3A TR3A Door Triumph 17
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph For Sale Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
J TR2/3/3A TR3A Finally on the Road! Triumph 6
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Hamish Racing TR2/3/3A Harewood hill climb Yorkshire TR3a Triumph 3
Hamish Racing Harewood Hill Climb Yorkshire TR3a Racing 0
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
Hamish Racing General TR TR3a hillclimb Thumdrrstorm video uk Triumph 4
Hamish Racing General TR TR3a faster that a Lamborghini Huracan STO ?? Triumph 6
W For Sale 1960 TR3A for sale Triumph Classifieds 0
D TR2/3/3A tr3a occasional seat padding Triumph 10
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
Hamish Racing TR2/3/3A Greenville TR3a V8 ? Triumph 8
T TR2/3/3A Would like a paper pattern for TR3A hood stick cover Triumph 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
T TR2/3/3A TR3A Windshield Question Triumph 4
Hamish Racing TR2/3/3A Anglesey (Wales) TR3a track videos Triumph 3
RonC TR2/3/3A TR3A Hardtop Seals Triumph 7
T TR2/3/3A TR3A Disk Brake Question Triumph 10
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
Hamish Racing TR2/3/3A TR3a British Hill Climb Shelsley Walsh Triumph 8
