TR2/3/3A TR3A Crank pulley removal
tinman58
Pat
What are you working on now?
I would spray the crap out of it with wd-40 and some tapping with a rubber mallet.
DornTRoriginal
I would use PB Blaster, lots of it and let it work in for a while. I had a simalar situation I used a puller with a modified brace and lots of tapping... good luck!
Tugboat
Pat,
I used a bearing puller on mine, which I knew I was going to replace, which was good as I really mangled the thing getting it off.
Mike
TR4nut
Thread the dog bolt back in and then use a bearing puller - hopefully you can be luckier than Mike and not bend things, sometimes they are stuck, but quite often just the puller will persuade it off with no issues.
Moseso
All I can say is, "Ooooohhhh -- that really looks rusted-on there." The crank is worth a LOT more than the pulley. Be careful which you destroy in the separation process.
TR3driver
Great Pumpkin - R.I.P
I use a "harmonic balancer" puller, plus a bolt that fits into the threads in the crank (5/8 NF IIRC) and two bolts that fit through the holes in the hub. On my 3A, the crank nose was worn undersize, so I used Loctite to mount the hub on the crank. Took quite a bit of force to get it off, but the puller did it several times without damage to anything.
My puller only has 2 arms, but apparently they only sell 4-arm pullers these days. Certainly won't hurt if you want to use 3 or even 4 bolts, but two worked fine for me.
PatGalvin
PatGalvin
Pat
Hi Dan
Just pulling a crank out of a spare engine - was planning on selling it. No new projects (I have plenty).
Hope to see you at the Scottish Games in Pleasanton this weekend.
Pat
tinman58
Pat
We will be there on Saturday!
I have about 5 more LBC's coming. See you Saturday.
D TR2/3/3A TR3A Crank Dog Triumph 2
Hamish Racing TR2/3/3A TR3a track fun in uk Triumph 2
F TR2/3/3A TR3A tub assembly Triumph 44
F Wanted TR3A control head parts (trafficator) Triumph Classifieds 1
D TR2/3/3A TR3A electrical issues Triumph 2
R TR2/3/3A TR3A Coil/condenser problem Triumph 22
C TR2/3/3A TR3A clutch/brake cylinder rebuild Triumph 4
B TR2/3/3A TR3a steering box rebuild Triumph 19
BritBob TR2/3/3A Part restored TR3A in Oregon Triumph 0
Hamish Racing General TR UK SPRINT RACE in my TR3a Triumph 5
T For Sale - 1961 TR3A Steering Box Triumph Classifieds 6
G For Sale: Triumph TR2, TR3, TR3A Sheet Metal Body Parts – Front Apron (valence) with grille, Bonnet (hood), Doors, Boot (trunk) Deck Lid Triumph Classifieds 3
G For Sale: Triumph TR2, TR3, TR3A, TR3B Factory Steel Hardtop, New Rear window, Partial Bracket Set Triumph Classifieds 2
T TR2/3/3A TR3A rack & pinion conversion question - solution for horn & directional lever Triumph 2
Donald1107 59 TR3A Fuel Pump Triumph 48
D TR2/3/3A 1961 Triumph TR3a Triumph 17
D For sale. TR3A Bellcrank Pivot and lever. Triumph Classifieds 0
M TR2/3/3A Difficulty Adjusting Tr3A Rear Brakes Triumph 12
60TR3A TR2/3/3A How To Jack Up a TR3A Triumph 14
Hamish Racing TR2/3/3A Fast Road TR3a on figure of 8 sprint track - UK Triumph 10
71TR6 TR2/3/3A TR3A Scuttle Rim Question Triumph 4
71TR6 TR2/3/3A TR3A Wing to Apron Mismatch Triumph 9
G Wanted - Glove Box Door for a TR3A Triumph Classifieds 2
71TR6 TR2/3/3A TR3A Breather Tube Attachment Triumph 6
S Price check on TR3A valve cover Triumph Classifieds 0
G 1962 TR3A inner plate # Triumph 8
G 1960 TR3A for sale $9,999 or best offer! Triumph Classifieds 3
71TR6 TR2/3/3A TR3A SU Carb rebuild opinions requested Triumph 12
71TR6 TR2/3/3A TR3A Front Sway bar- how to install? Triumph 5
71TR6 For Sale TR3A Roll Bar for sale Triumph Classifieds 1
J For Sale Triumph TR2 TR3 TR3A New Moss Motors Black Karvel Style Carpet Kit Triumph Classifieds 0
S Wanted Wanted - TR3A Horns Triumph Classifieds 2
K For Sale Triumph TR3A front bumper and overiders Triumph Classifieds 0
71TR6 TR2/3/3A TR3A Drive shaft cork seal Triumph 10
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
K For Sale TR3A Steering wheel Triumph Classifieds 4
A TR2/3/3A A rigged TR3a oil filter housing Triumph 8
T For Sale Tr3a 1961 Triumph Classifieds 0
S TR2/3/3A Need New Battery for TR3A Triumph 7
S For Sale Triumph TR2/TR3/TR3A/TR3B Workshop on CCD/ROMManual – 1953 - 1962 Models Triumph Classifieds 0
M TR2/3/3A 1960 TR3A turn signal harness Triumph 6
D Wanted TR3A starting handle Triumph Classifieds 0
T TR2/3/3A TR3A Door Handle Triumph 3
W TR2/3/3A TR3A Movie Sighting Triumph 8
M TR2/3/3A Upper Fulcrum Orientation On TR3A with Late TR4 Upper Control Arms Triumph 6
R TR2/3/3A 1961 TR3A Master Cylinder[s] Rebuild Kits Triumph 4
W For Sale 1961 TR3a - Full Off Frame Restoration Triumph Classifieds 0
T TR2/3/3A TR3A Hardtop Rear Mounting Brackets Triumph 15
J TR2/3/3A TR3A gas tank repair Triumph 4
T TR2/3/3A TR3A Gas Cap Triumph 15
