TR2/3/3A TR3 Turn signal
tinman58
I have a new turn signal trafficator from TRF with a new steering wheel. The problem is that when I make a turn it won't self cancel unless I turn really sharp . Is there a adjustment? Tired of looking like a duffes driving down the road with my blinker on.
Dan
TR3driver
Great Pumpkin - R.I.P
Yup, kind of. First check that the control head won't turn and that the signal lever points straight up when the turn signals are off.
You'll need to loosen the 3 grub screws in the steering wheel and pull the control head out until you can reach the cancelling ring. Turn the steering wheel to the straight-ahead position; then turn the cancelling ring until it's lever is pointing straight down. Push it back into place in the steering wheel, making sure it goes all the way, then without turning the wheel at all, tighten all 3 grub screws snugly. That should do it.
And don't feel bad, I need to redo mine too. I apparently didn't get the screws tight enough, and it slipped.
Don Elliott
When you install the control head with the horn, it's obvious that the clicker must be straight up at 12 o'clock. But to cancel properly the "twin arrowheads" must be in the center of the slot for them. Also the centerline for the cam with the slope on each side of the slot must be straight down at 6 PM.
mallard
Would the adjustment be the same on an Austin Healey? The control head looks the same.
P TR2/3/3A TR3 turn signal and horn control wiring check Triumph 4
J TR2/3/3A TR3 turn signal issue Triumph 12
C TR2/3/3A TR3 Turn Signal Lever Triumph 3
O TR2/3/3A TR3 Turn Signal Lights Install Triumph 1
O TR2/3/3A TR3 Turn Signal Retrofit / Windshield Screws? Triumph 7
Brooklands TR2/3/3A TR3 Turn Signal question... Triumph 6
J TR2/3/3A TR3 right turn signal not working Triumph 15
T TR2/3/3A turn signal repair tr3 Triumph 2
CraigLandrum TR2/3/3A TR3 Turn signal note Triumph 6
newmexTR3 TR2/3/3A TR3 turn signal return mechanism? Triumph 31
E TR2/3/3A stubborn TR3 turn signal wires Triumph 7
F TR2/3/3A TR3 Turn Signal/Horn control head Triumph 4
M TR2/3/3A TR3 turn signal replacement Triumph 2
S TR2/3/3A TR3 Turn Signal Auto Cut-Off Triumph 5
Kleykamp TR2/3/3A 1961 TR3 turn indicator diagnosis? Triumph 4
O TR2/3/3A TR3 Rear Turn lights Versus Rear Stop Tail lights? Triumph 5
J TR2/3/3A TR3 Too Rich- What direction do I turn the nut? Triumph 3
A TR2/3/3A WHY DOES MY TR3 STALL WHEN I TURN RIGHT? Triumph 26
S TR2/3/3A tr3 turn indicator Triumph 9
Moseso TR2/3/3A TR3 Brake/Turn Lighting Improvement Discussion Triumph 12
A TR2/3/3A TR3 turn indicator not flashing in car Triumph 8
bluemiata90 TR2/3/3A TR3 rack and pinion conversion /turn signals Triumph 9
M TR2/3/3A TR3 turn signals Triumph 5
gsalt57tr3 TR2/3/3A Left turn braking problem [TR3] Triumph 2
T For Sale Free - Body Jig for TR3/TR3A Triumph Classifieds 0
J TR2/3/3A TR3 engine cylinder top clearance Triumph 22
BillyB62 TR2/3/3A Looking for the Owner of a TR3 Triumph 5
Pool Dad 1960 TR3 engine serial number Triumph 14
T TR2/3/3A TR3 coolant hoses Triumph 2
T TR2/3/3A Has anyone designed a hand brake warning light for the TR3? Triumph 3
J TR2/3/3A "TR3" painted on the engine block Triumph 13
J TR2/3/3A TR3 Rear seat Triumph 11
D Socket for TR3 Gear box drain plug Restoration & Tools 6
J TR2/3/3A TR3 gas tank mystery Triumph 5
T Wanted Wanted - 1956 TR3 Crankshaft Triumph Classifieds 0
jfarris TR2/3/3A Venture into the "dark side," Miata seats in a TR3 Triumph 2
T TR2/3/3A Question on old radio from my TR3 Triumph 9
T TR2/3/3A tr3 front carpet replacement Triumph 5
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
G For Sale: Triumph TR2, TR3, TR3A Sheet Metal Body Parts – Front Apron (valence) with grille, Bonnet (hood), Doors, Boot (trunk) Deck Lid Triumph Classifieds 3
G For Sale: Triumph TR2, TR3, TR3A, TR3B Factory Steel Hardtop, New Rear window, Partial Bracket Set Triumph Classifieds 2
A TR2/3/3A Early TR3 starter (bomb style) bushings sizes Triumph 5
T For Sale TR2 - TR3 Gas Cap for sale Triumph Classifieds 1
B TR2/3/3A TR3 Hard Top Triumph 2
D TR2/3/3A TR3 throttle linkage bell crank. Triumph 13
M TR2/3/3A Defective master cylinders Tr3 Triumph 13
BarryO TR2/3/3A setting up a TR3 clutch slave Triumph 5
M master cylinder brake/clutch Tr3 Triumph Classifieds 6
C TR2/3/3A TR3 Gearbox Problem Triumph 10
Tr3aguy TR2/3/3A Started a Car revival channel for the TR3 Triumph 12
