TR2/3/3A TR3 Turn Signal Lever
CI_TR3
Member
Somehow the little turn signal lever has come out of my control head. The screw must have just loosened and backed out over time becuase it is not broken. I have been told that the control heads are very difficult to take apart and put back together in good working order. Do I really need to spend $200 on a whole new control head? Do I have to pull the whole wiring harness and stator tube out of the steering column to try and get in there to fix it? Any other ideas? THANKS!
TR3driver
Great Pumpkin - R.I.P
I wouldn't call it "very difficult", just moderately frustrating. I've done it many times without pulling the wires, by just sitting in the drivers seat with a towel on my lap to catch the bits I drop.
You will have to take the wires at least partially loose (8" or so of slack) and loosen the 3 "grub" screws in the steering wheel. That should be enough to let you pull the head back from the wheel far enough to undo the 3 flat head screws on the back (accessible through the 3 holes in the metal plate) and then the 3 round head screws that hold the face plate and horn button on.
Collect the face plate, horn button, spring, and distance piece. Then you'll have to hold the appropriate nuts (chain nose pliers will do if you're careful and don't have a 5BA wrench handy) while you remove the two screws that hold the horn contacts in place.
That should let you get in far enough to access the screw that holds the lever; without opening up the section where all the fiddly bits are.
I've stuck a few photos up at https://s258.photobucket.com/albums/hh260/TR3driver/Control%20Head/ Someday Real Soon Now I might write an article to go with them, but I'll have to go back and retake the ones that show the little pivoting pushrods installed. The photos up there now show them installed backwards!
MGTF1250Dave
Aloha,
Here is a link to the tech archives of the Australian TR Register:
https://www.tr-register.com.au/Files/technical.htm
There is a link about 15-20 items down to an illustrated article by Clive Elsdon that is also very informative. Becareful during disassembly and do it in an area where it will be easy to find small parts that may spring free. It is a lesson I learned the hard way. The article also has a list of all the parts in the control head.
vivdownunder
Off topic but our Australian TR Register technical archive also shows how to fit fuel injection to a 4 pot TR engine. The test car really flies.
The Gallery is a good reference source for how body/trim color combinations work.
Viv.
P TR2/3/3A TR3 turn signal and horn control wiring check Triumph 4
J TR2/3/3A TR3 turn signal issue Triumph 12
O TR2/3/3A TR3 Turn Signal Lights Install Triumph 1
O TR2/3/3A TR3 Turn Signal Retrofit / Windshield Screws? Triumph 7
Brooklands TR2/3/3A TR3 Turn Signal question... Triumph 6
J TR2/3/3A TR3 right turn signal not working Triumph 15
tinman58 TR2/3/3A TR3 Turn signal Triumph 3
T TR2/3/3A turn signal repair tr3 Triumph 2
CraigLandrum TR2/3/3A TR3 Turn signal note Triumph 6
newmexTR3 TR2/3/3A TR3 turn signal return mechanism? Triumph 31
E TR2/3/3A stubborn TR3 turn signal wires Triumph 7
F TR2/3/3A TR3 Turn Signal/Horn control head Triumph 4
M TR2/3/3A TR3 turn signal replacement Triumph 2
S TR2/3/3A TR3 Turn Signal Auto Cut-Off Triumph 5
Kleykamp TR2/3/3A 1961 TR3 turn indicator diagnosis? Triumph 4
O TR2/3/3A TR3 Rear Turn lights Versus Rear Stop Tail lights? Triumph 5
J TR2/3/3A TR3 Too Rich- What direction do I turn the nut? Triumph 3
A TR2/3/3A WHY DOES MY TR3 STALL WHEN I TURN RIGHT? Triumph 26
S TR2/3/3A tr3 turn indicator Triumph 9
Moseso TR2/3/3A TR3 Brake/Turn Lighting Improvement Discussion Triumph 12
A TR2/3/3A TR3 turn indicator not flashing in car Triumph 8
bluemiata90 TR2/3/3A TR3 rack and pinion conversion /turn signals Triumph 9
M TR2/3/3A TR3 turn signals Triumph 5
gsalt57tr3 TR2/3/3A Left turn braking problem [TR3] Triumph 2
1 TR3 Fender spats sold on EBay. Triumph 0
J TR2/3/3A What size speedi-sleeve needed for pinion seal on a TR3? Triumph 6
T For Sale Free - Body Jig for TR3/TR3A Triumph Classifieds 0
J TR2/3/3A TR3 engine cylinder top clearance Triumph 22
BillyB62 TR2/3/3A Looking for the Owner of a TR3 Triumph 5
Pool Dad 1960 TR3 engine serial number Triumph 14
T TR2/3/3A TR3 coolant hoses Triumph 2
T TR2/3/3A Has anyone designed a hand brake warning light for the TR3? Triumph 3
J TR2/3/3A "TR3" painted on the engine block Triumph 13
J TR2/3/3A TR3 Rear seat Triumph 11
D Socket for TR3 Gear box drain plug Restoration & Tools 6
J TR2/3/3A TR3 gas tank mystery Triumph 5
T Wanted Wanted - 1956 TR3 Crankshaft Triumph Classifieds 0
jfarris TR2/3/3A Venture into the "dark side," Miata seats in a TR3 Triumph 2
T TR2/3/3A Question on old radio from my TR3 Triumph 9
T TR2/3/3A tr3 front carpet replacement Triumph 5
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
G For Sale: Triumph TR2, TR3, TR3A Sheet Metal Body Parts – Front Apron (valence) with grille, Bonnet (hood), Doors, Boot (trunk) Deck Lid Triumph Classifieds 3
G For Sale: Triumph TR2, TR3, TR3A, TR3B Factory Steel Hardtop, New Rear window, Partial Bracket Set Triumph Classifieds 2
A TR2/3/3A Early TR3 starter (bomb style) bushings sizes Triumph 5
T For Sale TR2 - TR3 Gas Cap for sale Triumph Classifieds 1
B TR2/3/3A TR3 Hard Top Triumph 2
D TR2/3/3A TR3 throttle linkage bell crank. Triumph 13
J For Sale 1965 TR4 + TR3 Parts - Rebuilt trans, floors, gauges, misc. Triumph Classifieds 9
M TR2/3/3A Defective master cylinders Tr3 Triumph 13
BarryO TR2/3/3A setting up a TR3 clutch slave Triumph 5
