TR2/3/3A tr3 transmission
sp53
Hello tr3 people, has anyone ever put a rear main seal in a 57 tr3 non-overdrive transmission while the trans is still in the car?
Sp53
martx-5
I haven't done it myself, but if you take the drive shaft off (might have to remove it) and take the big nut and flange off, replacement shouldn't be too much of a problem. I know one of the guys in the Triumph club with a TVR (TR6 drivetrain) did it.
MGTF1250Dave
Aloha Sp53
I replaced the rear seal in a TR3 gear box, however it was not in the car at the time. The drive shaft might need to be removed to give you room to work in. In my experience, the hardest part of the job is removing the nut that holds the flange in place. An impact wrench is the tool needed to make this an easy step. A car lift would also make it easier for you to get access from below and removing the gearbox cover allows access from above. I would think it is possible and would try it. These are all things you would be doing if you pull the gearbox out of the car to replace the seal.
Safety Fast,
Dave
S TR4/4A TR3/4/4a Transmission rebuild question Triumph 7
S TR2/3/3A What weight transmission oil in a tr3 with OD? Triumph 13
G Wanted TR3 Overdrive Transmission Triumph Classifieds 2
Moosca TR2/3/3A TR3 Overdrive Transmission Verification Triumph 5
T For Sale Free tr3 transmission radiator and generator Triumph Classifieds 2
Got_All_4 TR2/3/3A Fitting the original tr3 transmission cover over a tr6 overdrive Triumph 9
D TR2/3/3A TR3 Overdrive to transmission mating problem Triumph 8
R TR2/3/3A TR2/TR3 transmission dip stick access Triumph 10
T TR2/3/3A Will Spitfire D-type overdrive work in TR3 with TR4 transmission? Triumph 3
R TR2/3/3A TR3 A Transmission rebuild Triumph 5
charleyf TR2/3/3A Transmission numbers on a TR3 Triumph 7
Scotsman TR2/3/3A HVDA transmission conversion. 90* speedometer cable adapter may be required on TR3's Triumph 4
JFeher TR2/3/3A Has anyone installed a TR6 OD transmission in their TR3? Triumph 8
AHS TR2/3/3A TR3 transmission clutch fork & shifter removal? Triumph 5
T TR4/4A I'm back to the well of knowledge - TR3/TR4/TR4A clutch-transmission confusuion Triumph 10
P TR2/3/3A TR3 Transmission oil Triumph 13
T TR2/3/3A Is CT52431 a TR3 Transmission serial ? Triumph 4
T TR2/3/3A What weight gear oil to use in TR3 transmission? Triumph 23
Russ Austin TR2/3/3A TR3 Transmission Installation Hints / Tips Please! Triumph 14
Russ Austin TR2/3/3A TR3 Transmission question Triumph 8
mgbmedic TR2/3/3A TR3 Transmission Tunnel Triumph 8
O TR2/3/3A TR3 Transmission Removal Triumph 2
RedTR3 TR2/3/3A TR3 Transmission Differences Triumph 27
RedTR3 TR2/3/3A Removing TR3 OD transmission Triumph 5
M TR2/3/3A Draining and refilling TR3 transmission with OD Triumph 23
M TR2/3/3A Metal transmission cover color for TR3 ??? Triumph 9
T TR2/3/3A TR3 transmission cover - supposed to be metal? Triumph 5
Moseso TR2/3/3A TR3 Transmission noises Triumph 11
K TR2/3/3A Toyota transmission for TR3=long distance driving Triumph 13
CCURTISS TR2/3/3A TR3 Transmission Tunnel Sealant Triumph 7
CCURTISS TR2/3/3A TR3 Transmission Questions Triumph 14
B TR2/3/3A tr3 transmission oil fill plug Triumph 18
White79MGB TR2/3/3A TR3 Transmission Oil Triumph 18
hondo402000 TR6 TR3 VS TR6 Transmission units Triumph 6
gubba TR2/3/3A TR3 B 5 speed Transmission conversion Triumph 0
S TR2/3/3A tr3 transmission front seal Triumph 3
mcguijo TR2/3/3A TR3 Transmission Blues Triumph 16
jsneddon TR2/3/3A TR3 Transmission Oil Capacity Triumph 3
S TR2/3/3A Tr3 transmission oil Triumph 4
T TR2/3/3A Hole in transmission bellhousing TR3!!!! Triumph 5
T TR2/3/3A Proper oil TR3 Transmission Triumph 3
